AS1154-BSOU
AS1154-BSOU
    AMSOSRAM(艾迈斯半导体)
    SOIC8
    IC DRIVER 2/0 8SOIC
AS1154-BSOU 数据手册
A S 11 5 6 / A S 11 5 4 S i n g l e / D u a l LV D S D r i v e r D a ta S he e t 1 General Description The AS1156/AS1154 is a Single/Dual Flow-Through LVDS (Low-Voltage Differential Signaling) Line Driver which accepts and converts LVTTL/LVCMOS input levels into LVDS output signals. The device is perfect for low-power low-noise applications requiring high signaling rates and reduced EMI emissions. The device is guaranteed to transmit data at speeds up to 800Mbps (400MHz) over controlled impedance media of approximately 100Ω. Supported transmission media are PCB traces, backplanes, and cables. The AS1156 is a single LVDS transmitter, and the AS1154 is a dual LVDS transmitter. Outputs conform to the ANSI TIA/EIA-644 LVDS standards. Flow-through pinout simplifies PC board layout and reduces crosstalk by separating the LVTTL/LVCMOS inputs and LVDS outputs. The AS1156/AS1154 operates from a single +3.3V supply and is specified for operation from -40 to +85°C. 2 Key Features Flow-Through Pinout Guaranteed 800Mbps Data Rate 250ps Pulse Skew (Max) Conforms to ANSI TIA/EIA-644 LVDS Standards Single +3.3V Supply Operating Temperature Range: -40 to +85°C 8-Pin SOIC Package 3 Applications Digital Copiers, Laser Printers, Cellular Phone Base Stations, Add/Drop Muxes, Digital Cross-Connects, DSLAMs, Network Switches/Routers, Backplane Interconnect, Clock Distribution Computers, Intelligent Instruments, Controllers, Critical Microprocessors and Microcontrollers, Power Monitoring, and Portable/Battery-Powered Equipment. Figure 1. Block Diagram AS1156 AS1154 VCC Tx OUT1- VCC Tx OUT1- IN1 OUT1+ IN1 OUT1+ N/C N/C IN2 Tx OUT2+ GND N/C GND OUT2- www.austriamicrosystems.com Revision 1.01 1 - 15 AS1156/AS1154 Data Sheet - P i n o u t 4 Pinout Pin Assignments Figure 2. AS1156/AS1154 Pin Assignments (Top View) VCC IN1 N/C GND 1 2 8 7 OUT1OUT1+ N/C N/C VCC IN1 IN2 GND 1 2 8 7 OUT1OUT1+ OUT2+ OUT2- AS1156 3 4 6 5 3 4 AS1154 6 5 Pin Descriptions Table 1. AS1156/AS1154 Pin Descriptions Pin Number AS1154 1 2 3 4 5 6 7 8 7 8 3, 5, 6 4 AS1156 1 2 Pin Name VCC IN1 IN2 GND OUT2OUT2+ OUT1+ OUT1N/C Description Power Supply Input. Bypass VCC to GND with 0.1µF and 0.001µF ceramic capacitors. LVTTL/LVCMOS Driver Input LVTTL/LVCMOS Driver Input Ground Inverting LVDS Driver Output Noninverting LVDS Driver Output Noninverting LVDS Driver Output Inverting LVDS Driver Output Not connected www.austriamicrosystems.com Revision 1.01 2 - 15 AS1156/AS1154 Data Sheet - A b s o l u t e M a x i m u m R a t i n g s 5 Absolute Maximum Ratings Stresses beyond those listed in Table 2 may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Table 2. Absolute Maximum Ratings Parameter VCC to GND INx, EN, ENn to GND OUTx+, OUTx- to GND Short Circuit Duration (OUTx+, OUTx-) Continuous Power Dissipation (TA = +70°C) Storage Temperature Range Maximum Junction Temperature Operating Temperature Range Limits -0.3 to +5.0 -0.3 to (VCC + 0.3) -0.3 to +5 Continuous 755 -65 to +150 +150 -40 to +85 mW ºC ºC ºC Units V V V Notes Derate 9.4mW/°C Above +70°C Package Body Temperature 260 ºC The reflow peak soldering temperature (body temperature) specified is in compliance with IPC/JEDEC J-STD020C “Moisture/ Reflow Sensitivity Classification for Non-Hermetic Solid State Surface Mount Devices”. Human Body Model, INx, OUTx+, OUTx-- ESD Protection ±4 kV www.austriamicrosystems.com Revision 1.01 3 - 15 AS1156/AS1154 Data Sheet - E l e c t r i c a l C h a r a c t e r i s t i c s 6 Electrical Characteristics DC Electrical Characteristics (VCC = +3.0 to +3.6V, TA = -40 to +85°C , RL = 100Ω ±1% Typical values are at VCC = +3.3V, TA = +25°C, Unless Otherwise Noted.) 1 Table 3. DC Electrical Characteristics Parameter LVDS Output (OUtx+, OUTx-) Differential Output Voltage Change in Magnitude of VOD Between Complementary Output States VOD Symbol Conditions Min Typ Max Unit Figure 21 on page 11 Figure 21 on page 11 Figure 21 on page 11 Figure 21 on page 11 250 355 1 450 35 1.375 25 1.6 mV mV V mV V V ΔVOD VOS Offset Voltage Change in Magnitude of VOS Between Complementary Output States 1.125 1.25 4 ΔVOS VOH VOL IOSD IOS IOFF Output High Voltage Output Low Voltage Differential Output Short-Circuit Current 2 Output Short-Circuit Current Power-Off Output Current Inputs (INx) High-Level Input Voltage Low-Level Input Voltage Input Current Supply Current No-Load Supply Current 0.90 VOD = 0V OUTx+ = 0V at INx = VCC or OUTx- = 0V at INx = 0V VCC = 0V or open, OUTx+ = 0V or 3.6V OUTx- = 0V or 3.6V, RL = ∞ -9 -3.7 -20 -9 20 mA mA µA VIH VIL IIN INx = 0V or VCC RL = ∞ , INx = VCC or 0V for all channels RL = 100Ω, INx = VCC or 0V for all channels, AS1156 RL = 100Ω, INx = VCC or 0V for all channels, AS1154 2.0 GND -20 VCC V V µA 0.8 20 ICC 2 5.5 8.5 3.5 7.5 12 mA mA mA Loaded Supply Current ICCL Notes: 1. Currents into the device are positive, and current out of the device is negative. All voltages are referenced to ground except VOD. 2. Guaranteed by correlation data. www.austriamicrosystems.com Revision 1.01 4 - 15 AS1156/AS1154 Data Sheet - E l e c t r i c a l C h a r a c t e r i s t i c s Switching Characteristics (VCC = +3.0 to +3.6V, RL = 100Ω ±1%, CL = 2.5pF (differential), TA = -40 to +85°C Typical values are at VCC = +3.3V, TA = +25ºC, Unless Otherwise Noted.) 1, 2, 3, 10 Table 4. Switching Characteristics Parameter Differential Propagation Delay, High-to-Low Differential Propagation Delay, Low-to-High Differential Pulse Skew 4 Differential Channel-to-Channel Skew 5 Differential Part-to-Part Skew 6 Differential Part-to-Part Skew 7 Rise Time Fall Time Maximum Operating Frequency 8, 9 Notes: 1. Parameters are guaranteed by design and characterization. 2. CL includes probe and jig capacitance. 3. Signal generator conditions for dynamic tests: VOL = 0, VOH = 2.4V, f = 100MHz, 50% duty cycle, RO = 50Ω, tR ≤ 1ns, tF ≤ 1ns (0 to 100%). 4. tSKD1 is the magnitude difference of differential propagation delay. tSKD1 = |tPHLD - tPLHD|. 5. tSKD2 is the magnitude difference of tPHLD or tPLHD of one channel to the tPHLD or tPLHD of another channel on the same device. 6. tSKD3 is the magnitude difference of any differential propagation delays between devices at the same VCC and within 5°C of each other. 7. tSKD4 is the magnitude difference of any differential propagation delays between devices operating over the rated supply and temperature ranges. 8. fMAX signal generator conditions: VOL = 0, VOH = 2.4V, 50% duty cycle, RO = 50Ω, tR ≤ 1ns, tF ≤ 1ns (0 to 100%). 9. Transmitter output criteria: duty cycle = 45 to 55%, VOD ≥ 250mV. 10. For optimum performance matched circuits should be used. Symbol tPHLD tPLHD tSKD1 tSKD2 tSKD3 tSKD4 tTLH tTHL fMAX Conditions Figure 20 on page 11 and Figure 21 on page 11 Figure 20 on page 11 and Figure 21 on page 11 Figure 20 on page 11 and Figure 21 on page 11 Figure 20 on page 11 and Figure 21 on page 11 Figure 20 on page 11 and Figure 21 on page 11 Figure 20 on page 11 and Figure 21 on page 11 Figure 20 on page 11 and Figure 21 on page 11 Figure 20 on page 11 and Figure 21 on page 11 200 200 400 356 352 Min 1.1 1.1 Typ 1.268 1.267 90 110 Max 1.5 1.5 200 250 750 900 800 800 Unit ns ns ps ps ps ps ps ps MHz www.austriamicrosystems.com Revision 1.01 5 - 15 AS1156/AS1154 Data Sheet - Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s 7 Typical Operating Characteristics VCC = +3.3V, CLOAD = 2.5pF (differential), Freq = 20MHz, Tamb = +25ºC, unless otherwise noted Figure 3. Transition Time vs. VCC 270 Figure 4. Transition Time vs. Temperature 350 . . tTHL 300 tTHL Transition Time (ps) Transition Time (ps) 260 250 200 150 100 50 0 -50 tTLH 250 240 tTLH 230 3 3.1 3.2 3.3 3.4 3.5 3.6 -30 -10 10 30 50 70 90 Supply Voltage(V) Ambient Temperature(°C) Figure 5. Differential Pulse Skew vs. VCC 80 Figure 6. Pulse Skew vs. Temperature 35 30 . 70 Differential Pulse Skew (ps) 60 50 40 30 20 10 0 3 3.1 3.2 3.3 3.4 3.5 3.6 . Pulse Skew (ps) 25 20 15 10 5 0 -50 -30 -10 10 30 50 70 90 Supply Voltage(V) Ambient Temperature(°C) Figure 7. Differential Propagation Delay vs. VCC; 1.05 Figure 8. Differential Propagation Delay vs. Temp. 1.14 . . 1.12 1.03 tPHLD Diff. Propagation Delay (ns) Diff. Propagation Delay (ns) 1.1 1.08 1.06 1.04 1.02 1 0.98 -50 tPHLD tPLHD 1.01 0.99 0.97 tPLHD 0.95 3 3.1 3.2 3.3 3.4 3.5 3.6 -30 -10 10 30 50 70 90 Supply Voltage(V) Ambient Temperature(°C) www.austriamicrosystems.com Revision 1.01 6 - 15 AS1156/AS1154 Data Sheet - Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s Figure 9. Differential Output Voltage vs. VCC 350 Figure 10. Differential Output Voltage vs. Frequency 350 300 250 200 150 100 50 0 0 50 100 150 200 250 300 350 400 . 345 340 335 330 325 3 3.1 3.2 3.3 3.4 3.5 3.6 Supply Voltage (V) Differential Output Voltage (mV) Differential Output Voltage (mV) . Frequency (MHz) Figure 11. Offset Voltage vs. VCC 1.24 Figure 12. Offset Voltage vs. Frequency 1.35 Offset Voltage (V) . 1.23 Offset Voltage (V) . 3 3.1 3.2 3.3 3.4 3.5 3.6 1.3 1.25 1.22 1.2 1.21 1.15 1.2 1.1 0 50 100 150 200 250 Supply Voltage (V) Frequency (MHz) Figure 13. Output Voltage vs. VCC; 1.45 VOUT+ Figure 14. Output Voltage vs. Load Resistance; 1.45 Output Voltage (V) . Output Voltage (V) . 1.35 1.35 VOUT+ 1.25 1.25 1.15 VOUT- 1.15 VOUT- 1.05 1.05 0.95 3 3.1 3.2 3.3 3.4 3.5 3.6 0.95 80 90 100 110 120 130 140 150 Supply Voltage (V) Load Resistance (Ω ) www.austriamicrosystems.com Revision 1.01 7 - 15 AS1156/AS1154 Data Sheet - Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s Figure 15. ICC vs. VCC 11 Figure 16. ICC vs. Temperature; 13 . 10.6 . 12 Supply Current (mA) 10.2 Supply Current (mA) Freq = 100MHz 11 9.8 10 Freq = 20MHz 9.4 9 9 3 3.1 3.2 3.3 3.4 3.5 3.6 8 -50 -30 -10 10 30 50 70 90 Supply Voltage (V) Ambient Temperature(°C) Figure 17. Short Circuit Current vs. VCC 3.9 Figure 18. ICC vs. Frequency 18 16 Output Short Circuit Current (mA) . 3.85 3.8 . Supply Current (mA) 14 12 10 8 6 4 2 0 3 3.1 3.2 3.3 3.4 3.5 3.6 0 50 100 150 200 250 One Channel Two Channels 3.75 3.7 3.65 3.6 Supply Voltage(V) Frequency (MHz) www.austriamicrosystems.com Revision 1.01 8 - 15 AS1156/AS1154 Data Sheet - D e t a i l e d D e s c r i p t i o n 8 Detailed Description LVDS Interface The LVDS interface standard is a signaling method intended for point-to-point communication over a controlled-impedance medium as defined by the ANSI/TIA/EIA-644 and IEEE 1596.3 standards. The LVDS standard uses a lower voltage swing than other common communication standards, achieving higher data rates with reduced power consumption while reducing EMI emissions and system susceptibility to noise. The AS1156/AS1154 is an 800Mbps single/dual differential LVDS driver that is designed for high-speed, point-to-point, low-power applications. This device accepts LVTTL/LVCMOS input levels and translates them to LVDS output signals. The AS1156/AS1154 generates a 2.5mA to 4.5mA output current using a current-steering configuration. This current steering approach induces less ground bounce and no shoot-through current, enhancing noise margin and system speed performance. The driver outputs are short-circuit current limited, and enter a high-impedance state when the device is not powered or is disabled. The current-steering architecture of the AS1156/AS1154 requires a resistive load to terminate the signal and complete the transmission loop. Because the device switches current and not voltage, the actual output voltage swing is determined by the value of the termination resistor at the input of an LVDS receiver (AS1157, AS1158). Logic states are determined by the direction of current flow through the termination resistor. With a typical 3.7mA output current, the AS1156/AS1154 produces an output voltage of 370mV when driving a 100Ω load. Termination Because the AS1156/AS1154 is a current-steering device, no output voltage will be generated without a termination resistor. The termination resistors should match the differential impedance of the transmission line. Output voltage levels depend upon the value of the termination resistor. The AS1156/AS1154 is optimized for point-to-point interface with 100Ω termination resistors at the receiver inputs. Termination resistance values may range between 90 and132Ω, depending on the characteristic impedance of the transmission medium. www.austriamicrosystems.com Revision 1.01 9 - 15 AS1156/AS1154 Data Sheet - A p p l i c a t i o n s 9 Applications Table 5. Function Table Input INx L H 0.8V < VINx < 2.0V OUTx+ L H Undetermined Output OUTxH L Undetermined Figure 19. Typical Application Circuit +3.3V +3.3V 0.001µF 0.1µF 0.001µF 0.1µF LVDS Signals LVTTL/LVCMOS Data Inputs LVTTL/LVCMOS Data Outputs Tx 107Ω Rx AS1156 AS1158 Single LVDS Receiver 100Ω Shielded Twisted Cable or Microstrip PC Board Traces Power-Supply Bypassing To bypass VCC, use high-frequency surface-mount ceramic 0.1µF and 0.001µF capacitors in parallel as close to the device as possible, with the smaller valued capacitor closest to pin VCC. Differential Traces Input trace characteristics can adversely affect the performance of the AS1156/AS1154. Use controlled-impedance PC board traces to match the cable characteristic impedance. The termination resistor is also matched to this characteristic impedance. Eliminate reflections and ensure that noise couples as common mode by running the differential traces near each other. Reduce skew by using matched trace lengths. Tight skew control is required to minimize emissions and proper data recovery of the devices. Route each channel’s differential signals very close to each other for optimal cancellation of their respective external magnetic fields. Use a constant distance between the differential traces to avoid irregularities in differential impedance. Avoid 90° turns (use two 45° turns). Minimize the number of vias to further prevent impedance irregularities. Cables and Connectors Supported transmission media include printed circuit board traces, backplanes, and cables. Use cables and connectors with matched differential impedance (typically 100Ω) to minimize impedance mismatches. Balanced cables such as twisted pair offer superior signal quality and tend to generate less EMI due to magnetic field canceling effects. Balanced cables pick up noise as common mode, which is rejected by the LVDS receiver. Avoid the use of unbalanced cables such as ribbon cable or simple coaxial cable. www.austriamicrosystems.com Revision 1.01 10 - 15 AS1156/AS1154 Data Sheet - A p p l i c a t i o n s Board Layout The device should be placed as close to the interface connector as possible to minimize LVDS trace length. Keep the LVDS and any other digital signals separated from each other to reduce crosstalk. Use a four-layer PC board that provides separate power, ground, LVDS signals, and input signals. Isolate the input LVDS signals from each other and the output LVCMOS/LVTTL signals from each other to prevent coupling. Separate the input LVDS signals from the output signals planes with the power and ground planes for best results. Figure 20. Driver Propagation Delay and Transition Time Waveforms 1.5V INx tPLHD OUTx0 Differential OUTx+ 1.5V tPHLD VOH 0 VOL 80% 0 20% VDIFF = (VOUTx+) - (VOUTx-) 80% 00 20% tTLH tTHL Figure 21. Driver Propagation Delay and Transition Time Test Circuit OUTx+ Generator 50Ω CL RL OUTx- www.austriamicrosystems.com Revision 1.01 11 - 15 AS1156/AS1154 Data Sheet - A p p l i c a t i o n s Figure 22. Driver VOD and VOS Test Circuit OUTx+ RL/2 VCC INx GND RL/2 VOS VOD OUTx- www.austriamicrosystems.com Revision 1.01 12 - 15 AS1156/AS1154 Data Sheet - P a c k a g e D r a w i n g s a n d M a r k i n g s 10 Package Drawings and Markings The AS1156/AS1154 is available in a 8-pin SOIC package. Figure 23. 8-pin SOIC Package Notes: 1. Lead coplanarity should be 0 to 0.10mm (.004”) max. 2. Package surface finishing: - Top, matte (charmilles #18-30) - All sides, matte (charmilles +18-30) - Bottom, smooth or matte (charmilles +18-30) 3. All dimensions excluding mold flashes and end flash from the package body shall not exceed 0.25mm (.010”) per side. 4. Details of pin #1 mark are optional but must be located within the area indicated. Symbol A A1 A2 B C D E e H h L α ZD Min Max 1.52 1.72 0.10 0.25 1.37 1.57 0.36 0.46 0.19 0.25 4.80 4.98 3.81 3.99 1.27BSC 5.80 6.20 0.25 0.50 0.41 1.27 0º 8º 0.53REF www.austriamicrosystems.com Revision 1.01 13 - 15 AS1156/AS1154 Data Sheet - O r d e r i n g I n f o r m a t i o n 11 Ordering Information Part Number AS1156-BSOU AS1156-BSOT AS1154-BSOU AS1154-BSOT Description Single Channel LVDS Line Driver Single Channel LVDS Line Driver Dual Channel LVDS Line Driver Dual Channel LVDS Line Driver Delivery Form Tubes Tape and Reel Tubes Tape and Reel Package SOIC-8 SOIC-8 SOIC-8 SOIC-8 www.austriamicrosystems.com Revision 1.01 14 - 15 AS1156/AS1154 Data Sheet Copyrights Copyright © 1997-2008, austriamicrosystems AG, Schloss Premstaetten, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered ®. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. All products and companies mentioned are trademarks or registered trademarks of their respective companies. Disclaimer Devices sold by austriamicrosystems AG are covered by the warranty and patent indemnification provisions appearing in its Term of Sale. austriamicrosystems AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein or regarding the freedom of the described devices from patent infringement. austriamicrosystems AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with austriamicrosystems AG for current information. This product is intended for use in normal commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or lifesustaining equipment are specifically not recommended without additional processing by austriamicrosystems AG for each application. For shipments of less than 100 parts the manufacturing flow might show deviations from the standard production flow, such as test flow or test location. The information furnished here by austriamicrosystems AG is believed to be correct and accurate. However, austriamicrosystems AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of austriamicrosystems AG rendering of technical or other services. Contact Information Headquarters austriamicrosystems AG A-8141 Schloss Premstaetten, Austria Tel: +43 (0) 3136 500 0 Fax: +43 (0) 3136 525 01 For Sales Offices, Distributors and Representatives, please visit: http://www.austriamicrosystems.com/contact www.austriamicrosystems.com Revision 1.01 15 - 15
AS1154-BSOU 价格&库存
很抱歉,暂时无法提供与“AS1154-BSOU”相匹配的价格&库存,您可以联系我们找货
