3187
    ADAFRUIT
    WASHER FLAT 3/8 FIBRE
3187 数据手册
SmartiPi Touch - Stand for Raspberry Pi 7" Touchscreen Display PRODUCT ID: 3187 Description Here is an excellently designed stand that provides a sleek and sturdy look for the 7" Touchscreen Display and Raspberry Pi. Say hello to the SmartiPi Touch. The 7" Display is secured into the case with four screws and the Raspberry Pi is enclosed in the compartment on the back of the case. A simple door covers the Pi in the compartment allowing for the display ribbon cable to connect to the Raspberry Pi DSI port.  You can power the display 2 ways - by either running two jumper wires from the raspberry Pi GPIO (will conflict with HATs) or using separate micro USB cables (or splitter cable) to power the Pi and display independently. Features: Compatible with Raspberry Pi 3, 2, B+, and A+ 125° smooth pivot that allows you to adjust the angle of the screen HAT boards can be attached to the back of the case, adding even more functionality 3D printable accessories for additional customization  LEGO compatible camera case that works with Pi camera version 1 and 2 Please note: The 7" Touchscreen Display and Raspberry Pi are not included. The HDMI port on the Raspberry Pi is not accessible when enclosed. Technical Details Product Dimensions: 220.0mm x 133.0mm x 37.0mm / 8.7" x 5.2" x 1.5" Product Weight: 221.2g / 7.8oz Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3187”相匹配的价格&库存,您可以联系我们找货
