1665
    ADAFRUIT
    ROUND SPACER #10 BRASS 5/8"
1665 数据手册
Sign In SHOP BLOG LEARN FORUMS 0 Items   VIDEOS CABLES / CABLE ASSEMBLIES / 6-PIN JST SM PLUG + RECEPTACLE CABLE SET 6-pin JST SM Plug + Receptacle Cable Set PRODUCT ID: 1665 IN STOCK ADD TO CART 1 1-9 10-99 100+ ADD TO WISHLIST DESCRIPTION TECHNICAL DETAILS DESCRIPTION These 6-wire cables are 162mm (6.4") long and come as a set. One cable has a JST SM type connector plug on the end. The other cable has a matching JST SM type receptacle connector. They are good for whenever you have 6 wires you want to be able to plug and unplug. We like the solid and compact nature of these connectors and the latch that keeps the cable from coming apart easily. For more information, check the JST SM connector datasheet Each order receives one of each connector. Wires are 22 American wire gauge. New Products 4/30/2014 TECHNICAL DETAILS JST SM plug + receptacle connector: JST SM connector datasheet Length: 162mm / 6.4" Weight (female / male): 5.1g / 5.6g MAY WE ALSO SUGGEST... 4-pin JST SM Plug + Receptacle Cable Set JST PH 2-Pin Cable Female Connector 100mm 4-pin AT/ATX/IDE power cable JST-PH Battery Extension Cable - 500mm In-line power cable 1 meter long extension cord (for EL Terminal block - 4 pin EuroStyle 3-pin JST SM Plug + Receptacle Cable Set JST PH 3-Pin to Male Header Cable - 200mm 5-pin JST SM Plug + Receptacle Cable Set JST PH 3-Pin to Female Socket Cable - 200mm 2-pin JST SM Plug + Receptacle Cable Set JST 2-pin Extension Cable with On/Off Switch - JST DISTRIBUTORS EXPAND TO SEE DISTRIBUTORS CONTACT SUPPORT DISTRIBUTORS "If you want to build a ship, don’t drum up people to collect wood and don’t assign them tasks and work, but rather teach them to long for the endless immensity of the sea" - Antoine de Saint-Exupéry EDUCATORS JOBS FAQ SHIPPING & RETURNS TERMS OF SERVICE PRIVACY & LEGAL ABOUT US ENGINEERED IN NYC Adafruit ® 4.9
很抱歉,暂时无法提供与“1665”相匹配的价格&库存,您可以联系我们找货
    • 250+13.12191
