1413
    ADAFRUIT
    CONN PIN RCPT .015-.025 SOLDER
1413 数据手册
Adafruit Analog Accelerometer Breakouts Created by Bill Earl https://learn.adafruit.com/adafruit-analog-accelerometer-breakouts Last updated on 2021-11-15 05:52:51 PM EST ©Adafruit Industries Page 1 of 17 Table of Contents Overview 3 • How it Works: • MEMS - Micro Electro-Mechanical Systems • Ratiometric Output 4 4 4 Assembly 4 • Prepare the header strip: • Add the breakout board: • And Solder! 5 5 5 Arduino Wiring 5 • • • • 5 5 6 6 Wiring: Connect the Power: Connect the X, Y and Z Signal Outputs: Using the Voltage Reference: Calibration and Programming 7 • • • • • • 7 8 8 10 10 11 Static Calibration: Gravity as a Calibration Reference Calibration Method: Run the Calibration Sketch Calibration Sketch Output: Calibration Sketch CircuitPython Code 13 Downloads 15 • Files • ADXL326 Schematic & Fabrication Print • ADXL377 Schematic & Fabrication Print ©Adafruit Industries 15 16 17 Page 2 of 17 Overview The ADXL335 , ADXL326 and ADXL377 are low-power, 3-axis MEMS accelerometer modules with ratiometric analog voltage outputs. The Adafruit Breakout boards for these modules feature on-board 3.3v voltage regulation which makes them simple to interface with 5v microcontrollers such as the Arduino. The ADXL335 can measure at least +/3G in the X, Y and Z axis.  It is perfect for high-resolution static acceleration measurements such as tilt-sensing, as well as for moderate dynamic accelerations from motion, shock or vibration. The ADXL326 can measure at least +/16G(!) in the X, Y and Z axis. It is ideal for measuring more dynamic accelerations from high-performance land and air vehicles as well as for shock and impact measurements. The ADXL377 can measure at least +/200G(!) in the X, Y and Z axis. This is the sensor for measuring extreme dynamic accelerations encountered in applications such as rocketry experiments and high-impact shock measurements. ©Adafruit Industries Page 3 of 17 How it Works: MEMS - Micro Electro-Mechanical Systems The sensor consists of a micro-machined structure on a silicon wafer. The structure is suspended by polysilicon springs which allow it to deflect in the when subject to acceleration in the X, Y and/or Z axis. Deflection causes a change in capacitance between fixed plates and plates attached to the suspended structure. This change in capacitance on each axis is converted to an output voltage proportional to the acceleration on that axis. Ratiometric Output Ratiometric output means that the output voltage increases linearly with acceleration over the range. • For the ADXL335, that is approximately 0v at -3G to 3.3v at +3G. • For the ADXL326, that is approximately 0v at -16G to 3.3v at +16G. • For the ADXL377, that is approximately 0v at -200G to 3.3v at +200G. • For all modules, the output at 0G in each axis, is about 1/2 full-scale, or 1.65v. Note that the specified device ranges are guaranteed minimum ranges. Most actual devices will have a somewhat wider usable range. Also, due to manufacturing variations the zero point may be slightly offset from exactly 1/2 scale. We will discuss how to calibrate the range and offset in the Calibration and Programming section of this guide. Assembly These boards come with all surface-mount components pre-soldered. The included header strip can be soldered on for convenient use on a breadboard or with 0.1" connectors. However, for applications subject to extreme accelerations, shock or vibration, locking connectors or direct soldering plus strain relief is advised. ©Adafruit Industries Page 4 of 17 Prepare the header strip: Cut the strip[ to length if necessary.  It will be easier to solder if you insert it into a breadboard - long pins down. Add the breakout board: Place the breakout board over the pins. And Solder! Be sure to solder all pins for reliable electrical contact. Arduino Wiring Wiring: Connect the Power: • Connect the GND pin to GND on the Arduino. • Connect the VIN pin to the 5v pin on the Arduino. • (For 3.3v microprocessors, connect the pin marked 3Vo to the 3.3v supply) ©Adafruit Industries Page 5 of 17 Connect the X, Y and Z Signal Outputs: Connect X, Y and Z to the analog pins as shown below: Using the Voltage Reference: For the best possible accuracy and precision, you can use the output of the accelerometer boards voltage regulator as the analog reference for the Arduino.  Connect the 3Vo pin on the accelerometer board to the AREF pin on the Arduino. ©Adafruit Industries Page 6 of 17 If you connect an external voltage reference to the AREF pin, you must set the analog reference to EXTERNAL before calling analogRead() (e.g. in your setup() function). Otherwise, you will short the internal reference with the external reference, possibly damaging your Arduino board. Calibration and Programming Static Calibration: As with all sensors, there is some variation in output between samples of these accelerometers. For non-critical applications such as game controllers, or simple motion or tilt sensors, these variations are not important. But for applications requiring precise measurements, calibration to a reliable reference is a good idea. ©Adafruit Industries Page 7 of 17 Gravity as a Calibration Reference Acceleration is measured in units of gravitational force or "G", where 1G represents the gravitational pull at the surface of the earth.  Despite what you may have heard (h ttps://adafru.it/aRE), gravity is a pretty stable force and makes a convenient and reliable calibration reference if you happen to be a surface-dwelling earthling. For High-G accelerometers such as the ADXL377, the +/- 1G range of static calibration is too small to assure good accuracy over the +/- 200G range of the sensor. Accurate calibration for extreme G-forces requires more specialized equipment to repeatably create these extreme forces in a controlled environment. One commonly used technique is to drop the accelerometer from a known height and measure the negative acceleration at impact. Calibration Method: To calibrate the sensor to the gravitational reference, you need to determine the sensor output for each axis when it is precisely aligned with the axis of gravitational pull.  Laboratory quality calibration uses precision positioning jigs.  The method described here is simple and gives surprisingly good results.  ©Adafruit Industries Page 8 of 17 Mount the Sensor: First mount the sensor to a small breadboard (http://adafru.it/65) like the one on the left.  The back and squared edges of the breadboard make a reasonably accurate set of reference planes to orient the sensor for calibration. Wire the Sensor: Wire the sensor as shown below.  This is equivalent to the circuit shown on the previous page, with the addition of a switch. ©Adafruit Industries Page 9 of 17 Run the Calibration Sketch • Load the sketch below onto the Arduino and run it. • Open the Serial Monitor. • Lay the breadboard with the sensor on a flat surface ◦ Press and hold the button until you see "Calibrate" in the serial monitor. ◦ This will calibrate the minimum value for the z axis. • Stand the breadboard on the front edge and press the button again. to calibrate +y • Repeat this for the three other edges to calibrate +x, -y and -x. • Turn the breadboard upside down and press the button again to calibrate +z.  (Hint, the underside of a table works well to steady it.) Calibration Sketch Output: Once calibrated, the output will show the calibrated raw range for each axis, followed by the measured "G" forces.  The raw ranges can be used as constants in sketches. Raw Ranges: X: 408-616, Y: 398-610, Z: 422-625 511, 511, 625 :: -0.01G, 0.07G, 1.00G Raw Ranges: X: 408-616, Y: 398-610, Z: 422-625 511, 511, 625 :: -0.01G, 0.07G, 1.00G Raw Ranges: X: 408-616, Y: 398-610, Z: 422-625 511, 511, 625 :: -0.01G, 0.07G, 1.00G Raw Ranges: X: 408-616, Y: 398-610, Z: 422-625 511, 511, 625 :: -0.01G, 0.07G, 1.00G Raw Ranges: X: 408-616, Y: 398-610, Z: 422-625 ©Adafruit Industries Page 10 of 17 Calibration Sketch const const const const int int int int xInput = A0; yInput = A1; zInput = A2; buttonPin = 2; // Raw Ranges: // initialize to mid-range and allow calibration to // find the minimum and maximum for each axis int xRawMin = 512; int xRawMax = 512; int yRawMin = 512; int yRawMax = 512; int zRawMin = 512; int zRawMax = 512; // Take multiple samples to reduce noise const int sampleSize = 10; void setup() { analogReference(EXTERNAL); Serial.begin(9600); } void loop() { int xRaw = ReadAxis(xInput); int yRaw = ReadAxis(yInput); int zRaw = ReadAxis(zInput); if (digitalRead(buttonPin) == LOW) { AutoCalibrate(xRaw, yRaw, zRaw); } else { Serial.print("Raw Ranges: X: "); Serial.print(xRawMin); Serial.print("-"); Serial.print(xRawMax); Serial.print(", Y: "); Serial.print(yRawMin); Serial.print("-"); Serial.print(yRawMax); Serial.print(", Z: "); Serial.print(zRawMin); Serial.print("-"); Serial.print(zRawMax); Serial.println(); Serial.print(xRaw); Serial.print(", "); Serial.print(yRaw); Serial.print(", "); Serial.print(zRaw); // Convert raw long xScaled = long yScaled = long zScaled = ©Adafruit Industries values to map(xRaw, map(yRaw, map(zRaw, 'milli-Gs" xRawMin, xRawMax, -1000, 1000); yRawMin, yRawMax, -1000, 1000); zRawMin, zRawMax, -1000, 1000); Page 11 of 17 // re-scale to float xAccel = float yAccel = float zAccel = fractional Gs xScaled / 1000.0; yScaled / 1000.0; zScaled / 1000.0; Serial.print(" :: "); Serial.print(xAccel); Serial.print("G, "); Serial.print(yAccel); Serial.print("G, "); Serial.print(zAccel); Serial.println("G"); delay(500); } } // // Read "sampleSize" samples and report the average // int ReadAxis(int axisPin) { long reading = 0; analogRead(axisPin); delay(1); for (int i = 0; i < sampleSize; i++) { reading += analogRead(axisPin); } return reading/sampleSize; } // // Find the extreme raw readings from each axis // void AutoCalibrate(int xRaw, int yRaw, int zRaw) { Serial.println("Calibrate"); if (xRaw < xRawMin) { xRawMin = xRaw; } if (xRaw > xRawMax) { xRawMax = xRaw; } if (yRaw < yRawMin) { yRawMin = yRaw; } if (yRaw > yRawMax) { yRawMax = yRaw; } if (zRaw < zRawMin) { zRawMin = zRaw; } if (zRaw > zRawMax) { zRawMax = zRaw; } } ©Adafruit Industries Page 12 of 17 CircuitPython Code It's easy to use the analog accelerometer breakouts with CircuitPython and its built-in analog I/O module (https://adafru.it/BBj).  You can read the X, Y, Z accelerometer axis values as simple analog inputs that are converted to acceleration values with simple Python code. This page will show how to use the ADXL335 with a CircuitPython board like the Feather M0.  Remember your CircuitPython board must support and have three analog inputs, so the ESP8266 and small boards like Gemma M0 won't work.  Stick with a Feather or Metro M0. Wire up the ADXL335 to your board as follows: • Board 3V to sensor VIN • Board GND to sensor GND • Board A1 to sensor Xout • Board A2 to sensor Yout • Board A3 to sensor Zout Remember you can use any available analog inputs for the X, Y, Z outputs.  Be sure that these analog inputs are tolerant of up to 3.3 volt input (the Feather and Metro M0 powered by 3.3-5V as shown will be tolerant)! Next connect to the board's serial REPL  (https://adafru.it/Awz)so you are at the CircuitPython >>> prompt. ©Adafruit Industries Page 13 of 17 If you haven't read it yet it will be helpful to read the analog I/O guide (https:// adafru.it/BBj) as it explains the basics of reading analog inputs with the board's analog to digital converter.  We will read the X, Y, Z axis values as analog inputs.  First import the necessary board and analogio modules and create three inputs, one for each axis: import import x_axis y_axis z_axis board analogio = analogio.AnalogIn(board.A1) = analogio.AnalogIn(board.A2) = analogio.AnalogIn(board.A3) You can read the raw value of an axis with the value property: print('Raw XYZ: ({0}, {1}, {2})'.format(x_axis.value, y_axis.value, z_axis.value)) Raw values aren't that interesting though, you really want the acceleration.  Luckily it's easy to convert raw values to acceleration with a simple formula.  Remember these sensors output a radiometric analog voltage proportional to the acceleration between -3G and 3G.  Let's define a function to do this conversion:  def accel_value(axis): # Convert axis value to float within 0...1 range. val = axis.value / 65535 # Shift values to true center (0.5). val -= 0.5 # Convert to gravities. return val * 3.0 Now try reading the axis values again using the function to convert to gravities: x = accel_value(x_axis) y = accel_value(y_axis) z = accel_value(z_axis) print('Acceleration (G): ({0}, {1}, {2})'.format(x, y, z)) ©Adafruit Industries Page 14 of 17 That's all there is to using the ADXL335 with CircuitPython!  You can use the built-in analog input capabilities to convert the accelerometer's X, Y, Z axis acceleration into a gravity value for your own use! Here's a complete example of printing the X, Y, Z axis acceleration every second.  Save this as main.py on your board and examine the REPL output: import analogio import board import time # Create x_axis = y_axis = z_axis = analog inputs for each ADXL335 axis. analogio.AnalogIn(board.A1) analogio.AnalogIn(board.A2) analogio.AnalogIn(board.A3) # Define function to convert raw analog values to gravities. def accel_value(axis): # Convert axis value to float within 0...1 range. val = axis.value / 65535 # Shift values to true center (0.5). val -= 0.5 # Convert to gravities. return val * 3.0 # Main loop prints acceleration every second. while True: x = accel_value(x_axis) y = accel_value(y_axis) z = accel_value(z_axis) print('Acceleration (G): ({0}, {1}, {2})'.format(x, y, z)) time.sleep(1.0) Downloads Files • ADXL335 Documentation Page (https://adafru.it/aRF) • ADXL326 Documentation Page (https://adafru.it/nhe) • ADXL377 Data Sheet (https://adafru.it/cLj) • ADXL335, ADXL326 & ADXL377 Breakout Board Eagle Files (https://adafru.it/ aRH) • Fritzing objects in the Adafruit Fritzing Library (https://adafru.it/aP3) ©Adafruit Industries Page 15 of 17 ADXL326 Schematic & Fabrication Print ©Adafruit Industries Page 16 of 17 ADXL377 Schematic & Fabrication Print ©Adafruit Industries Page 17 of 17
很抱歉,暂时无法提供与“1413”相匹配的价格&库存,您可以联系我们找货
