X000010
X000010
    ARDUINO
    POEMODULE5V
X000010 数据手册
PoE module 5V Model : X000010 Description The AG9605-2BR is a module designed to extract power from a conventional twisted pair Category 5 Ethernet cable, conforming to the IEEE 802.3af Power-over-Ethernet (PoE) standard. AG9605-2BR provides the PoE compatibility signature and power classification required by the Power Sourcing Equipment (PSE) before applying up to 9W power to the port. The high efficiency DC/DC converter operates over a wide input voltage range (36V to 48V typ) and provides a regulated low ripple and low noise output. The DC/DC converter also has built-in overload and short-circuit output protection. Features: IEEE802.3af compliant Small SIL package size - 56mm (L) x 14mm (H) Low output ripple and noise Input voltage range 36V to 57V Overload and short-circuit protection High efficiency DC/DC converter (75% typ) 1500V isolation (input to output) This module could be used ONLY with Arduino Yun (for products Arduino Ethernet shield and Arduino Ethernet please use the X000002 module) http://world.arduino.org/en/poe-module-5
X000010 价格&库存
很抱歉,暂时无法提供与“X000010”相匹配的价格&库存,您可以联系我们找货
