Adafruit BNO055 Absolute Orientation
Sensor
Created by Kevin Townsend
https://learn.adafruit.com/adafruit-bno055-absolute-orientation-sensor
Last updated on 2022-10-18 12:54:22 PM EDT
©Adafruit Industries
Page 1 of 47
Table of Contents
Overview
5
• Data Output
• Related Resources
Pinouts
7
Power Pins
I2C Pins
STEMMA QT version
Other Pins
Assembly
9
• Prepare the header strip:
• Add the breakout board:
• And Solder!
Arduino Code
Wiring for Arduino
Software
Adafruit Unified Sensor System
'sensorapi' Example
Raw Sensor Data
.getVector ( adafruit_vector_type_t vector_type )
.getQuat(void)
.getTemp(void)
'rawdata' Example
WebSerial Visualizer
Step
Step
Step
Step
Step
Step
Step
24
Requirements
Opening the Processing Sketch
Run the Bunny Sketch on the Uno
Rabbit Disco!
Device Calibration
19
1 - Wire up the BNO055 to your Microcontroller using I2C
2 - Load the Sketch onto your device
3 - Install Chrome
4 - Enable Web Serial API if necessary
5 - Visit the Adafruit 3D Model viewer
6 - Calibration
7 - Euler Angles or Quaternions
Processing Test
12
28
Interpretting Data
Generating Calibration Data
Persisting Calibration Data
Bosch Video
Python & CircuitPython
30
• CircuitPython Microcontroller Wiring - I2C
• CircuitPython Microcontroller Wiring - UART
• Python Computer Wiring - I2C
Page 2 of 47
Python Computer Wiring - UART
CircuitPython Installation of BNO055 Library
CircuitPython & Python Usage
Usage
Full Example Code
Python Docs
38
WebGL Example
38
Dependencies
Download the WebGL Example
Start Server
Sensor Calibration
Usage
More Info
FAQs
43
Downloads
45
Files
Pre-Compiled Bunny Rotate Binaries
Schematic
Board Dimensions
Schematic for STEMMA QT
Fab Print for STEMMA QT
Page 3 of 47
Page 4 of 47
Overview
If you've ever ordered and wire up a 9-DOF sensor, chances are you've also realized
the challenge of turning the sensor data from an accelerometer, gyroscope and
magnetometer into actual "3D space orientation"! Orientation is a hard problem to
solve. The sensor fusion algorithms (the secret sauce that blends accelerometer,
magnetometer and gyroscope data into stable three-axis orientation output) can
be mind-numbingly difficult to get right and implement on low cost real time systems.
Bosch is the first company to get this right by taking a MEMS accelerometer,
magnetometer and gyroscope and putting them on a single die with a high speed
ARM Cortex-M0 based processor to digest all the sensor data, abstract the sensor
fusion and real time requirements away, and spit out data you can use in quaternions,
Euler angles or vectors.
Page 5 of 47
The new version of the board includes SparkFun qwiic (https://adafru.it/Fpw) compatib
le STEMMA QT (https://adafru.it/Ft4) connectors for the I2C bus so you don't even
need to solder! Use a a plug-and-play STEMMA QT cable to get 9 DoF data ASAP.
Rather than spending weeks or months fiddling with algorithms of varying accuracy
and complexity, you can have meaningful sensor data in minutes thanks to the
BNO055 - a smart 9-DOF sensor that does the sensor fusion all on its own!
Data Output
The BNO055 can output the following sensor data:
• Absolute Orientation (Euler Vector, 100Hz)
Three axis orientation data based on a 360° sphere
• Absolute Orientation (Quaterion, 100Hz)
Four point quaternion output for more accurate data manipulation
• Angular Velocity Vector (100Hz)
Three axis of 'rotation speed' in rad/s
• Acceleration Vector (100Hz)
Three axis of acceleration (gravity + linear motion) in m/s^2
• Magnetic Field Strength Vector (20Hz)
Three axis of magnetic field sensing in micro Tesla (uT)
• Linear Acceleration Vector (100Hz)
Three axis of linear acceleration data (acceleration minus gravity) in m/s^2
Page 6 of 47
• Gravity Vector (100Hz)
Three axis of gravitational acceleration (minus any movement) in m/s^2
• Temperature (1Hz)
Ambient temperature in degrees celsius
Related Resources
• Datasheet (https://adafru.it/f0H)
• Adafruit BNO055 Library (https://adafru.it/f0I) (Github)
Pinouts
Page 7 of 47
Note: The pin order on the STEMMA QT version of the board is not the same as the
original version. The pins are the same otherwise.
Power Pins
• VIN: 3.3-5.0V power supply input
• 3VO: 3.3V output from the on-board linear voltage regulator, you can grab up to
about 50mA as necessary
• GND: The common/GND pin for power and logic
I2C Pins
• SCL - I2C clock pin, connect to your microcontrollers I2C clock line. This pin can
be used with 3V or 5V logic, and there's a 10K pullup on this pin.
• SDA - I2C data pin, connect to your microcontrollers I2C data line. This pin can
STEMMA QT version
• STEMMA QT (https://adafru.it/Ft4) - These connectors allow you to connectors to
dev boards with STEMMA QT connectors or to other things with various
associated accessories (https://adafru.it/Ft6)
Page 8 of 47
Other Pins
• RST: Hardware reset pin. Set this pin low then high to cause a reset on the
sensor. This pin is 5V safe.
• INT: The HW interrupt output pin, which can be configured to generate an
interrupt signal when certain events occur like movement detected by the
accelerometer, etc. (not currently supported in the Adafruit library, but the chip
and HW is capable of generating this signal). The voltage level out is 3V
• ADR: Set this pin high to change the default I2C address for the BNO055 if you
need to connect two ICs on the same I2C bus. The default address is 0x28. If
this pin is connected to 3V, the address will be 0x29
• PS0 and PS1: These pins can be used to change the mode of the device (it can
also do HID-I2C and UART) and also are provided in case Bosch provides a
firmware update at some point for the ARM Cortex M0 MCU inside the sensor.
They should normally be left unconnected.
Assembly
Page 9 of 47
Cut the strip to length if necessary. It will
be easier to solder if you insert it into a
breadboard - long pins down
Place the breakout board over the pins so
that the short pins poke through the
breakout pads
Page 10 of 47
And Solder!
Be sure to solder all pins for reliable
electrical contact.
Solder the longer power/data strip first
(For tips on soldering, be sure to check out
our Guide to Excellent Soldering (https://
adafru.it/aTk)).
Page 11 of 47
You're done! Check your solder joints
visually and continue onto the next steps
Arduino Code
Wiring for Arduino
You can easily wire this breakout to any microcontroller, we'll be using an Arduino. For
another kind of microcontroller, just make sure it has I2C capability, then port the
code - its pretty simple stuff!
Page 12 of 47
To connect the assembled BNO055
breakout to an Arduino Uno, follow the
wiring diagram.
Connect Vin (red wire) to the power
supply, 3-5V is fine. Use the same voltage
that the microcontroller logic is based off
of. For most Arduinos, that is 5V
Connect GND (black wire) to common
power/data ground
Connect the SCL (yellow wire) pin to the
I2C clock SCL pin on your Arduino. On an
UNO & '328 based Arduino, this is also
known as A5, on a Mega it is also known
as digital 21 and on a Leonardo/Micro,
digital 3
Connect the SDA (blue wire) pin to the I2C
data SDA pin on your Arduino. On an UNO
& '328 based Arduino, this is also known
as A4, on a Mega it is also known as digital
20 and on a Leonardo/Micro, digital 2
If you're using a Genuino Zero or Arduino Zero with the built in EDBG interface
you may need to use I2C address 0x29 since 0x28 is 'taken' by the DBG chip
Software
The Adafruit_BNO055 driver (https://adafru.it/f0I) supports reading raw sensor data,
or you can use the Adafruit Unified Sensor (https://adafru.it/dGB) system to retrieve
orientation data in a standard data format.
Page 13 of 47
Open up the Arduino library manager:
Search for the Adafruit Sensor library and install it
Search for the Adafruit BNO055 library and install it
We also have a great tutorial on Arduino library installation at:
http://learn.adafruit.com/adafruit-all-about-arduino-libraries-install-use (https://
adafru.it/aYM)
Since the Adafruit_BNO055 driver is based on the Adafruit Unified Sensor system,
you can retrieve your three axis orientation data (in Euler angles) using the standard
types and functions described in the Adafruit Sensor learning guide (https://adafru.it/
kA0) (.getEvent (https://adafru.it/kA0), .getSensor (https://adafru.it/kA0), etc.).
This is probably the easiest option if all you care about is absolute orientation data
across three axis.
Page 14 of 47
For example, the following code snippet shows the core of what is needed to start
reading data using the Unified Sensor System:
#include
#include
#include
#include
<Wire.h>
<Adafruit_Sensor.h>
<Adafruit_BNO055.h>
<utility/imumaths.h>
Adafruit_BNO055 bno = Adafruit_BNO055(55);
void setup(void)
Serial.begin(9600);
Serial.println("Orientation Sensor Test"); Serial.println("");
/* Initialise the sensor */
if(!bno.begin())
/* There was a problem detecting the BNO055 ... check your connections */
Serial.print("Ooops, no BNO055 detected ... Check your wiring or I2C ADDR!");
while(1);
delay(1000);
bno.setExtCrystalUse(true);
void loop(void)
/* Get a new sensor event */
sensors_event_t event;
bno.getEvent(&event);
/* Display the floating point data */
Serial.print("X: ");
Serial.print(event.orientation.x, 4);
Serial.print("\tY: ");
Serial.print(event.orientation.y, 4);
Serial.print("\tZ: ");
Serial.print(event.orientation.z, 4);
Serial.println("");
delay(100);
'sensorapi' Example
To test the Unified Sensor System output, open the sensorapi demo in the
Adafruit_BNO055 examples folder:
This should produce the following output on the Serial Monitor:
Page 15 of 47
Raw Sensor Data
If you don't want to use the Adafruit Unified Sensor system (for example if you want to
access the raw accelerometer, magnetometer or gyroscope data directly before the
sensor fusion algorithms process it), you can use the raw helper functions in the
driver.
The key raw data functions are:
• getVector (adafruit_vector_type_t vector_type)
• getQuat (void)
• getTemp (void)
The .getVector function accepts a single parameter (vector_type), which indicates
what type of 3-axis vector data to return.
The vector_type field can be one of the following values:
• VECTOR_MAGNETOMETER (values in uT, micro Teslas)
• VECTOR_GYROSCOPE (values in rps, radians per second)
• VECTOR_EULER (values in Euler angles or 'degrees', from 0..359)
• VECTOR_ACCELEROMETER (values in m/s^2)
• VECTOR_LINEARACCEL (values in m/s^2)
• VECTOR_GRAVITY (values in m/s^2)
Page 16 of 47
For example, to get the Euler angles vector, we could run the following code:
imu::Vector<3> euler = bno.getVector(Adafruit_BNO055::VECTOR_EULER);
Serial.print(euler.x());
Serial.print(" Y: ");
Serial.print(euler.y());
Serial.print(" Z: ");
Serial.print(euler.z());
Serial.println("");
.getQuat(void)
The .getQuat function returns a Quaternion, which is often easier and more accurate
to work with than Euler angles when doing sensor fusion or data manipulation with
raw sensor data.
You can get a quaternion data sample via the following code:
imu::Quaternion quat = bno.getQuat();
/* Display the quat data */
Serial.print("qW: ");
Serial.print(quat.w(), 4);
Serial.print(" qX: ");
Serial.print(quat.y(), 4);
Serial.print(" qY: ");
Serial.print(quat.x(), 4);
Serial.print(" qZ: ");
Serial.print(quat.z(), 4);
Serial.println("");
.getTemp(void)
The .getTemp helper returns the current ambient temperature in degrees celsius, and
can be read via the following function call:
/* Display the current temperature */
int8_t temp = bno.getTemp();
Serial.print("Current Temperature: ");
Serial.print(temp);
Serial.println(" C");
Serial.println("");
Page 17 of 47
'rawdata' Example
To test the raw data ouput, open the rawdata demo in the Adafruit_BNO055
examples folder:
By default, the sketch generates Euler angle absolute orientation data, but you can
easily modify the data displayed by changing the value provided to .getVector below:
// Possible vector values can be:
// - VECTOR_ACCELEROMETER - m/s^2
// - VECTOR_MAGNETOMETER - uT
// - VECTOR_GYROSCOPE
- rad/s
// - VECTOR_EULER
- degrees
// - VECTOR_LINEARACCEL
- m/s^2
// - VECTOR_GRAVITY
- m/s^2
Serial.println("");
Page 18 of 47
That raw data is all fine and good, but we want to see what they mean in 3D space,
right? Traditionally, a Processing sketch would be used to read the serial data and
convert it to a 3D rotation - but thanks to Web Serial API we can use any Chrome
browser - a lot easier than installing Processing! (https://adafru.it/JaV)
Step 1 - Wire up the BNO055 to your Microcontroller
using I2C
First wire up a BNO055 to your board exactly as shown on the previous pages using
the I2C interface. Here's an example of wiring a Feather M0 to the sensor with I2C:
Board 3V to sensor VIN
Board GND to sensor GND
Board SCL to sensor SCL
Board SDA to sensor SDA
Page 19 of 47
Step 2 - Load the Sketch onto your device
Continue by making sure you still have the Arduino IDE open and have the latest
version of the Adafruit BNO055 library installed. Open the sketch at Examples →
Adafruit BNO055 → webserial_3d
Upload the sketch to your Microcontroller Board.
Step 3 - Install Chrome
Start by installing the Chrome browser if you haven't yet. (https://adafru.it/B-S)
Step 4 - Enable Web Serial API if necessary
As of Chrome 89, Web Serial is enabled by default.
At the time of this tutorial, you'll need to enable the Serial API, which is really easy.
Visit chrome://flags from within Chrome. Find and enable the Experimental Web
Platform features
Page 20 of 47
Restart Chrome
Step 5 - Visit the Adafruit 3D Model viewer
In Chrome, visit https://adafruit.github.io/Adafruit_WebSerial_3DModelViewer/ (https://
adafru.it/PPE)
Verify you have 9600 Baud selected (it only really matters for non-native-serial
devices but might as well make sure its right). If you changed it in the sketch, be sure
it matches.
Click Connect
When the security window pops up, pick the matching Serial/COM port for your board
running the AHRS sketches. Make sure the serial port isn't open in Arduino or
something else.
Page 21 of 47
You'll see the serial port monitor on the bottom and a 3D bunny on the top. Try
rotating and twisting the sensor to see it move!
Step 6 - Calibration
The devices will need to be calibrated each time it is powered up. You can see the
Device Calibration page for more details on performing the actual calibration, but the
WebSerial interface provides a convenient way to check the current calibration status.
Page 22 of 47
When you first connect, you'll see that
most of the calibration registers show as
Uncalibrated.
Once you have gone through the
calibration steps, you will see that they are
all fully calibrated.
Step 7 - Euler Angles or Quaternions
The WebSerial interface is also able to use both Euler Angles and Quaternions. Euler
angles represent the X, Y, and Z axes and are easier to understand, but also have the
disadvantage of "Gimbal Lock" at certain angles. To get around that, quaternions can
be used. The angle type selection is at the top.
You can choose between using Euler Angles and Quaternions.
Page 23 of 47
Try playing around with both by moving the bunny around and see if you can see the
differences!
Processing Test
We don't recommend using processing for visualization, as its not easy. Check
the previous page for how to use a Chrome browser
To help you visualize the data, we've put together a basic Processing sketch that
loads a 3D model (in the .obj file format) and renders it using the data generated by
the BNO055 sketch on the Uno. The "bunny" sketch on the uno published data over
UART, which the Processing sketch reads in, rotating the 3D model based on the
incoming orientation data.
Page 24 of 47
Requirements
• Processing 2.x (https://adafru.it/ddm)
◦ Note that you can try later Processing versions like 3.0+ too. On some
platforms Processing 2.2.1 has issues with supporting 3D acceleration (you
might see 'NoClassDefFoundError: processing/awt/PGraphicsJava2D'
errors). In those cases grab the later Processing 3.0+ release and use it
instead of 2.x.
• Saito's OBJ Loader (https://adafru.it/mf0) library for Processing (included as part
of the Adafruit repo since Google Code is now 'End of Life').
• G4P GUI library (https://adafru.it/dMO) for Processing (download the latest
version here (https://adafru.it/dMP) and copy the zip into the processing libraries
folder along with the OBJ loader library above). Version 3.5.2 was used in this
guide.
The OBJ library is required to load 3D models. It isn't strictly necessary and you could
also render a boring cube in Processing, but why play with cubes when you have
rabbits?!
The processing sketch to render the 3D model is contained in the sample folder as
the ahrs sketch for the Uno.
With Processing open, navigate to you Adafruit_BNO055 library folder (ex.: 'libraries/
Adafruit_BNO055'), and open 'examples/bunny/processing/cuberotate/
cuberotate.pde'. You should see something like this in Processing:
Page 25 of 47
Make sure that the "bunny" example sketch is running on the Uno, and that the Serial
Monitor is closed.
With the sample sketch running on the Uno, click the triangular 'play' icon in
Processing to start the sketch.
Rabbit Disco!
You should see a rabbit similar to the following image:
Page 26 of 47
Before the rabbit will rotate you will need to click the : to the right of the serial port
name. This will open a list of available serial ports, and you will need to click the
appropriate serial port that your Arduino uses (check the Arduino IDE to see the port
name if you're unsure). The chosen serial port should be remembered if you later run
the sketch again.
As you rotate your breakout board, the rabbit should rotate to reflect the movement
of the breakout in 3D-space, as seen in the video below
Page 27 of 47
Also notice in the upper right corner of the dialog box at the top that the calibration of
each sensor is displayed. It's important to calibrate the BNO055 sensor so that the
most accurate readings are retrieved. Each sensor on the board has a separate
calibration status from 0 (uncalibrated) up to 3 (fully calibrated). Check out the video
and information from this guide for how to best calibrate the BNO055 sensor (https://
adafru.it/kA1).
Device Calibration
The BNO055 includes internal algorithms to constantly calibrate the gyroscope,
accelerometer and magnetometer inside the device.
The exact nature of the calibration process is a black box and not fully documented,
but you can read the calibration status of each sensor using the .getCalibration
function in the Adafruit_BNO055 (https://adafru.it/f0I) library. An example showing
how to use this function can be found in the sensorapi demo, though the code is also
shown below for convenience sake.
The four calibration registers -- an overall system calibration status, as well individual
gyroscope, magnetometer and accelerometer values -- will return a value between '0'
(uncalibrated data) and '3' (fully calibrated). The higher the number the better the data
will be.
Display sensor calibration status
Page 28 of 47
void displayCalStatus(void)
/* Get the four calibration values (0..3) */
/* Any sensor data reporting 0 should be ignored, */
/* 3 means 'fully calibrated" */
uint8_t system, gyro, accel, mag;
system = gyro = accel = mag = 0;
bno.getCalibration(&system, &gyro, &accel, &mag);
/* The data should be ignored until the system calibration is > 0 */
Serial.print("\t");
if (!system)
Serial.print("! ");
/* Display the individual values */
Serial.print("Sys:");
Serial.print(system, DEC);
Serial.print(" G:");
Serial.print(gyro, DEC);
Serial.print(" A:");
Serial.print(accel, DEC);
Serial.print(" M:");
Serial.println(mag, DEC);
Interpretting Data
The BNO055 will start supplying sensor data as soon as it is powered on. The
sensors are factory trimmed to reasonably tight offsets, meaning you can get valid
data even before the calibration process is complete, but particularly in NDOF mode y
ou should discard data as long as the system calibration status is 0 if you have the
choice.
The reason is that system cal '0' in NDOF mode means that the device has not yet
found the 'north pole', and orientation values will be off The heading will jump to an
absolute value once the BNO finds magnetic north (the system calibration status
jumps to 1 or higher).
When running in NDOF mode, any data where the system calibration value is '0'
should generally be ignored
To generate valid calibration data, the following criteria should be met:
• Gyroscope: The device must be standing still in any position
Page 29 of 47
• Magnetometer: In the past 'figure 8' motions were required in 3 dimensions, but
with recent devices fast magnetic compensation takes place with sufficient
normal movement of the device
• Accelerometer: The BNO055 must be placed in 6 standing positions for +X, -X,
+Y, -Y, +Z and -Z. This is the most onerous sensor to calibrate, but the best
solution to generate the calibration data is to find a block of wood or similar
object, and place the sensor on each of the 6 'faces' of the block, which will help
to maintain sensor alignment during the calibration process. You should still be
able to get reasonable quality data from the BNO055, however, even if the
accelerometer isn't entirely or perfectly calibrated.
Once the device is calibrated, the calibration data will be kept until the BNO is
powered off.
The BNO doesn't contain any internal EEPROM, though, so you will need to perform a
new calibration every time the device starts up, or manually restore previous
calibration values yourself.
Bosch Video
Here's a video from the BNO055 makers on calibration!
It's easy to use the BNO055 sensor with Python and CircuitPython, and the Adafruit
CircuitPython BNO055 (https://adafru.it/C43) library. This library allows you to easily
write Python code that reads the acceleration and orientation of the sensor.
You can use this sensor with any CircuitPython microcontroller board or with a
computer that has GPIO and Python thanks to Adafruit_Blinka, our CircuitPython-forPython compatibility library (https://adafru.it/BSN).
Page 30 of 47
First wire up a BNO055 to your board exactly as shown on the previous pages for
Arduino using the I2C interface. Here's an example of wiring a Feather M4 to the
sensor with I2C:
Board 3V to sensor VIN (red wire for
STEMMA QT)
Board GND to sensor GND (black wire for
STEMMA QT)
Board SCL to sensor SCL (yellow wire for
STEMMA QT)
Board SDA to sensor SDA (blue wire for
STEMMA QT)
Page 31 of 47
Here's an example of wiring a Feather M4 to the sensor with UART:
Board TX to sensor SCL
Board RX to sensor SDA
sensor PS1 to sensor VIN
Since there's dozens of Linux computers/boards you can use we will show wiring for
Raspberry Pi. For other platforms, please visit the guide for CircuitPython on Linux to
see whether your platform is supported (https://adafru.it/BSN).
Here's the Raspberry Pi wired with I2C:
Page 32 of 47
Pi 3V3 to sensor VIN (red wire for STEMMA
QT)
Pi GND to sensor GND (black wire for
STEMMA QT)
Pi SCL to sensor SCL (yellow wire for
STEMMA QT)
Pi SDA to sensor SDA (blue wire for
STEMMA QT)
Older versions of the Raspberry Pi firmware do not have I2C clock stretching
support so they don't work well with the BNO. Please ensure your firmware is
updated to the latest version before continuing and slow down the I2C as
explained here https://learn.adafruit.com/circuitpython-on-raspberrypi-linux/i2cclock-stretching
Page 33 of 47
Here's the Raspberry Pi wired with UART:
Pi TXD to sensor SCL
Pi RXD to sensor SDA
You will also need to configure the Pi to enable the UART and disable the login
console from using it.
Library
Next you'll need to install the Adafruit CircuitPython BNO055 (https://adafru.it/C43) lib
rary on your CircuitPython board.
First make sure you are running the latest version of Adafruit CircuitPython (https://
adafru.it/tBa) for your board.
Next you'll need to install the necessary libraries to use the hardware--carefully follow
the steps to find and install these libraries from Adafruit's CircuitPython library bundle
(https://adafru.it/zdx). For example the Circuit Playground Express guide has a great
page on how to install the library bundle (https://adafru.it/Bf2) for express boards.
The lib folder on your CIRCUITPY drive should contain at least the following libraries:
• adafruit_bno055.mpy
• adafruit_bus_device
• adafruit_register
Page 34 of 47
Before continuing make sure your board's lib folder or root filesystem has the adafruit
_bno055.mpy, adafruit_bus_device, and adafruit_register files and folders copied
over.
Next connect to the board's serial REPL (https://adafru.it/Awz) so you are at the
CircuitPython >>> prompt.
You'll need to install the Adafruit_Blinka library that provides the CircuitPython
support in Python. This may also require enabling I2C on your platform and verifying
you are running Python 3. Since each platform is a little different, and Linux changes
often, please visit the CircuitPython on Linux guide to get your computer ready (https:
//adafru.it/BSN)!
Once that's done, from your command line run the following command:
• sudo pip3 install adafruit-circuitpython-bno055
If your default Python is version 3 you may need to run 'pip' instead. Just make sure
you aren't trying to use CircuitPython on Python 2.x, it isn't supported!
To use this sensor, you must enable i2c slowdown on the Raspberry Pi device tree
overlay. Check out this guide for instructions! (https://adafru.it/C7x)
To demonstrate the usage of the sensor we'll initialize it and read the acceleration,
orientation (in Euler angles), and more from the board's Python REPL. The difference
between I2C and UART is only with the initialization. After that, you can use the
sensor the same with either connection.
Page 35 of 47
I2C Initialization
If you are using the I2C connection, create you sensor object as follows:
import board
import busio
import adafruit_bno055
i2c = busio.I2C(board.SCL, board.SDA)
sensor = adafruit_bno055.BNO055_I2C(i2c)
UART Initialization - CircuitPython
If you are using the UART connection with a board (like a Feather) running
CircuitPython, create your sensor object as follows:
import
import
import
uart =
sensor
board
busio
adafruit_bno055
busio.UART(board.TX, board.RX)
= adafruit_bno055.BNO055_UART(uart)
UART Initialization - Python
Check how you specific board supports UART and where the port entry is created and
named. For the Raspberry Pi, this is done using the pyserial module and the UART
used is /dev/serial0 . Then you create your sensor object as follows:
import
import
uart =
sensor
serial
adafruit_bno055
serial.Serial("/dev/serial0")
Usage
Now you're ready to read values from the sensor using any of these properties:
• temperature - The sensor temperature in degrees Celsius.
• acceleration - This is a 3-tuple of X, Y, Z axis accelerometer values in meters per
second squared.
• magnetic - This is a 3-tuple of X, Y, Z axis magnetometer values in microteslas.
• gyro - This is a 3-tuple of X, Y, Z axis gyroscope values in degrees per second.
• euler - This is a 3-tuple of orientation Euler angle values.
• quaternion - This is a 4-tuple of orientation quaternion values.
Page 36 of 47
• linear_acceleration - This is a 3-tuple of X, Y, Z linear acceleration values (i.e.
without effect of gravity) in meters per second squared.
• gravity - This is a 3-tuple of X, Y, Z gravity acceleration values (i.e. without the
effect of linear acceleration) in meters per second squared.
That's all there is to using the BNO055 sensor with CircuitPython!
Here's a complete example that prints each of the properties every second. Save this
as code.py on your board and look for the output in the serial REPL.
Full Example Code
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# SPDX-License-Identifier: MIT
import time
import board
i2c = board.I2C()
# If you are going to use UART uncomment these lines
# uart = board.UART()
# sensor = adafruit_bno055.BNO055_UART(uart)
last_val = 0xFFFF
def temperature():
global last_val # pylint: disable=global-statement
result = sensor.temperature
if abs(result - last_val) == 128:
return 0b00111111 & result
last_val = result
return result
Page 37 of 47
while True:
print("Temperature: {} degrees C".format(sensor.temperature))
print(
"Temperature: {} degrees C".format(temperature())
) # Uncomment if using a Raspberry Pi
print("Accelerometer (m/s^2): {}".format(sensor.acceleration))
print("Magnetometer (microteslas): {}".format(sensor.magnetic))
print("Gyroscope (rad/sec): {}".format(sensor.gyro))
print("Euler angle: {}".format(sensor.euler))
print("Quaternion: {}".format(sensor.quaternion))
print("Linear acceleration (m/s^2): {}".format(sensor.linear_acceleration))
print("Gravity (m/s^2): {}".format(sensor.gravity))
print()
time.sleep(1)
Python Docs
Python Docs (https://adafru.it/C45)
WebGL Example
Included with the BNO055 library is an example of how to send orientation readings
to a webpage and use it to rotate a 3D model. Follow the steps below to setup and
run this example.
This example is for use with Raspberry Pi and other Linux computers - flask doesn't
run on CircuitPython yet!
Dependencies
In addition to the BNO055 libary, you'll need to install the flask Python web
framework (https://adafru.it/cFR).
Connect to your board in a command terminal and run the following commands:
sudo apt-get update
sudo apt-get install python3-flask
You will also need to be using a web browser that supports WebGL (https://adafru.it/
fEf) on your computer or laptop. I recommend and have tested the code for this
project with the latest version of Chrome (https://adafru.it/fEg).
Page 38 of 47
The example can be found in the library repo here (https://adafru.it/ENo). There are
various ways you can get all the code. The easiest is probably to just clone the repo
to your Pi:
git clone https://github.com/adafruit/Adafruit_CircuitPython_BNO055.git
And then you can navigate to the examples folder in the repo. Or copy the example to
another location, etc.
Start Server
Navigate to the webgl_demo example folder that you downloaded above. Then you
can start the server by running:
sudo python3 server.py
You should see text like the following after the server starts running:
* Running on http://0.0.0.0:5000/ (Press CTRL+C to quit)
* Restarting with stat
Now open a web browser on your computer and navigate to your board's IP address
or hostname on port 5000. For example on a Raspberry Pi http://raspberrypi.local:
5000/ (https://adafru.it/fEh) might work, or on a BeagleBone Black http://beaglebone:
5000/ (https://adafru.it/fEi) is the URL to try. If neither URL works you'll need to look
up the IP address of your device (https://adafru.it/fEj) and then access it on port 5000.
For example if your board has the IP address 192.168.1.5 you would access http://
192.168.1.5:5000/ (https://adafru.it/fEk).
Once the page loads you should see something like the following:
Page 39 of 47
If you move the BNO055 sensor you should see the 3D model move too. However
when the demo first runs the sensor will be uncalibrated and likely not providing good
orientation data. Follow the next section to learn how to calibrate the sensor.
Sensor Calibration
This feature is currently not active. Once the library has been updated to allow
calibration data to be saved and loaded, this section will get updated.
For now, just have fun spinning the little 3D rabbit around.
Usage
You can line up the axes of the sensor and 3D model by using the Straighten button.
First you'll need to place the BNO sensor in a very specific orientation. Place the
sensor flat in front of you and with the row of SDA, SCL, etc. pins facing away from
you like shown below:
Page 40 of 47
Then click the Straighten button and you should see the 3D model snap into its
normal position:
Now move the BNO055 sensor around and you should see your movements exactly
matched by the 3D model!
You can also change the 3D model by clicking the Model drop down on the right and
changing to a different model, like a cat statue:
Page 41 of 47
That's all there is to using the BNO055 WebGL demo!
To stop the server go back to the terminal where it was started and press Ctrl-C.
More Info
Describing how all of the WebGL code works is a little too complex for this guide,
however the high level components of the example are:
• flask web service framework (https://adafru.it/cFR): This is a great, simple web
framework that is used by server.py to serve the main index.html page and
expose a few web service endpoints to read BNO sensor data and save/load
calibration data.
• HTML5 server sent events (https://adafru.it/dh7): This is how data is sent from
the server to the webpage. With SSE a connection is kept open and data is
pushed to the client web page. BNO sensor readings are taken and sent over
SSE where they're use to update the orientation of the model. This page (https:/
/adafru.it/fEl) has a little more info on how to use HTML5 SSE with the flask
framework (although it uses a more complex multiprocessing framework called g
event (https://adafru.it/fEm) that isn't necessary for simple apps like this demo).
• Three.js (https://adafru.it/fEn): This is the JavaScript library that handles all the
3D model rendering.
• Bootstrap (https://adafru.it/fEo) & jQuery (https://adafru.it/fEp): These are a
couple other JavaScript libraries that are used for the layout and some core
functionality of the page.
Page 42 of 47
That's all there is to using the BNO055 WebGL demo. Enjoy using the BNO055
absolute orientation sensor in your own projects!
FAQs
Can I manually set the calibration constants?
Yes you can save and restore the calibration of the sensor, check out the
restore_offsets example: https://github.com/adafruit/Adafruit_BN ...
ffsets.ino (https://adafru.it/kBv)
One thing to keep in mind though is that the sensor isn't necessarily 'plug and play'
with loading the calibration data, in particular the magnetometer needs to be
recalibrated even if the offsets are loaded. The magnetometer calibration is very
dynamic so saving the values once might not really help when they're reloaded
and the EMF around the sensor has changed.
For further details check out the datasheet and Bosch's info on the sensor for
calibration info: https://www.bosch-sensortec.com/en/home ... 1/bno055_4 (https://
adafru.it/kBw)
Does the device make any assumptions about its initial
orientation?
You can customize how the axes are oriented (i.e. swap them around, etc.) but the
Adafruit Arduino library doesn't expose it right now. Check out section 3.4 Axis
Remap of the BNO055 datasheet for info on the registers to adjust its orientation:
https://www.adafruit.com/datasheets/BST ... 000_12.pdf (https://adafru.it/kBx)
Another thing to be aware of is that until the sensor calibrates it has a relative
orientation output (i.e. orientation will be relative to where the sensor was when it
powered on).
A system status value of '0' in NDOF mode means that the device has not yet
found the 'north pole', and orientation values will be relative not absolute. Once
calibration and setup is complete (system status > '0') the heading will jump to an
absolute value since the BNO has found magnetic north (the system calibration
status jumps to 1 or higher). See the Device Calibration page in this learning guide
for further details.
Page 43 of 47
Why doesn't Euler output seem to match the Quaternion
output?
The Euler angles coming out of the chip are based on 'automatic orientation
detection', which has the drawback of not being continuous for all angles and
situations.
According to Bosch BNO055 Euler angle output should only be used for
eCompass, where pitch and roll stay below 45 degrees.
For absolute orientation, quaternions should always be used, and they can be
converted to Euler angles at the last moment via the .toEuler() helper function in
quaternion.h (https://adafru.it/lee).
I'm sometimes losing data over I2C, what can I do about
this?
Depending on your system setup, you might need to adjust the pullups on the SCL
and SDA lines to be a bit stronger. The BNO055 has very tight timing requirements
on the I2C bus, requiring short setup and rise times on the signals. By default the
breakout board has 10K pullups, which might be too weak on some setups. You can
shorten the rise times and extend the setup time on the I2C lines with 'stronger'
pullups. To do this simply add a 3.3K pullup on SCL and a 2.2K pullup on the SDA
line with a breadboard or perma-proto board, which will override to weaker 10K
pullups that are populated by default. See the image below for details:
I have some high frequency (> 2MHz) wires running near
the BNO055 and I'm getting unusual results/hanging
behavior
Turns out the BNO0055 breakout board is quite sensitive to RF interference from
nearby wires with higher frequency square waves. (https://adafru.it/PPF)
Page 44 of 47
Try to keep high frequency lines/wires away from the BNO055!
Downloads
Files
• Arduino Library (https://adafru.it/f0I)
• EagleCAD PCB files on GitHub (https://adafru.it/sEn)
• BNO055 Stemma 3D models on GitHub (https://adafru.it/11Am)
• BNO055 Datasheet (https://adafru.it/se6)
• Fritzing object in the Adafruit Fritzing Library (https://adafru.it/aP3)
The following binary images can be used in place of running the Processing Sketch,
and may help avoid the frequent API and plugin changes.
For OS X download cuberotate.app.zip, which was built on OS X 10.11.6 based on
Processing 2.2.1:
cuberotate.app.zip
https://adafru.it/wB4
Schematic
The latest version of the Adafruit BNO055 breakout can be seen below (click the
image to view the schematic in full resolution):
Page 45 of 47
Board Dimensions
The BNO055 breakout has the following dimensions (in inches):
Page 46 of 47
Page 47 of 47
