TEACL-USB
TEACL-USB
    FLEXIPANEL
    ADAPTER USB TEACLIPPER
TEACL-USB 数据手册
TEAclipper/PIC™ Firmware delivery for Microchip PIC microcontrollers FlexiPanel Summary TEAclipper/PIC is a portable, target-powered firmware programmer for Microchip’s PIC microcontrollers. About the same weight and size as a nickel (US 5¢ coin), it can be readily transported and plugged in to the PCB or prototyping board containing the PIC requiring programming. TEAclipper/PIC makes it easy to sell code written for PICs and also to deliver updates to products already delivered to customers. Programming a target PCB TEAclipper/PIC Features How It Works TEAclipper/PIC features: The HexWax Explorer application is used to load TEAclippers with firmware, either stored locally or downloaded from www.hexwax.com via the TEAclipper USB adapter.  Support for most 8-bit PICs.  In-the-field reflash for your TEAclippers as we add capability to program other PICs.  High-voltage (Vpp) generator option.  Limited-download feature that counts the number of devices programmed. When the limit is reached the TEAclipper refuses to program any more, allowing firmware to be sold on a per-copy basis  Encrypted delivery secures against copying.  Unique serial numbers and license codes can be written to each PIC programmed.  No other components required for programming. Can connect to the PIC via, for example: - 5 plate-though PCB holes (for light duty use) - 0.1” header (for heavy duty use) - Prototyping board  Powered in-situ by target circuit  TEAclipper USB adapter required for charging TEAclippers with firmware.  Compatible with www.hexwax.com firmware publishing service. Hex File Import locally (.hex) W ax File Encrypted hex Description TEAclipper/PIC high voltage programming clip TEAclipper/PIC low voltage programming clip TEAclipper USB adapter TEAclipper evaluation / test board TEAclipper/PIC debugging adapter FlexiPanel Ltd 2 Marshall St, 3rd Floor London W1F 9BB, UK www.flexipanel.com email: support@flexipanel.com Manufactured to RoHS, WEEE & ISO9001:2001 standards Page 1 13-Jan-08 TEAclipper//PIC DS508-6 Download from www.hexwax.com (.wax) HexW ax Explorer Charge TEAclipper via USB PICs are then programmed by temporarily inserting the TEAclipper into the target device’s circuit. The connection can be a PCB header or simply leaning against plate-through holes on a PCB. For prototyping, TEAclippers can be inserted into breadboards. Applications  Firmware programming & archiving  Firmware sales through physical dispatch of TEAclippers to customers  Protection from design theft by subcontractors  Delivery of in-the-field firmware updates for already-deployed products. Costs nothing to implement at product design-time.  Firmware sales through web marketing by www.hexwax.com, FlexiPanel’s firmware publishing service. Ordering Information Part No TEACL-PIC-H TEACL-PIC-L TEACL-USB EVAL-TEACL TEACL-PIC-DB stored file TEAclipper system TEAclipper/PIC is part of the FlexiPanel TEAclipper system, which provides:  TEAleaf authentication tags  TEAclippers for Microchip PICs and Parallax BASIC Stamps available now.  Planned rollout for major microcontroller, CPLD, FPGA brands. (Manufacturers should contact us to schedule TEAclipper support for their products.) © FlexiPanel Ltd Patents pending www.FlexiPanel.com Loading Firmware onto the TEAclipper To load a TEAclipper with a firmware data payload, start the HexWax Explorer application (downloaded from www.hexwax.com). Import the .hex or .wax file containing the firmware you want into the Local Files section of HexWax Explorer. To import local files held on your computer, press the Add… button. To import files from HexWax, navigate to the firmware you want and press the Click To Download button in the browser area. Insert the TEAclipper into the TEAclipper USB adapter. The LEDs should be face upwards, although you will not damage the TEAclipper if you insert it incorrectly. Select the .hex or .wax file you wish to load and press the Charge Now… button. The Charge TEAclipper PIC dialog will appear: When the TEAclipper attempts to write the dummy values, it will substitute the serialization values. The values can be stored directly or as literals in RETLW instruction (i.e. in the same manner as the Microchip PM3 SQTP facility programmer). Fixed: A fixed value of up to 4 bytes (Stamps) or 16 bytes (PICs) to each target during programming. This option requires limited discharge to be enabled. Random: A random value of up to 16 bytes to each target during programming. This option requires limited discharge to be enabled. Increment: An incrementing value of up to 4 bytes (Stamps) or 16 bytes (PICs) to each target during programming. This option requires limited discharge to be enabled. The value is written little-endian, i.e. least significant byte first. Note that PIC increments do not carry beyond the fourth byte. Limited Discharge: Allows you to limit the number of discharges of the payload for licensing purposes. Note that each 16 discharges will require an erase cycle. Payload name: This name will appear in the Explorer view Payload information area when the TEAclipper is inserted into the TEAclipper USB adapter. Version number: If non-zero, this version number will appear in the Explorer view Payload information area when the TEAclipper is inserted into the TEAclipper USB adapter. The value is a two-byte hex number. You will be given the following options: Target PIC: Specifies the type of PIC for which the hex data is intended. This information is not contained in .hex files and so must be specified here. It is not always possible to cross-check that the PIC type is correct, so be careful to set it correctly. Either high-voltage or low-voltage programming may be specified, depending on the target device. Some PICs require high-voltage (7V-13V) programming; others require low-voltage programming; some may be programmed by either method. High-voltage programming is only possible using TEAclippers incorporating high-voltage generator components. If low-voltage programming is specified, there may be a supply voltage minimum below which bulk erase operations cannot be performed. Programming is only possible below this limit with high voltage erase. LF series devices identical to F series are identical to F series devices, e.g. PIC18LF4520 is the same as PIC18F4520, except that LF series devices may be operated at lower voltage. To specify an LF device, simply specify its F series equivalent. Serialization: Serialization options allow you to set certain memory locations to unique values. The memory locations may not cross a page write-byte boundary and must be word aligned. Dummy values must be declared in the source code for these locations. Page 2 13-Jan-08 TEAclipper//PIC DS508-6 URL: The URL which will be navigated to when the TEAclipper is inserted into the TEAclipper USB adapter and the Lookup button is pressed. After Programming: Specify whether the TEAclipper should hold the target in a reset state until it is removed, or whether to tri-state immediately and allow the target to execute. Security Options: Specify whether or not the serialization information can be read out of the TEAclipper. Checksums: The checksums are a shorthand method of verifying that you have the correct payload and dialog settings. (They are not the same checksums as used by MPLAB.) Preserve / Authenticate: You have the options of leaving certain areas of ROM or EEPROM unchanged during programming (preserve), or of only programming if the ROM or EEPROM locations match the values specified in the hex file (authenticate). The first of these options is useful if you wish to leave serial numbers, MAC addresses, calibration data unchanged. The second is useful when upgrading to ensure that the right target device is being upgraded. Note for 10F, 12F and 16F devices, two bytes are used for each 12-bit or 14-bit ROM location and each 8-bit EEPROM location. Addresses are specified in bytes, so address values and lengths may be double what you would expect. Dummy values must be declared in the source code for the preserve / authenticate memory locations. © FlexiPanel Ltd Patents pending www.FlexiPanel.com Preserve / Authenticate of code protected ROM is not possible. Override High Voltage Defaults: Voltage Programming section below. Refer to High Embed Settings: Writes settings to hex file so if another user opens the file, it will default to the settings selected. HexWax Explorer may also be used to determine the payload currently resident on a TEAclipper. When you insert it into TEAclipper USB, HexWax Explorer will display information about the resident firmware. Press the Details… button for more information. Refer to the HexWax Explorer HW050 data sheet for more information about the software. Note: High Voltage TEAclipper/PICs with the marking TCPr3 need a few moments to discharge in order to reset properly. After loading the firmware onto the PIC, you may need to remove it for about 5 seconds and then re-insert it. connections to an RJ11 socket. This is designed for development and debugging of applications using the Microchip ICD2 In-Circuit Debugger. Pinout Table Pin 1 2 3 4 5 Name Description Vdd Power input Vmin – 5.5V DC† PGD Program data (Bidirectional) PGC Program clock (Output) Vpp/NMCLR Programming voltage / reset (Output ) Vss Power Ground reference † Refer to Compatibility Chart for Vmin values Specifications Voltage on Vdd Vmin – Vmax DC † Current, low voltage programming 10mA max Current, high voltage programming 80mA max Maximum erase cycles 100 Maximum high volt current IVpp 1mA † Refer to Compatibility Chart for Vmin and Vmax values Mechanical Drawing Programming PICs To discharge the payload data into a PIC, connection must be made as detailed in the Pinout Table. A PCB header or series of plate-though holes is usually provided on a target PCB for programming. Payloads can be set for limited discharge, in which case they can only program a limited number of PICs. The TEAclipper has a limited life due to the low-cost nature of the flash memory used. It can be reloaded with firmware a maximum of 100 times. In addition, if the limited-download or serialization features are used, the total maximum number of downloads is 1600. Red & Green LED Indicator Guide Red & Grn on continuously Red & Grn flash every 2s Alternate Red & Grn Occulting Green 2 Red flashes 3 Red flashes 4 Red flashes 5 Red flashes 6 Red flashes 8 Red flashes Initializing Connected to HexWax Explorer Programming PIC Programming complete PIC not found Authenticate failure Erase limit reached Limited discharge limit reached No payload to discharge Program verify failure Evaluation and Development Guide To experiment with TEAclippers, try downloading the Eval1 and Eval2 firmware files from www.hexwax.com. They don’t do much – flash LEDs once and twice respectively on P0 and P1 – but they are enough for you to become familiar with how TEAclippers are used. You’ll find them by visiting the Products section of the web site and downloading the PICeval pack. Target Board Design Guide When designing a PCB to facilitate frequent in-circuit programming of PICs, a five pin 0.1” header socket should be provided. For compact PCBs, it may be necessary to devise an adapter cable. If it is anticipated that the board will only need to be programmed once or twice in its lifetime, and the PIC is small enough that the programming duration is quite short, leaning the TEAclipper against five plate-through holes will be sufficient. A TEAclipper Evaluation Board is available. It includes zero-insertion-force test sockets which may be useful for programming a large quantity of PICs The TEAclipper/PIC Debugging adapter is available which translates the TEAclipper programming Page 3 13-Jan-08 TEAclipper//PIC DS508-6 © FlexiPanel Ltd Patents pending www.FlexiPanel.com Pin 1 indicated by square pad locations specified. Bits 16 and higher of the preserve / authenticate location address will be ignored. 2.54mm spacing 1mm hole dia Vss NMCLR PGC PGD Vdd Recommended plate-through connector design Since the plate-through connector costs nothing, it’s worth integrating it in every PIC PCB you design, just in case you might want to use it to update the firmware at a later date. If any of the Vpp, PGC or PGD pins serve another purpose in the circuit, these connections must be isolated so that they do not interfere with, nor are affected by, the programming process. Capacitance on these connections should be sufficiently low to allow digital transitions of up to 1MHz in frequency. If implementing Low-Voltage Programming, consider the requirements for the PGM pin as detailed below in the Low-Voltage Programming section. We typically implement a 4k7 pull-down resistor and a pair of colocated pads, one on either side of the board near the edge, which allow the PGM pin to be temporarily shorted high using a crocodile clip. File Formats PIC firmware must be in INHX32 32-bit Intel Extended Hex format. (This is the standard .hex file format generated by MPLAB.) Any EEPROM or configuration data must be embedded in the hex file. Configuration, ID and EEPROM data must be embedded in the hex data as recommended by Microchip programming specifications. Refer to the evaluation applications’ source code for examples. Large Hex Images Hex images greater than 64Kbyte. require one TEAclipper per 64Kbyte or part thereof. Each TEAclipper will program a separate 64K section of memory. The TEAclippers should be numbered TC1, TC2, etc. During programming, they must be applied in the order in which they are numbered. TC1 will erase the microcontroller and program the highest memory locations. The ‘last’ (i.e. highest numbered) TEAclipper will program the lowest memory locations, EEPROM, ID locations and configuration bits. The following restrictions apply:  The memory is not code protected prior to the use of the last TEAclipper.  Serialization values must reside in the lowest 64K of memory.  Authenticate may only be used on TC1.  Preserve and authenticate should only be specified on the TEAclipper which programs the Page 4 13-Jan-08 TEAclipper//PIC DS508-6  Only the ‘last’ TEAclipper is limited-write. If the firmware is paid-for, this is the TEAclipper which holds financial value.  TEAclippers other than the ‘last’ are unlimited write and the payload has no financial value. Low-Voltage Programming Some PIC devices implement low voltage programming using a PGM pin. The pin is pulled low during normal use. When the TEAclipper is to be used to program the device, a specific sequence of actions needs to be followed: 1. Ensure no power is applied to the target PCB 2. Connect the PGM pin so it will be pulled high when power is applied 3. Insert the TEAclipper 4. Power up the board 5. Wait for programming to complete. 6. Power down the board 7. Remove the TEAclipper 8. Disconnect the pull-up on the PGM pin Note that for some LF parts, there is a minimum supply voltage below which low voltage programming is not permitted. High-Voltage Programming High voltage programming is only possible with TEAclippers which include the high voltage programming option. This option uses switched-mode boost generator to provide required Vpp programming voltage. The boost generator performance is governed by two parameters. The Precharge time governs the voltage at the instant the high voltage is applied. The PWMonTime governs the asymptotic voltage level. The default Precharge and PWMonTime values assume a 10K-22K pullup resistor to Vdd. This is the recommended load and should be suitable for most circuits. A very weak pullup may result in overvoltage; too strong a voltage may result in undervoltage. In cases of abnormal loads on Vpp, it is possible to override Precharge and PWMonTime in HexWax Explorer. A test mode is also provided, where a Vpp square wave is output at 25Hz approx. The aim is to enter programming mode with a voltage Vpp inside the range specified in the device’s programming specification. Security TEAclippers can be used to buy and sell firmware on a per-copy basis. The degree of security offered by © FlexiPanel Ltd Patents pending www.FlexiPanel.com TEAclipper/PIC varies with the type of PIC that can be programmed. On 10F, 12F, 16F, 18F, PIC24H, dsPIC30F and dsPIC33F devices, the code protection bit is set when programming is complete. If programming is interrupted the device remains in an unprotected state. They are recommended for use only in trusted environments or with low-valued firmware On 18FJ and PIC24FJ devices, the code protection bit is set when programming begins. The only way to read the devices is to decrypt the programming signals. They are much more tightly protected and are suitable for medium-valued firmware. The TEAclipper/Crypto product uses a decrypting bootloader to transfer data from the TEAclipper. It may be used with any microcontroller (PIC or not) which has self-write capability. There is no known way to intercept these programming signals. This product is recommended for the highest valued firmware, e.g. gaming systems, banking, etc. Copyright TEAclippers can be used as a licensing system to allow firmware to be bought and sold. When used in this way, trade is protected by the WIPO Copyright Treaty and the Digital Millennium Copyright Act. The following are punishable by fines or imprisonment: - Any attempt to interfere with the programming process or intercept or record or reproduce the programming signals - Any attempt to disseminate unlicensed copies of firmware carried by TEAclippers Page 5 13-Jan-08 TEAclipper//PIC DS508-6 © FlexiPanel Ltd Patents pending www.FlexiPanel.com Compatibility Chart The PICs listed below are currently compatible with TEAclipper. We intend to prioritize the addition of further PIC devices according to customer demand, so let us know what you need. HexWax Explorer is able to reflash the firmware in the TEAclippers, so as we enhance the product your existing TEAclippers are updated automatically. Our intention is to support as many 8-bit and 16-bit PICs as possible in due course. Testing new devices is labor intensive and so support will be progressive. Contact us if there is a particular PIC you would like prioritized. Note that many PICs are near-identical siblings. We do not test all members of the family. Devices marked * are family members which have been tested exhaustively. Devices marked † have been tested, but less exhaustively. These devices have corresponding evaluation and test files available for download from www.HexWax.com. To create evaluation and test files for other devices, simply recompile a test file with the same programming specification, setting the target to the desired microcontroller. Except where listed separately, ‘LF’ series parts are considered identical to their ‘F’ series equivalents, except that different supply voltages apply. Some devices have a minimum permitted supply voltage as indicated. Vmin is the minimum supply voltage shown permitted during programming (assuming an LF part where applicable.) Target PIC10F200 PIC10F202 PIC10F204 PIC10F206 PIC10F220 PIC10F222 PIC12F508 PIC12F509 PIC12F510 PIC12F615 PIC12HV615 PIC12F629 PIC12F635 PIC12F675 PIC12F683 PIC16F616 PIC16HV616 PIC16F630 PIC16F630-ICD PIC16F631 PIC16F636 PIC16F639 PIC16F676 PIC16F677 PIC16F684 PIC16F685 PIC16F687 PIC16F688 PIC16F689 PIC16F690 PIC16F73 PIC16F74 Page 6 Prog Spec Test Dev F F F F V V Y Y G X X Z W Z W X X Z Z W W W Z W W W W W W W Q Q 13-Jan-08 * * * * * * * * * * * From Version 1.00 1.00 1.00 1.00 1.00 1.00 1.36 1.36 1.36 1.36 1.36 1.36 1.36 1.36 1.36 1.36 1.36 1.36 1.36 1.36 1.36 1.36 1.36 1.36 1.36 1.36 1.36 1.36 1.36 1.36 1.37 1.37 Page write bytes High/Low Volt Prog Vmin (HVP / LVP) HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP HVP 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.75 4.75 TEAclipper PIC DS508-6 Serialization values may not cross the page write memory boundaries specified. The high voltage TEAclipper is capable of both high and low voltage programming. The low voltage TEAclipper is only capable of low voltage programming. Target PIC16F76 PIC16F77 PIC16F737 PIC16F747 PIC16F767 PIC16F777 PIC16F818 PIC16F819 PIC16F87 PIC16F870 PIC16F871 PIC16F872 PIC16F873 PIC16F874 PIC16F874A PIC16F875 PIC16F875A PIC16F876 PIC16F876A PIC16F877 PIC16F877A PIC16F88 PIC16F882 PIC16F883 PIC16F884 PIC16F886 PIC16F887 PIC18F1220 PIC18F1230 PIC18F1320 PIC18F1330 PIC18F2220 © FlexiPanel Ltd Prog Spec Q Q A2 A2 A2 A2 J J Q2 S2 S2 S2 S2 S2 R2 S2 R2 S2 R2 S2 R2 Q2 M M M M M J2 G2 J2 G2 J2 Test Dev * * * * * * * From Version 1.37 1.37 1.40 1.40 1.40 1.40 1.34 1.34 1.39 1.35 1.35 1.35 1.35 1.35 1.35 1.35 1.35 1.35 1.35 1.35 1.35 1.39 1.39 1.39 1.39 1.39 1.39 1.10 1.30 1.10 1.30 1.10 Patents pending Page write bytes 8 8 8 8 8 High/Low Volt Prog Vmin (HVP / LVP) HVP HVP HVP HVP HVP HVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP HVP / LVP HVP HVP / LVP 4.75 4.75 4.75 4.75 4.75 4.75 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 4.50 2.00 / 4.50 3.00 2.00 / 4.50 4.50 2.00 / 4.50 www.FlexiPanel.com Target PIC18F2221 PIC18F2320 PIC18F23K20 PIC18F2321 PIC18F2331 PIC18F2410 PIC18F242 PIC18F2420 PIC18F24K20 PIC18F2431 PIC18F2450 PIC18F2455 PIC18F248 PIC18F2480 PIC18F2510 PIC18F2515 PIC18F252 PIC18F2520 PIC18F25K20 PIC18F2525 PIC18F2550 PIC18F258 PIC18F2580 PIC18F2585 PIC18F2610 PIC18F2620 PIC18F26K20 PIC18F2680 PIC18F2682 PIC18F2685 PIC18F4220 PIC18F4221 PIC18F4320 PIC18F43K20 PIC18F4321 PIC18F4331 PIC18F4410 PIC18F442 PIC18F4420 PIC18F44K20 PIC18F4431 PIC18F4450 PIC18F4455 PIC18F4480 PIC18F448 PIC18F4510 PIC18F4515 PIC18F452 PIC18F4520 PIC18F45K20 PIC18F4525 PIC18F4550 PIC18F458 Page 7 Prog Spec Test Dev A J2 K A Y2 A N A K Y2 A A N A A A N A K A A N A A A A K A A A J2 A J2 K A Y2 A N A K Y2 A A A N A A N A K A A N 13-Jan-08 * * * † * * * * * * * * From Version 1.00 1.10 1.32 1.00 1.10 1.00 1.41 1.00 1.32 1.10 1.00 1.00 1.41 1.00 1.00 1.00 1.41 1.00 1.32 1.00 1.00 1.41 1.00 1.00 1.00 1.00 1.32 1.00 1.00 1.00 1.10 1.00 1.10 1.32 1.00 1.10 1.00 1.41 1.00 1.32 1.10 1.00 1.00 1.00 1.41 1.00 1.00 1.41 1.00 1.32 1.00 1.00 1.41 Page write bytes 8 8 8 8 8 32 8 32 32 8 16 32 8 32 32 64 8 32 32 64 32 8 32 64 64 64 64 64 64 64 8 8 8 8 8 8 32 8 32 32 8 16 32 32 8 32 16 8 32 32 64 32 8 High/Low Volt Prog Vmin (HVP / LVP) HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP 2.00 / 3.00 2.00 / 4.50 TBD 2.00 / 3.00 2.00 / 4.50 2.00 / 3.00 2.00 / 4.50 2.00 / 3.00 TBD 2.00 / 4.50 2.00 / 3.00 2.00 / 3.00 2.00 / 4.50 2.00 / 3.00 2.00 / 3.00 2.00 / 3.00 2.00 / 4.50 2.00 / 3.00 TBD 2.00 / 3.00 2.00 / 3.00 2.00 / 4.50 2.00 / 3.00 2.00 / 3.00 2.00 / 3.00 2.00 / 3.00 TBD 2.00 / 3.00 2.00 / 3.00 2.00 / 3.00 2.00 / 4.50 2.00 / 4.50 2.00 / 4.50 TBD 2.00 / 3.00 2.00 / 4.50 2.00 / 3.00 2.00 / 4.50 2.00 / 3.00 TBD 2.00 / 4.50 2.00 / 3.00 2.00 / 3.00 2.00 / 3.00 2.00 / 4.50 2.00 / 3.00 2.00 / 3.00 2.00 / 4.50 2.00 / 3.00 TBD 2.00 / 3.00 2.00 / 3.00 2.00 / 4.50 TEAclipper PIC DS508-6 Target PIC18F4580 PIC18F4585 PIC18F4610 PIC18F4620 PIC18F46K20 PIC18F4680 PIC18F4682 PIC18F4685 PIC18F6310 PIC18F6390 PIC18F6410 PIC18F6490 PIC18F6520 PIC18F6527 PIC18F6620 PIC18F6622 PIC18F6627 PIC18F6680 PIC18F6685 PIC18F6720 PIC18F6722 PIC18F8310 PIC18F8390 PIC18F8410 PIC18F8490 PIC18F8520 PIC18F8527 PIC18F8620 PIC18F8622 PIC18F8627 PIC18F8680 PIC18F8685 PIC18F8720 PIC18F8722 PIC18F24J10 PIC18F25J10 PIC18F44J10 PIC18F45J10 PIC18LF24J10 PIC18LF25J10 PIC18LF44J10 PIC18LF45J10 PIC18F63J11 PIC18F63J90 PIC18F64J11 PIC18F64J90 PIC18F65J10 PIC18F65J11 PIC18F65J15 PIC18F65J50 PIC18F65J90 PIC18F66J10 PIC18F66J11 © FlexiPanel Ltd Prog Spec Test Dev From Version A A A A K A A A P P P P N2 H2 N2 H2 H2 L L N2 H2 P P P P N2 H2 N2 H2 H2 L L N2 H2 B B B B B B B B U U U U U U U U U U U * * * * 1.00 1.00 1.00 1.00 1.32 1.00 1.00 1.00 1.10 1.10 1.10 1.10 1.41 1.10 1.41 1.10 1.10 1.32 1.32 1.41 1.10 1.10 1.10 1.10 1.10 1.41 1.10 1.41 1.10 1.10 1.32 1.32 1.41 1.10 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 * * * * * * Patents pending Page write bytes 32 64 64 64 64 64 64 64 16 16 16 16 8 64 8 64 64 8 8 8 64 16 16 16 16 8 64 8 64 64 8 8 8 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 High/Low Volt Prog Vmin (HVP / LVP) HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP HVP HVP HVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP HVP HVP HVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP HVP / LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP 2.00 / 3.00 2.00 / 3.00 2.00 / 3.00 2.00 / 3.00 TBD 2.00 / 3.00 2.00 / 3.00 2.00 / 3.00 4.50 4.50 4.50 4.50 2.00 / 4.50 4.50 2.00 / 4.50 4.50 4.50 4.50 4.50 2.00 / 4.50 4.50 4.50 4.50 4.50 4.50 2.00 / 4.50 4.50 2.00 / 4.50 4.50 4.50 4.50 4.50 2.00 / 4.50 4.50 3.60 3.60 3.60 3.60 3.60 3.60 3.60 3.60 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 www.FlexiPanel.com Target PIC18F66J15 PIC18F66J16 PIC18F66J50 PIC18F66J55 PIC18F67J10 PIC18F67J11 PIC18F67J50 PIC18F83J11 PIC18F83J90 PIC18F84J11 PIC18F84J90 PIC18F85J10 PIC18F85J11 PIC18F85J15 PIC18F85J50 PIC18F85J90 PIC18F86J10 PIC18F86J11 PIC18F86J15 PIC18F86J16 PIC18F86J50 PIC18F86J55 PIC18F87J10 PIC18F87J11 PIC18F87J50 Spec A A2 B F G G2 H2 J J2 K L M Page 8 Prog Spec Test Dev From Version U U U U U U U U U U U U U U U U U U U U U U U U U † 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 * Page write bytes 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 High/Low Volt Prog Vmin (HVP / LVP) LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP LVP 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 Programming specification notes Notes Based on Microchip’s data sheet DS39622 PIC18F2XX0/2X21/2XX2/2XX3/2XX5/4XX0/4X21/4XX2/4XX3/4XX5 Based on Microchip’s data sheet DS30492 PIC16F7X7 ID locations programming not implemented Verifies memory locations with VddApp = target Vdd (refer to data sheet) Based on Microchip’s data sheet DS39687 PIC18F45J10 Family Based on Microchip’s data sheet DS41228 PIC10F200/202/204/206 ID locations programming not implemented If Oscillator Calibration Bits (0x0FF / 0x1FF) do not contain a valid MOVLW instruction prior to programming, an MOVLW 0xFE instruction will be inserted Based on Microchip’s data sheet DS41257 PIC12F510 ID locations programming not implemented If Oscillator Calibration Bits (0x3FF) do not contain a valid MOVLW instruction prior to programming, an MOVLW 0x80 instruction will be inserted Based on Microchip’s data sheet DS39752 PIC18F1230/1330 Based on Microchip’s data sheet DS39643 PIC18F8722 Family Based on Microchip’s data sheet DS39603 PIC16F818/819 ID locations programming not implemented Based on Microchip’s data sheet DS39592 PIC18FX220/X320 Based on Microchip’s data sheet DS39606 PIC18F2XK20/4XK20 Problems may exist programming EEPROM. Contact us if you have difficulties. Based on Microchip’s data sheet DS39606 PIC18FXX80/XX85 Based on Microchip’s data sheet DS41287 PIC16F88X ID locations programming not implemented 13-Jan-08 TEAclipper PIC DS508-6 Spec N N2 P Q Q2 R2 S2 U V W X Y Y2 Z © FlexiPanel Ltd Programming specification notes Notes Verifies memory locations with VddApp = target Vdd (refer to data sheet) Based on Microchip’s data sheet DS39576 PIC18FXX2/XX8 Based on Microchip’s data sheet DS39583 PIC18FXX20 Based on Microchip’s data sheet DS39624 PIC18FX310/X410/X390/X490 The specification implies ability to program down to Vmin = 2.75V but we have not been able to achieve this. Please let us know if you are able to. Based on Microchip’s data sheet DS30324 PIC16F7X ID locations programming not implemented Verifies memory locations with VddApp = target Vdd (refer to data sheet) Based on Microchip’s data sheet DS39607 PIC16F87/88 ID locations programming not implemented Verifies memory locations with VddApp = target Vdd (refer to data sheet) Based on Microchip’s data sheet DS39589 PIC16F87XA ID locations programming not implemented Based on Microchip’s data sheet DS39025 PIC16F87X ID locations programming not implemented Based on Microchip’s data sheet DS39644 PIC18F6XJXX/8XJXX Family Based on Microchip’s data sheet DS41266 PIC10F220/222 ID locations programming not implemented If Oscillator Calibration Bits (0x0FF / 0x1FF) do not contain a valid MOVLW instruction prior to programming, an MOVLW 0xFE instruction will be inserted Based on Microchip’s data sheet DS41204 PIC12F6XX/PIC16F6XX ID locations programming not implemented Based on Microchip’s data sheet DS41284 PIC12F61X/PIC16F61X ID locations programming not implemented Based on Microchip’s data sheet DS41221 PIC12F508/509 ID locations programming not implemented If Oscillator Calibration Bits (0x1FF / 0x3FF) do not contain a valid MOVLW instruction prior to programming, an MOVLW 0x80 instruction will be inserted Based on Microchip’s data sheet DS30500 PIC18F2331/2431/4331/4431 Based on Microchip’s data sheet DS41191 PIC12F629/675/PIC16F630/676 ID locations programming not implemented Patents pending www.FlexiPanel.com
TEACL-USB 价格&库存
很抱歉,暂时无法提供与“TEACL-USB”相匹配的价格&库存,您可以联系我们找货
