P0006
P0006
    TERASIC(友晶科技)
    BOARD ADAPTER THDB-SUM
P0006 数据手册
Terasic THDB-SUM THDBHDB-SUM Terasic HSMC to Santa Cruz Daughter Board User Manual Document Version 1.3 JULY. 29, 2009 by Terasic Introduction Page Index INTRODUCTION................................................................................................................................................................................. 1 1.1 FEATURES ........................................................................................................................................................................... 1 1.2 GETTING HELP .................................................................................................................................................................... 2 ARCHITECTURE ................................................................................................................................................................................ 3 2.1 LAYOUT AND COMPONETS .................................................................................................................................................. 3 2.2 BLOCK DIAGRAM................................................................................................................................................................. 5 BOARD COMPONENTS ................................................................................................................................................................... 6 3.1 THE HSMC CONNECTOR ................................................................................................................................................... 6 3.2 SANTA CRUZ CONNECTOR ............................................................................................................................................... 10 3.3 USB ON-THE-GO TRANSCEIVER ..................................................................................................................................... 14 3.4 MICTOR CONNECTOR ....................................................................................................................................................... 16 3.5 SD CARD INTERFACE ....................................................................................................................................................... 18 3.6 SMA CONNECTOR ............................................................................................................................................................ 19 3.7 I2C SERIAL EEPROM ..................................................................................................................................................... 20 3.8 POWER SUPPLY ................................................................................................................................................................ 21 DEMONSTRATION .......................................................................................................................................................................... 22 4.1 CONNECTING THDB-SUM BOARD TO CYCLONE III START BOARD ............................................................................... 22 APPENDIX ......................................................................................................................................................................................... 24 5.1 REVISION HISTORY ........................................................................................................................................................... 24 5.2 ALWAYS VISIT THDB-SUM W EBPAGE FOR NEW MAIN BOARD ...................................................................................... 24 ii Introduction 1 Introduction THDB-SUM (HSMC to Santa Cruz / USB / Mictor Daughter Board) is an adapter board to convert High Speed Mezzanine Connector (HSMC) interface to Santa Cruz (SC), USB, Mictor, and SD Card interface. It allows users to use these interface on a host board with a HSMC connector. Because of limited I/O numbers of the HSMC interface, the SC interface and USB port have to share the same I/O pins. Users can choose which interface to be enabled by jumper selection. Finally, the source signals from the HSMC interface to the SC header on the THDB-SUM board will be passed through level shifters to adjust the logic level difference between the HSMC and SC interface board. 1.1 Features Figure 1.1 shows the photo of the THDB-SUM board. The important features are listed below: • One HSMC connector for interface conversion • One Santa Cruz interface • Adjustable logic levels between HSMC and SC interface signals • One Hi-Speed USB On-The-Go transceiver • One Mictor Connector • One SMA Connector for external clock input • One SD Card Socket Figure 1.1. The THDB-SUM board 1 Introduction 1.2 Getting Help Here are some places to get help if you encounter any problem:  Email to support@terasic.com  Taiwan & China: +886-3-550-8800  Korea : +82-2-512-7661  Japan: +81-428-77-7000 2 Architecture 2 Architecture This chapter describes the architecture of the THDB-SUM board including its PCB and block diagram. 2.1 Layout and Componets The picture of the TDRB-SUM board is shown in Figure 2.1 and Figure 2.2. It depicts the layout of the board and indicates the location of the connectors and key components. HSMC Logical Level Configuration Header (JP3) Mini USB AB type receptacle connector (J8) USB Host/Peripheral Mode Configuration Header(JP2) JTAG TDI/TDO Loopback Header (JP0) USB On-The-Go transceiver (U11) Santa Cruz Connector (J3) EEPROM(U10) Bus Switch (U1~U2) SMA Connector (J6) Level Shifters (U7~U8) Santa Cruz Connector (J5) Level Shifters (U3~U6) Mictor Connector (J2) Santa Cruz Connector (J4) USB/SC Function Select Header (JP1) SC Connector Logical Level Configuration Header (JP3) Figure 2.1. The THDB-SUM PCB and component diagram 3 Architecture HSMC Connector (J1) SD Card Socket (J7) Figure 2.2. The THDB-SUM Back side – HSMC connector view The following components are provided on the THDB-SUM board : • HSMC expansion connector (J1) • Santa Cruz Headers(J3,J4,J5) • Mictor connector (J2) • SMA connector (J6) • Hi-Speed USB On-The-Go transceiver (U11) o Fully compliant with Universal Serial Bus Specification Rev. 2.0 o Supplement to the USB 2.0 Specification Rev. 1.3 o Supplement UTMI+ Low Pin Interface (ULPI) Specification Rev. 1.1 • Mini USB AB type receptacle connector(J8) • Logic level configuration headers (JP3,JP4) • SD Card socket(J7) • I2C serial EEPROM (U10) • Level translator (U3~U9) • Bus Switches (U1~U2) 4 Architecture 2.2 Block Diagram Figure 2.3 shows the block diagram of the THDB-SUM board THDB-SUM HSMC Connector Level Shift Bus Switch To HSMC Interface Host Board SD Card Interface SC Interface USB Interface Level Shift Santa Cruz Connector USB Transceiver SD Card Socket Mictor Connector Interface Mictor Connector External Clock Input SMA Connector I2C Interface I2C Serial EEPROM Figure 2.3. The block diagram of the THDB-SUM board 5 Board Components 3 Board Components This section will describe the detailed information of the components, connector interfaces, and the pin mapping tables of the THDB-SUM board 3.1 The HSMC Connector This section describes the HSMC connector on the THDB-SUM board THDB-SUM board contains an Altera standard HSMC connector. All the other connector interfaces on the THDB-SUM board are connected to the HSMC connector. Figure 3.1, Figure 3.2, and Figure 3.3 show the pin-outs of the HSMC connector. Also, the JTAG interface of the HSMC connector is shown in the Figure 3.4. If users don’t need to use the JTAG interface on the THDB-SUM board, please short the header JP0 to loopback the TDI and TDO signals on the HSMC connector. 6 Board Components NC NC 2 4 1 3 NC NC NC NC 6 8 5 NC 7 NC NC NC 10 12 9 11 NC NC NC NC 14 16 13 NC 15 NC NC 18 NC 20 17 19 NC NC NC NC 22 24 21 NC 23 NC NC 26 NC 28 25 27 NC NC NC NC 30 32 29 31 NC NC HSMC_SCL 34 HSMC_TMS 36 33 35 HSMC_SDA HSMC_TCK HSMC_TDI SD Wpn 38 40 37 39 HSMC_TDO SD DAT1 Figure 3.1. The pin-outs of Bank 1 on the HSMC connector 7 Board Components SD DAT3 SD DAT2 42 44 46 HSPROTO_RESET 48 HSPROTO_IO0 50 52 HSPROTO_IO1 54 HSPROTO_IO2 56 58 HSPROTO_IO3 60 HSPROTO_IO4 62 64 HSPROTO_IO5 66 HSPROTO_IO6 68 70 HSPROTO_IO7 72 HSPROTO_IO8 74 76 HSPROTO_IO9 78 HSPROTO_IO10 80 82 HSPROTO_IO11 84 HSPROTO_IO12 86 88 HSPROTO_IO13 90 HSPROTO_IO14 92 94 EXT_CLK 96 CLK2 98 100 41 43 45 47 49 51 53 55 57 59 61 63 65 67 69 71 73 75 77 79 81 83 85 87 89 91 93 95 97 99 SD_DAT0 SD_CLK SD_CMD HSPROTO_IO40 HSPROTO_IO29 HSPROTO_IO30 HSPROTO_IO31 HSPROTO_IO33 HSPROTO_IO32 HSPROTO_IO35 HSPROTO_IO34 HSPROTO_IO37 HSPROTO_IO36 HSPROTO_IO39 HSPROTO_IO38 HSPROTO_IO15 HSPROTO_IO16 HSPROTO_IO17 OSC CLK1 Figure 3.2. The pin-outs of Bank 2 of the HSMC connector. 8 Board Components MICTOR_D14 MICTOR_D15 12V MICTOR_D16 MICTOR_D17 12V MICTOR_D18 MICTOR_D19 12V MICTOR_D20 MICTOR_D21 12V MICTOR_D22 MICTOR_D23 12V MICTOR_D24 HSPROTO_IO23 12V HSPROTO_IO24 HSPROTO_IO25 12V HSPROTO_IO26 HSPROTO_IO27 12V HSPROTO_CARDSEL HSPROTO_IO28 12V MICTOR_CLK DEV_SEL_R5 0 GND 102 104 106 108 110 112 114 116 118 120 122 124 126 128 130 132 134 136 138 140 142 144 146 148 150 152 154 156 158 160 101 103 105 107 109 111 113 115 117 119 121 123 125 127 129 131 133 135 137 139 141 143 145 147 149 151 153 155 157 159 MICTOR_D0 MICTOR_D1 V C C 33 MICTOR_D4 MICTOR_D5 V C C 33 MICTOR_D2 MICTOR_D3 V C C 33 MICTOR_D6 MICTOR_D13 V C C 33 MICTOR_D12 MICTOR_D11 V C C 33 MICTOR_D10 MICTOR_D9 V C C 33 MICTOR_D8 MICTOR_D7 V C C 33 HSPROTO_IO18 HSPROTO_IO19 V C C 33 HSPROTO_IO20 HSPROTO_IO21 V C C 33 HSPROTO_IO22 TR_CLK V C C 33 Figure 3.3. The pin-outs of Bank 3 of the HSMC connector HSMC_TDI R1 0 MICTOR_TDI HSMC_TDO R2 0 MICTOR_TDO R3 0 NM R4 0 NM HSMC_TDI 1 2 NM:No Mount HSMC_TDI JP0 Open : JTAG Chain Close : JTAG Pass Figure 3.4. The JTAG interface setting of the HSMC connector. 9 Board Components 3.2 Santa Cruz Connector This section describes the Santa Cruz connector on the THDB-SUM board The THDB-SUM board comes with Santa Cruz connectors (J3, J4 and J5) to connect to a daughter board with Santa Cruz interface. On the THDB-SUM, the pin of SC connector not directly connects with HSMC connector. Owing to the limitation of number of HSMC connector I/O pins, SC connector and USB transceiver share some I/O pins together, Please refer to Figure 3.5, those I/O pass through a Bus Switch chip first and then connect with HSMC connector. Therefore users can only choose one function between SC connector and USB transceiver. Users can refer to Table3.1 and use JP2 to choose a function In addition, from the Figure 3.6, there are several level shift chips between HSMC and SC. Theses level shift chips convert the logic levels of the signals between the HSMC and Santa Cruz connectors according to the configurations of the headers (JP3, JP4). With this feature, users can use different I/O standards between the HSMC host board and SC interface daughter board. Table 3.2 and Table 3.3 list the configurations of the voltage level of the HSPROTO_IO BUS and the PROTO_IO BUS, respectively. HSMC Connector (J1) HSPROTO_CARDSEL HSPROTO_IO[40..15] Level Shifters (U3~U8) 27 PROTO_RESET PROTO_CARDSEL PROTO_IO[40..0] 43 Santa Cruz Connectors (J3~J5) SWPROTO_RESET SWPROTO_IO[14..0] HSPROTO_RESET HSPROTO_IO[14..0] 16 16 BUS Switches (U1~U2) USB_D[7..0] USB_CS_n USB_CLKOUT 14 DEV_SEL JP1 Open : USB Close : Santa Cruz USB_STP USB_DIR USB_NXT USB_RESET_n USB OTG Transceiver (U11) Figure 3.5. The I/O distribution of the HSMC, Santa Cruz, and USB transceiver interface. Table 3.1 The configuration of the Enable function on bus switch chip JP1 setting Enable Function Open USB OTC Transceiver Close Santa Cruz conenctor 10 Board Components Open : 3.3V Close : 5V Open : 2.5V Close : 3.3V JP3 JP4 HSMC Connector (J1) VCCA HSPROTO_RESET HSPROTO_CARDSEL HSPROTO_IO[40..0] VCCB Level Shifters (U3~U8) PROTO_RESET PROTO_CARDSEL PROTO_IO[40..0] 43 43 Santa Cruz Connectors (J3~J5) Figure 3.6 The diagram of the logic level transform block Table 3.2 The configuration of the logic level on the HSPROTO_IO BUS JP3 setting Logic level of the HSPROTO_IO BUS Open 2.5V Close 3.3V Table 3.3 The configuration of the logic level on the PROTO_IO BUS JP4 setting Logic level of the PROTO_IO BUS Open 3.3V Close 5V Finally, Figure 3.5 shows the pin-outs of the Santa Cruz connector. Detailed pin mappings between J3, J4, and J5 to the HSMC connector is listed in Table 3.4, Table 3.5, and Table 3.6, respectively. Note: Because of the characteristic of the level translators, the data rate of the HSPROTO_IO and PROTO_IO bus should be under 100 Mbps. 11 Board Components Figure 3.7 Santa Cruz connector pin-outs Table 3.4 The pin assignments of the Santa Cruz connector J3 HSMC Pin SC Pin Number SC Signal Name HSMC Signal Name HSMC Pin Name Number 3 PROTO_IO40 49 HSPROTO_IO40 HSMC_TX_N0 4 PROTO_IO29 53 HSPROTO_IO29 HSMC_TX_P1 5 PROTO_IO30 55 HSPROTO_IO30 HSMC_TX_N1 6 PROTO_IO31 59 HSPROTO_IO31 HSMC_TX_P2 7 PROTO_IO32 65 HSPROTO_IO32 HSMC_TX_P3 8 PROTO_IO33 61 HSPROTO_IO33 HSMC_TX_N2 9 PROTO_IO34 71 HSPROTO_IO34 HSMC_TX_P4 10 PROTO_IO35 67 HSPROTO_IO35 HSMC_TX_N3 11 PROTO_IO36 77 HSPROTO_IO36 HSMC_TX_P5 12 PROTO_IO37 73 HSPROTO_IO37 HSMC_TX_N4 13 PROTO_IO38 83 HSPROTO_IO38 HSMC_TX_P6 14 PROTO_IO39 79 HSPROTO_IO39 HSMC_TX_N5 Table 3.5 The pin assignments of the Santa Cruz connector J4 HSMC Pin SC Pin Number SC Signal Name HSMC Signal Name HSMC Pin Name Number 9 OSC 95 OSC HSMC_CLKOUT_P1 11 CLK1 97 CLK1 HSMC_CLKOUT_N1 13 CLK2 98 CLK2 HSMC_CLKIN_N1 12 Board Components Table 3.6 The pin assignments of the Santa Cruz connector J5 HSMC Pin SC Pin Number SC Signal Name HSMC Signal Name HSMC Pin Name Number 1 PROTO_RESET 48 HSPROTO_RESET HSMC_RX_P0 3 PROTO_IO0 50 HSPROTO_IO0 HSMC_RX_N0 4 PROTO_IO1 54 HSPROTO_IO1 HSMC_RX_P1 5 PROTO_IO2 56 HSPROTO_IO2 HSMC_RX_N1 6 PROTO_IO3 60 HSPROTO_IO3 HSMC_RX_P2 7 PROTO_IO4 62 HSPROTO_IO4 HSMC_RX_N2 8 PROTO_IO5 66 HSPROTO_IO5 HSMC_RX_P3 9 PROTO_IO6 68 HSPROTO_IO6 HSMC_RX_N3 10 PROTO_IO7 72 HSPROTO_IO7 HSMC_RX_P4 11 PROTO_IO8 74 HSPROTO_IO8 HSMC_RX_N4 12 PROTO_IO9 78 HSPROTO_IO9 HSMC_RX_P5 13 PROTO_IO10 80 HSPROTO_IO10 HSMC_RX_N5 14 PROTO_IO11 84 HSPROTO_IO11 HSMC_RX_P6 15 PROTO_IO12 86 HSPROTO_IO12 HSMC_RX_N6 16 PROTO_IO13 90 HSPROTO_IO13 HSMC_RX_P7 17 PROTO_IO14 92 HSPROTO_IO14 HSMC_RX_N7 18 PROTO_IO15 85 HSPROTO_IO15 HSMC_TX_N6 21 PROTO_IO16 89 HSPROTO_IO16 HSMC_TX_P7 23 PROTO_IO17 91 HSPROTO_IO17 HSMC_TX_N7 25 PROTO_IO18 143 HSPROTO_IO18 HSMC_TX_P15 27 PROTO_IO19 145 HSPROTO_IO19 HSMC_TX_N15 28 PROTO_IO20 149 HSPROTO_IO20 HSMC_TX_P16 29 PROTO_IO21 151 HSPROTO_IO21 HSMC_TX_N16 31 PROTO_IO22 155 HSPROTO_IO22 HSMC_CLKOUT_P2 32 PROTO_IO23 134 HSPROTO_IO23 HSMC_RX_N13 33 PROTO_IO24 138 HSPROTO_IO24 HSMC_RX_P14 35 PROTO_IO25 140 HSPROTO_IO25 HSMC_RX_N14 36 PROTO_IO26 144 HSPROTO_IO26 HSMC_RX_P15 37 PROTO_IO27 146 HSPROTO_IO27 HSMC_RX_N15 38 PROTO_CARDSEL 150 HSPROTO_CARDSEL HSMC_RX_P16 39 PROTO_IO28 152 HSPROTO_IO28 HSMC_RX_N16 13 Board Components 3.3 USB On-The-Go transceiver This section describes the USB On-The-Go transceiver on the THDB-SUM board The THDB-SUM is equipped with a NXP ISP1504C USB On-The-Go transceiver (U11) and Mini USB AB type receptacle connector (J8) to provide USB interface to the HSMC interface host board. The ISP1504 is a Universal Serial Bus (USB) On-The-Go (OTG) transceiver that is fully compliant with Universal Serial Bus Specification Rev. 2.0, On-The-Go Supplement to the USB 2.0 Specification Rev. 1.3 and UTMI+ Low Pin Interface (ULPI) Specification Rev. 1.1. The pervious section, Santa Cruz Connector, has mentioned that USB transceiver and Santa Cruz connector share the I/Os which connect to HSMC connector, which means users can only choose one function between USB and Satan Cruz interface, If users would like to choose the function of USB transceiver, please turn on JP2. For more detailed information about this transceiver, please refer to the datasheet which can be found in the NXP’s website. In addition, for OTG implementations, a 2-pin header named JP1 is connected with ID (identification) pin of the USB OTG transceiver and micro-USB receptacle. As shown in Figure 3.8, The logic level of the ID pin on the USB OTG transceiver can be configured to logic high or low via JP1. As defined in On-The-Go supplement to the USB 2.0 specification Rev. 1.3, the ID pin dictates the initial role of the link. If ID is detected as HIGH, the link must assume the role of a peripheral. If ID is detected as LOW, the link must assume a host role. Table 3.7 shows the JP1 configuration setting for the ID. Finally, the detailed pin mappings between the USB On-The-Go transceiver and the HSMC connector are shown in Table3.8. Table 3.7 The configuration of the ID pin JP2 setting Host or peripheral role Open Peripheral Close Host 14 Board Components HSMC Connector (J1) Jack-Mini- USB-AB (J8) USB USB _D[7..0] USB_RESET_n HSPROTO_IO VBUS DM DP ID DATA[7..0] USB_CS_n CS RESET Bus Switch (U1,U2) NXP ISP1504C (U11) USB_DIR USB_STP USB_NXT USB_CLKOUT JP2 Close = Host Open = Peripheral DIR STP NXT CLOCK X1 XTAL1 XTAL2 XTAL1 XTAL2 26MHZ JP1 Open Figure 3.8 The block diagram of the USB OTG transceiver and HSMC connector Table 3.8 The pin assignments of the USB OTG Transceiver U11 USB Pin HSMC Pin USB Signal Name Number HSMC Pin HSMC Signal Name Number Name 1 USB_D0 48 HSPROTO_RESET HSMC_RX_P0 17 USB_RESET_n 86 HSPROTO_IO12 HSMC_RX_N6 19 USB_DIR 84 HSPROTO_IO11 HSMC_RX_P6 20 USB_STP 80 HSPROTO_IO10 HSMC_RX_N5 21 USB_NXT 78 HSPROTO_IO9 HSMC_RX_P5 23 USB_D7 74 HSPROTO_IO8 HSMC_RX_N4 24 USB_D6 72 HSPROTO_IO7 HSMC_RX_P4 25 USB_D5 68 HSPROTO_IO6 HSMC_RX_N3 26 USB_D4 66 HSPROTO_IO5 HSMC_RX_P3 27 USB_CLKOUT 62 HSPROTO_IO4 HSMC_RX_N2 28 USB_D3 60 HSPROTO_IO3 HSMC_RX_P2 29 USB_CS_n 56 HSPROTO_IO2 HSMC_RX_N1 31 USB_D2 54 HSPROTO_IO1 HSMC_RX_P1 32 USB_D1 50 HSPROTO_IO0 HSMC_RX_N0 15 Board Components 3.4 Mictor Connector This section describes how to use the Mictor connector on the THDB-SUM board The Mictor connector (J2) can be used for logic analysis on the HSMC-interfaced host board by connecting an external scope or a logic analyzer to it. Figure 3.9 shows the pin-outs of the Mictor connector. Table 3.9 shows the detailed pin mappings between the Mictor connector and the HSMC connector. Figure 3.9 Mictor connector pin-outs Table 3.9 The pin assignments of the Mictor connector J2 Mictor Mictor Connector HSMC Pin Signal Name Number 5 MICTOR_CLK 6 Connector HSMC Signal Name HSMC Pin Name 156 MICTOR_CLK HSMC_CLKIN_P2 TR_CLK 157 TR_CLK HSMC_CLKOUT_N2 7 MICTOR_D24 132 MICTOR_D24 HSMC_RX_P13 8 MICTOR_D13 121 MICTOR_D13 HSMC_TX_N11 9 MICTOR_D23 128 MICTOR_D23 HSMC_RX_N12 10 MICTOR_D12 125 MICTOR_D12 HSMC_TX_P12 13 MICTOR_D22 126 MICTOR_D22 HSMC_RX_P12 16 MICTOR_D11 127 MICTOR_D11 HSMC_TX_N12 18 MICTOR_D10 131 MICTOR_D10 HSMC_TX_P13 20 MICTOR_D9 133 MICTOR_D9 HSMC_TX_N13 22 MICTOR_D8 137 MICTOR_D8 HSMC_TX_P14 23 MICTOR_D21 122 MICTOR_D21 HSMC_RX_N11 Pin Number 16 Board Components 24 MICTOR_D7 139 MICTOR_D7 HSMC_TX_N14 25 MICTOR_D20 120 MICTOR_D20 HSMC_RX_P11 26 MICTOR_D6 119 MICTOR_D6 HSMC_TX_P11 27 MICTOR_D19 116 MICTOR_D19 HSMC_RX_N10 28 MICTOR_D5 109 MICTOR_D5 HSMC_TX_N9 29 MICTOR_D18 114 MICTOR_D18 HSMC_RX_P10 30 MICTOR_D4 107 MICTOR_D4 HSMC_TX_P9 31 MICTOR_D17 110 MICTOR_D17 HSMC_RX_N9 32 MICTOR_D3 115 MICTOR_D3 HSMC_TX_N10 33 MICTOR_D16 108 MICTOR_D16 HSMC_RX_P9 34 MICTOR_D2 113 MICTOR_D2 HSMC_TX_P10 35 MICTOR_D15 104 MICTOR_D15 HSMC_RX_N8 36 MICTOR_D1 103 MICTOR_D1 HSMC_TX_N8 37 MICTOR_D14 102 MICTOR_D14 HSMC_RX_P8 38 MICTOR_D0 101 MICTOR_D0 HSMC_TX_P8 11 MICTOR_TDO 37 HSMC_TDO HSMC_TDO 15 MICTOR_TCK 35 HSMC_TCK HSMC_TCK 17 MICTOR_TMS 36 HSMC_TMS HSMC_TMS 19 MICTOR_TDI 38 HSMC_TDI HSMC_TDI To use this interface, user needs to configure the JTAG interface on the HSMC interface host board. For example, the steps of controlling the Cyclone III start board using Mictor interface is shown below: 1. Connecting the THDB-SUM board to the Cyclone III Start Board. 2. Removing the jumpers of JP1 and JP2 of the Cyclone III Start Board to connect the JTAG interface between Cyclone III FPGA and the THDB-SUM board. 3. Short the TDI and TDO pins of the JTAG connector(J4), as shown in Figure 3.10 4. Disable the built-in USB blaster by shorting JP8 on the Cyclone III Starter Board The above FOUR steps will make a closed JTAG chain as shown in Figure 3.11 17 Board Components Open JP1 nad JP2 Short TDI and TDO pin of the J4 J4 Short Close JP8 With jumper Figure 3.10 The configuration of the Cyclone III start board for controlling the JTAG chain using the Mictor connector THDB-SUM Board Cyclone III Start Board USB3V CLOSE JP8 VCC25 OPEN Mictor connector J2 JP1 OPEN TDI TDI TDO TDO J4 MICOTR_TDI MICOTR_TDI MICOTR_TDO JP2 MICOTR_TDO HSMC_TDI HSMC_TDI JTAG_TDO LF_TDI HSMC_TDO HSMC_TDO Cyclone III TDO LF_TDO HSMC SHORT LF_TDO TDI ADG3304 MAX 3128 Built-in Blaster TDI TDO CII_TDO ADG3308 Figure 3.11 The JTAG chain between the THDB-SUM board and Cyclone III Start Board 3.5 SD Card Interface This section describes the SD Card Interface on the THDB-SUM board The THDB-SUM has a SD card socket and can be accessed as optional external memory in both SPI and 1-bit SD mode. Table X shows the pinout of the SD card socket with HSMC connector. Figure 3.12 and Table 3.10 shows the pin connection and pin-out between the Mictor connector and HSMC connector, respectively. 18 Board Components HSMC Connector SD Card Socket SD_DAT2 LF_DAT2 9 DAT2 SD_DAT3 SD_CMD SD_CLK SD_DAT0 SD_DAT1 SD_WPn LF_DAT3 LF_CMD LF_CLK LF_DAT0 LF_DAT1 LF_WPn 1 2 DAT3 CMD CLK DAT0 DAT1 WPn Level Shift (U9) 5 7 8 11 Figure 3.12 The block diagram of the SD Card socket and HSMC connector Table 3.10 The pin assignments of the SD Card Socket J7 SD Card Socket SD Card Socket HSMC Pin Pin Number Signal Name Number 1 LF_DAT3 2 HSMC Signal Name HSMC Pin Name 42 SD_DAT3 HSMC_D1 LF_CMD 47 SD_CMD HSMC_TX_P0 5 LF_CLK 43 SD_CLK HSMC_D2 7 LF_DAT0 41 SD_DAT0 HSMC_D0 8 LF_DAT1 39 SD_DAT1 HSMC_CLKOUT0 9 LF_DAT2 44 SD_DAT2 HSMC_D3 11 LF_WPn 40 SD_WP_N HSMC_CLKIN0 3.6 SMA Connector This section describes the SMA connector on the THDB-SUM board The THDB-SUM board provides a SMA connector (J6) for external clock input. The pin assignments of the SMA connector are shown in Table 3.11. Table 3.11 The pin assignments of the SMA Connector J6 SD Card Socket SD Card Socket HSMC Pin Pin Number Signal Name Number 1 EXT_CLK 96 19 HSMC Signal Name HSMC Pin Name EXT_CLK HSMC_CLKIN_P1 Board Components 3.7 I2C Serial EEPROM This section describes the I2C Serial EEPROM on the THDB-SUM board The THDB-SUM board provides an EEPROM (U10) which can be configured by the I2C interface. The size of the EEPROM is 128 bit that can store the board information or user’s data. The detailed pin description between EEPROM and HSMC connector is listed in the Table 3.12. HSMC Connector R31 HSMC_SCL HSMC_SDA VCC33 A0 R32 SCL SDA EEPROM (U10) R33 VCC33 A1 R34 R35 A2 VCC33 R36 Default Address : 0x0 Table 3.13 The block diagram of the EEPROM and HSMC connector Table 3.12 The pin assignments of the EEPROM U10 EEPROM Pin EEPROM Signal HSMC Pin Number Name Number 5 HSMC_SDA 33 HSMC_SDA 6 HSMC_SCL 34 HSMC_SCL HSMC Signal Name 20 Board Components 3.8 Power Supply This section describes the power supply on the THDB-SUM board The power distribution on the THDB-SUM board is shown in Figure 3.14. 12V VCC50 REG3 REG2 HSMC Connector (J1) Santa Cruz Connector (J3~J5) VSC JP4 VHSMC VCCA VCCB Level Shifters (U3~U8) VCC33 REG1 JP3 VCCA VCCB Level Shifters (U9) EEPROM (U10) Mictor Connector (J2) VCC33 VCC50 SD Card Socket (J7) Figure 3.14. THDB-SUM board power distribution diagram. 21 USB (U11) Demonstration 4 Demonstration This chapter illustrates how to connect the THDB-SUM board to a HSMC interface host board using a Cyclone III Starter Board as an example 4.1 Connecting THDB-SUM Board to Cyclone III Start Board This section describes how to use THD-SUM board the Cyclone III start board and what users need to know during the operation Figure 4.1 Connecting the THDB-SUM board to the Cyclone III start board To correctly operate the THDB-SUM board with the Cyclone III start board, users need to pay attention to the following notes: 1. Observe the orientation of the HSMC connector when connecting the THDB-SUM to the Cyclone III Starter Board. 2. Users MUST short Pin 1 and Pin 2 of the JP3 on the THDB-SUM to force the voltage level to 2.5V to match the 2.5V IO pins of the Cyclone III board. 3. Configure JP4 of the THDB-SUM according to the logic level of the Santa Cruz daughter board (refer to Table 3.2) 4. Please note that there are two LVDS pairs on the HSMC connector: the HSMC_CLK_p1/n1 (form a 22 Demonstration close loop via R3) and HSMC_CLKIN_p2/n2 (form a close loop via R4). Therefore, using any one of the signal in a LVDS pair under single-ended mode will prevent users from using the other signal in the same pair. 23 Appendix 5 Appendix 5.1 Revision History Date Change Log SEP 3, 2008 Initial Version MAR 13,2009 Modify Figure 3.3 DEC 2, 2009 Corrections for tables 3.1 & 3.7. Modify Ch.4 section 5.2 Always Visit THDB-SUM Webpage for New Main board We will be continuing providing interesting examples and labs on our THDB-SUM webpage. Please visit www.altera.com or SUM.terasic.com for more information. 24
P0006 价格&库存
很抱歉,暂时无法提供与“P0006”相匹配的价格&库存,您可以联系我们找货
