Page 1 of 2
Triple-axis Accelerometer+Magnetometer
(Compass) Board - LSM303
PRODUCT ID: 1120
Page 2 of 2
DESCRIPTION
He told you "Go West, young maker!" - but you don't know which way is West! Ah, if
only you had this triple-axis accelerometer/magnetometer compass module. Inside
are two sensors, one is a classic 3-axis accelerometer, which can tell you which
direction is down towards the Earth (by measuring gravity). The other is a
magnetometer that can sense where the strongest magnetic force is coming from,
generally used to detect magnetic north. By combining this data you can then
orient your project!
We based this breakout on the latest version of this popular sensor, the
LSM303DLHC. This compact sensor uses I2C to communicate and its very easy to
use. Since it's a 3.3V max chip, we added circuitry to make it 5V-safe logic and
power, for easy use with either 3 or 5V microcontrollers. Simply connect VCC to
+3-5V and ground to ground. Then read data from the I2C clock and data pins.
There's also a Data Ready and two Interrupt pins you can use (check the LSM303
datasheet for details)
If using with an Arduino, its extra-easy to get started as we already wrote a nice
little Arduino library to get you started. Simply download our library and connect
the SCL pin to your Arduino's I2C clock pin, and SDA pin to your Arduino's I2C data
pin and upload our test program to read out accelerometer and magnetic field
data.
http://www.adafruit.com/products/1120
7/16/2015
很抱歉,暂时无法提供与“1120”相匹配的价格&库存,您可以联系我们找货
