6 DOF Sensor‐MPU6050 (SKU:SEN0142)
Contents
1 Introduction
2 Specification
3 Connection Diagram
4 Sample Code
Introduction
At the beginning,the inertial measurement unit is an electronic device that measures and reports on
a craft's velocity, orientation, and gravitational forces, using a combination of
accelerometers,gyroscopes, and magnetometers. Now IMUs are commonly used in the Humancomputer interaction(HCI), navigational purposes and balancing technology used in the Segway
Personal Transporter as we all known.
The MPU-6000/MPU-6050 family of parts are the world’s first and only 6-axis MotionTracking
devices designed for the low power, low cost, and high performance requirements of smartphones,
tablets and wearable sensors.
The MPU-6000/6050 devices combine a 3-axis gyroscope and a 3-axis accelerometer on the same
silicon die together with an onboard Digital Motion Processor (DMP) capable of processing complex
9-axis MotionFusion algorithms. The parts’ integrated 9-axis MotionFusion algorithms access
external magnetometers or other sensors through an auxiliary master I2C bus, allowing the devices
to gather a full set of sensor data without intervention from the system processor.
The 6 Dof sensor breakout integrate with the MPU6050 sensor and the low noise 3.3v regulator and
pull-up resistors for the I2C bus. So it's available to directly hook up the sensor with the Arduino
processors for your robotics,HCI and wearable projects. With the Arduino library from i2cdevlib it's
easy for you to drive this sensor and get the pitch,roll,yaw,quaternion,euler data.
Specification
Working voltage: 3~5v
I2C Digital-output of 6 or 9-axis MotionFusion data in rotation matrix, quaternion, Euler Angle, or raw
data format
Tri-Axis angular rate sensor (gyro) with a sensitivity up to 131 LSBs/dps and a full-scale range of
±250, ±500, ±1000, and ±2000dps
Tri-Axis accelerometer with a programmable full scale range of ±2g, ±4g, ±8g and ±16g
Digital Motion Processing (DMP) engine offloads complex MotionFusion, sensor timing
synchronization and gesture detection
Embedded algorithms for run-time bias and compass calibration. No user intervention required
Dimensions: 14 x 21mm
Connection Diagram
Sample Code
Please download the libraries for the all the IMU sensors first!
# Product: 6 DOF Sensor-MPU6050
# SKU
: SEN0142
# Description:
# To read
accel/gyro data from 6 DOF Sensor
#include "Wire.h"
#include "I2Cdev.h"
#include "MPU6050.h"
MPU6050 accelgyro;
int16_t ax, ay, az;
// define accel as ax,ay,az
int16_t gx, gy, gz;
// define gyro as gx,gy,gz
#define LED_PIN 13
bool blinkState = false;
void setup() {
Wire.begin();
// join I2C bus
Serial.begin(38400);
initialize serial communication
Serial.println("Initializing I2C devices...");
accelgyro.initialize();
// verify connection
Serial.println("Testing device connections...");
Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful"
: "MPU6050 connection failed");
pinMode(LED_PIN, OUTPUT);
// configure LED pin
void loop() {
accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
rom device
// display tab-separated accel/gyro x/y/z values
Serial.print("a/g:\t");
Serial.print(ax);
Serial.print("\t");
Serial.print(ay);
Serial.print("\t");
Serial.print(az);
Serial.print("\t");
Serial.print(gx);
Serial.print("\t");
Serial.print(gy);
Serial.print("\t");
Serial.println(gz);
// blink LED to indicate activity
blinkState = !blinkState;
digitalWrite(LED_PIN, blinkState);
Powered By DFRobot © 2008-2017
// read measurements f
很抱歉,暂时无法提供与“SEN0142”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+83.123901+10.10990
- 国内价格 香港价格
- 1+193.961111+23.54920
- 3+170.227863+20.66770
- 国内价格 香港价格
- 1+115.344651+14.00422
- 国内价格
- 1+205.40624
- 2+203.65810
- 3+199.28775
