AS13985F29-T
AS13985F29-T
    AMSOSRAM(艾迈斯半导体)
    5-UFBGA,WLCSP
    IC REG LDO 2.9V 0.15A 5WLCSP
AS13985F29-T 数据手册
Datasheet AS13985 Micropower 150mA Low-Noise LDO 1 General Description The AS13985 is a high-performance low-dropout 150mA voltage regulator designed for use with very-low ESR output capacitors. The device can deliver superior performance in all specifications critical to battery-powered designs, and is perfectly suited for mobile phones, PDAs, MP3 players, and other battery powered devices. Stability is guaranteed with a ceramic output capacitor from 1 to 22µF. The low equivalent series resistance of these capacitors ensures low output impedance at high frequencies. Automatic sleep mode requires less than 1µA quiescent current when pin EN is pulled low. Regulation performance is excellent even under low dropout conditions, when the power transistor has to operate in linear mode. A 10nF bypass capacitor can be added to reduce output noise to 30µV. The low-noise performance allows direct connection of noise sensitive circuits without additional filtering networks. Multiple output voltage options are available as standard products. Contact austriamicrosystems AG for details. The AS13985 is available in a 5-bump WLP package and a 5-pin SOT23 package. 2 Key Features ! Ultra-Low Dropout Voltage (typically 45mV @ 150mA, 0.3mV @ 1mA) Supply Range: 2.5V to 5.5V Output Voltage Range: 1.2V to 5.0V (in 25mV Steps) Output Current: 150mA (Guaranteed) Stable with Low-ESR Output Capacitor Integrated Over-Temperature/Over-Current Protection Low GND Pin Current (only 95µA) Output Voltage Accuracy: 1% Minimal External Components Required High Peak-Current Capability Low Shutdown Current: ≤1µA Operating Temperature Junction Range: -40 to +125°C Smallest Available Packages: - 5-bump WLP - 5-pin SOT23 ! ! ! ! ! ! ! ! ! ! ! ! 3 Applications The AS13985 is ideal for powering cordless and mobile phones, MP3 players, CD and DVD players, PDAs, handheld computers, digital cameras, and any other hand-held battery-powered device. Figure 1. AS13985 - Block Diagram VIN EN VREF – + VOUT BYPASS Over-Current/ Over-Temperature Protection GND AS13985 www.austriamicrosystems.com Revision 1.13 1 - 12 AS13985 Datasheet - P i n o u t 4 Pinout 4.1 Pin Assignments Figure 2. Pin Assignments (Top View) VIN 1 5 4 5 VOUT 2 GND 2 1 3 AS13985 (SOT23) AS13985 (WLP; Top Through View) BYPASS 3 4 EN 4.2 Pin Descriptions Table 1. Pin Descriptions Name VIN GND BYPASS EN VOUT WLP 4 2 5 1 3 SOT23 1 2 3 4 5 Input Voltage Ground Low-Noise Operation Bypass Capacitor Logic-High Enable Input. VEN ≥ 1.2V: VOUT is enabled. VEN ≤ 0.4V: VOUT is disabled. Regulated Output Voltage Description www.austriamicrosystems.com Revision 1.13 2 - 12 AS13985 Datasheet - A b s o l u t e M a x i m u m R a t i n g s 5 Absolute Maximum Ratings Stresses beyond those listed in Table 2 may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in Section 6 Electrical Characteristics on page 4 is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Table 2. Absolute Maximum Ratings Parameter Input Supply Voltage (Survival) Input Supply Voltage (Operating) Shutdown Input Voltage (Survival) Output Voltage (Survival) IOUT (Survival) Input/Output Voltage (Survival) Power Dissipation 2 1 Min -0.3 +2.5 -0.3 -0.3 Max +7 +5.5 +7 +7 Units V V V V Comments Short-circuit protected. -0.3 +7 V Internally limited. -40 -65 +125 +150 ºC ºC The reflow peak soldering temperature (body temperature) specified is in accordance with IPC/ JEDEC J-STD-020D “Moisture/Reflow Sensitivity Classification for Non-Hermetic Solid State Surface Mount Devices”. The lead finish for Pb-free leaded packages is matte tin (100% Sn). Operating Junction Temperature Storage Temperature Range Package Body Temperature +260 ºC 1. The output PNP structure contains a diode between pins VIN and VOUT that is normally reverse-biased. reversing the polarity of pins VIN and VOUT will activate this diode. 2. The maximum allowable power dissipation is a function of the maximum junction temperature (TJ(MAX), the junction-to-ambient thermal resistance (ΘJA), and the ambient temperature (TAMB). The maximum allowable power dissipation at any ambient temperature is calculated as: P(MAX) = (TJ(MAX) - (TAMB))/ΘJA Where: The value of ΘJA for the SOT23 package is 220ºC/W in a typical PC-board mounting. The value of ΘJA for the WLP package is 225ºC/W. Note: Exceeding the maximum allowable dissipation will cause excessive device temperature and the regulator will go into thermal shutdown. (EQ 1) www.austriamicrosystems.com Revision 1.13 3 - 12 AS13985 Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s 6 Electrical Characteristics TAMB = 25ºC, VIN = VOUT(NOM) +0.5V, COUT = CIN = 1µF, CBYPASS = 10nF, IOUT = 1mA, VEN = 1.4V (unless otherwise specified) Caution: Exposing the WLP package to direct light could cause device malfunction. Table 3. Electrical Characteristics Symbol VIN VOUT(NOM) - VOUT Parameter Operating Input Voltage Output Voltage Accuracy < 2.5V VOUT Output Voltage Accuracy ≥ 2.5V VOUT IOUT = 1mA TAMB = -40 to 125ºC IOUT = 1mA TAMB= -40 to 125ºC VIN = (VOUT(NOM) + 0.5V) to 4.5V, VOUT < 3V VIN = (VOUT(NOM) + 0.5V) to 5.5V, VOUT < 3V IOUT = 1 to 150mA, VOUT < 2.5V, TAMB = -40 to 125ºC Load Regulation IOUT = 1 to 150mA, VOUT ≥ 2.5V, TAMB = -40 to 125ºC (for WLP) IOUT = 1 to 150mA, TAMB = -40 to 125ºC (for SOT23-5), VOUT ≥ 2.5V Output AC Line Regulation VIN = VOUT(NOM) + 1V, IOUT = 150mA, tR = tF = 30µs On Mode: VEN = 1.2V, IOUT = 0mA On Mode: VEN = 1.2V, IOUT = 0mA, TAMB = -40 to 125ºC On Mode: VEN = 1.2V, IOUT = 0 to 150mA IQ Quiescent Current On Mode: VEN = 1.2V, IOUT = 0 to 150mA, TAMB = -40 to 125ºC Off Mode: VEN = 0.4V, IOUT = 0mA Off Mode: VEN = 0.4V, TAMB= -40 to 125ºC, IOUT = 0mA IOUT = 1mA IOUT = 1mA, TAMB = -40 to 125ºC IOUT = 50mA VDROP Dropout Voltage 3 Conditions Min 2.5 -50 -75 -1 -2 -0.15 -0.3 Typ Max 5.5 50 75 1 2 0.15 Unit V mV % of VOUT(NOM) Line Regulation 1 %/V 0.3 0.002 0.008 %/mA ΔVOUT 0.0004 0.002 0.0025 0.005 1 95 130 160 250 0.003 2 2 mVPP µA 1 0.3 2 15 35 30 70 45 100 500 60 dB 55 300 4 2 IOUT = 50mA, TAMB = -40 to 125ºC IOUT = 100mA IOUT = 100mA, TAMB = -40 to 125ºC IOUT = 150mA IOUT = 150mA, TAMB = -40 to 125ºC mV ISC Short Circuit Current RLOAD = 0Ω VIN = VOUT(NOM) + 1V, VRIPPLE = 50mV, IOUT = 50mA, f = 1kHz VIN = VOUT(NOM) + 1V, VRIPPLE = 50mV, IOUT = 50mA, f= 10kHz VOUT ≥ VOUT(NOM) - 5% VIN = 2.5 to 5.5V, TAMB = -40 to 125ºC mA SVR Supply Voltage Rejection IOUT(PK) VEN Peak Output Current Enable Input Logic Low Enable Input Logic High 500 0.4 mA V 1.2 www.austriamicrosystems.com Revision 1.13 4 - 12 AS13985 Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s Table 3. Electrical Characteristics Symbol IEN eN tON TSHDN Parameter Enable Input Current Output Noise Voltage Turn On Time 5 Conditions VEN = 0.4V, VIN = 5.5V BW = 10Hz to 100kHz, COUT = 1µF, IOUT = 0mA CBYPASS = 10nF Min Typ ±1 2 Max Unit nA µVRMS 30 150 160 250 µs ºC Thermal Shutdown 4, 6 Threshold Recommended Output Capacitor COUT Output Capacitor Capacitance ESR 1 5 22 2 µF mΩ 5000 1. Temperature variations are included within the output voltage accuracy. 2. Guaranteed by design. 3. Dropout voltage is the input-to-output voltage difference at which the output voltage is 100mV below its nominal value (does not apply to input voltages below 2.5V). 4. EN must be driven with a tR = tF < 10ms. 5. Turn on time is time measured between the enable input just exceeding the VEN high value and the output voltage just reaching 95% of its nominal value. 6. Typical thermal protection hysteresis is 20ºC. Note: All limits are guaranteed. The parameters with min and max values are guaranteed with production tests or SQC (Statistical Quality Control) methods. Figure 3. AC Line Regulation Input Voltage Test Signal 30µs 30µs 600mV VIN = VOUT(NOM) + 1V 600µs 4.6ms Figure 4. SVR Input Voltage Test Signal VIN 50mV VOUT(NOM) + 1V www.austriamicrosystems.com Revision 1.13 5 - 12 AS13985 Datasheet - Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s 7 Typical Operating Characteristics TAMB = +25ºC (unless otherwise specified) Figure 5. Output Voltage vs. Temperature; VIN = 3.4V, VSHDN = 1.4V, IOUT = 1mA 3 2.975 2.95 2.925 2.9 2.875 2.85 2.825 2.8 -45 0.6 -45 Figure 6. Shutdown Voltage vs. Temperature; VOUT = 2.9V, IOUT = 10mA 1 Shutdown Voltage (V) . Output Voltage (V) . 0.9 VIN = 5.5V 0.8 0.7 VIN = 3.8V -20 5 30 55 80 105 130 -20 5 30 55 80 105 130 Temperature (°C) Figure 7. Load Regulation vs. Temperature; VIN = 3.4V, VSHDN = 1.4V, IOUT = 1 to 150mA 0.0075 0.005 Temperature (°C) Figure 8. Line Regulation vs. Temperature; VIN = 3.4 to 5.0V, VSHDN =1.4V, IOUT =1mA 0.5 0.4 0.3 Load (%/mA) . Line (%/V) . 5 30 55 80 105 130 0.0025 0 -0.0025 -0.005 -0.0075 -45 -20 0.2 0.1 0 -0.1 -0.2 -0.3 -45 -20 5 30 55 80 105 130 Temperature (°C) Figure 9. SVR vs. Frequency; VIN = 3.9 to 3.95V, VOUT = 2.9V, IOUT = 50mA, VSHDN = 1.4V 100 90 80 70 250 200 Temperature (°C) Figure 10. Quiescent Current vs. Temperature; VOUT = 2.9V, VSHDN = 1.4V 300 SVR (dB) . IQ (µA) . 60 50 40 30 20 10 0 0.1 2.1 4.1 6.1 8.1 10.1 150 100 50 0 -45 VIN = 5.5V VIN = 3.4V -20 5 30 55 80 105 130 Frequency (kHz) Temperature (°C) www.austriamicrosystems.com Revision 1.13 6 - 12 AS13985 Datasheet - Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s Figure 11. Line Transient Response; VIN = 3.8 to 4.4V, TJ = 25ºC, IOUT = 150mA, CIN = COUT = 1µF, VOUT = 2.7V CBYPASS = 10nF, Rise Time/Fall Time = 1µs Figure 12. Turn On Time; VIN = 3.3V, CBYPASS = 10nF, CIN = COUT = 1µF (Ceramic), tR = 20ns, IOUT = 1mA, VOUT = 2.8V 1V/Div VIN 2mV/Div VOUT 1ms/Div EN 50µs/Div www.austriamicrosystems.com Revision 1.13 500mV/Div 500mV/Div VOUT 7 - 12 AS13985 Datasheet - Ty p i c a l A p p l i c a t i o n 8 Typical Application Figure 13. Typical Application Diagram VIN VIN EN 1.23V CIN 1µF VREF – + VOUT VOUT Over-Current/ Over-Temperature Protection COUT 1µF BYPASS GND CBYPASS 0.01µF AS13985 GND www.austriamicrosystems.com Revision 1.13 8 - 12 AS13985 Datasheet - P a c k a g e D r a w i n g s a n d M a r k i n g s 9 Package Drawings and Markings The AS13985 is available in a 5-bump WLP package and a 5-pin SOT23 package. Figure 14. 5-bump WLP Package www.austriamicrosystems.com Revision 1.13 9 - 12 AS13985 Datasheet - P a c k a g e D r a w i n g s a n d M a r k i n g s Figure 15. 5-pin SOT23 Package Notes: 1. All dimensions are in millimeters. 2. Foot length is measured at the intercept point between datum A and lead surface. 3. Package outline exclusive of mold flash and metal burr. 4. Package outline inclusive of solder plating. 5. Complies with EIAJ SC74. Symbol A A1 A2 b C D E E1 L e e1 α Min Max 0.90 1.45 0.00 0.15 0.90 1.30 0.30 0.50 0.09 0.20 2.80 3.05 2.60 3.00 1.50 1.75 0.30 0.55 0.95 Ref 1.90 Ref 0º 8º www.austriamicrosystems.com Revision 1.13 10 - 12 AS13985 Datasheet - O r d e r i n g I n f o r m a t i o n 10 Ordering Information The AS13985 is available as the standard versions listed in Table 4. Other versions are available upon request. For more information and inquiries contact http://www.austriamicrosystems.com/contact Table 4. Ordering Information Ordering Code Marking Description Delivery Form Package AS13985F33-T AS13985F30-T AS13985F29-T AS13985F28-T AS13985F27-T AS13985F18-T AS13985F12-T AS13985H33-T AS13985H30-T AS13985H29-T AS13985H28-T AS13985H27-T AS13985H18-T AS13985H12-T ASKK ASKJ ASKI ASLE ASKL ASKM ASKN ASK0 ASK1 ASK2 ASLF ASK3 ASK4 ASK5 3.3V LDO, 150mA 3.0V LDO, 150mA 2.9V LDO, 150mA 2.8V LDO, 150mA 2.7V LDO, 150mA 1.8V LDO, 150mA 1.2V LDO, 150mA 3.3V LDO, 150mA 3.0V LDO, 150mA 2.9V LDO, 150mA 2.8V LDO, 150mA 2.7V LDO, 150mA 1.8V LDO, 150mA 1.2V LDO, 150mA Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel Tape and Reel 5-bump WLP 5-bump WLP 5-bump WLP 5-bump WLP 5-bump WLP 5-bump WLP 5-bump WLP 5-pin SOT23 5-pin SOT23 5-pin SOT23 5-pin SOT23 5-pin SOT23 5-pin SOT23 5-pin SOT23 Note: All products are RoHS compliant and Pb-free. Buy our products or get free samples online at ICdirect: http://www.austriamicrosystems.com/ICdirect For further information and requests, please contact us mailto:sales@austriamicrosystems.com or find your local distributor at http://www.austriamicrosystems.com/distributor www.austriamicrosystems.com Revision 1.13 11 - 12 AS13985 Datasheet Copyrights Copyright © 1997-2009, austriamicrosystems AG, Tobelbaderstrasse 30, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered ®. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. All products and companies mentioned are trademarks or registered trademarks of their respective companies. Disclaimer Devices sold by austriamicrosystems AG are covered by the warranty and patent indemnification provisions appearing in its Term of Sale. austriamicrosystems AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein or regarding the freedom of the described devices from patent infringement. austriamicrosystems AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with austriamicrosystems AG for current information. This product is intended for use in normal commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by austriamicrosystems AG for each application. For shipments of less than 100 parts the manufacturing flow might show deviations from the standard production flow, such as test flow or test location. The information furnished here by austriamicrosystems AG is believed to be correct and accurate. However, austriamicrosystems AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of austriamicrosystems AG rendering of technical or other services. Contact Information Headquarters austriamicrosystems AG Tobelbaderstrasse 30 A-8141 Unterpremstaetten, Austria Tel: +43 (0) 3136 500 0 Fax: +43 (0) 3136 525 01 For Sales Offices, Distributors and Representatives, please visit: http://www.austriamicrosystems.com/contact www.austriamicrosystems.com Revision 1.13 12 - 12
AS13985F29-T 价格&库存
很抱歉,暂时无法提供与“AS13985F29-T”相匹配的价格&库存,您可以联系我们找货
