RVJ
GREEN
CAP
Chip Type, 105˚C Use, Large Capacitance Capacitors
RVJ
CHIP TYPE
ALUMINUM ELECTROLYTIC
VERTICAL CHIPVERTICAL
TYPE ALUMINUM
ELECTROLYTIC
CAPACITORS CAPACITORS
Compatible with surface mounting.
Supplied with carrier taping.
Guarantees 2000 hours at 105℃.
(φ12.5×13.5L:5000 hours at 105℃)
105˚C
SMD
2000hours
Anticleaning
solvent
RVJ
High temperature
RV
Marking color : Black print (φ8×6.5L)
White print on a brown sleeve (φ8×10L ‒ φ12.5×13.5L)
Specifications
Performance
−55 to +105
±20
Less than 0.01CV or 3 whichever is larger (after 2 minutes) C : Rated capacitance (µF) ; V : Rated voltage (V)
Item
Category temperature range (℃)
Tolerance at rated capacitance (%)
Leakage current (µA)
Rated voltage (V)
tanδ (max.)
Tangent of loss angle
(tanδ)
6.3
0.30
10
0.24
16
0.22
25
0.16
35
0.13
50
0.12
(20℃,120Hz)
(20℃)
63
0.11
100
0.10
(20℃,120Hz)
6.3
4
8
Impedance ratio (max.)
10
3
5
16
2
4
25
2
3
35
2
3
50
2
3
63
2
3
100
2
3
(120Hz)
2000 hours (φ12.5×13.5L:5000 hours)
The initial specified value or less
Within ±20% of initial value
200% or less of the initial specified value
Test time
Leakage current
Percentage of capacitance change
Tangent of the loss angle
Endurance (105℃)
(Applied ripple current)
Shelf life (105℃)
Test time : 1000 hours ; other items are the same as those for the endurance. Voltage application treatment : According to JIS C5101-1
Applicable standards
JIS C 5101-1 1998, -18 1999 (IEC 60384-1 1992, -18 1993)
Outline Drawing
Coefficient of Frequency for Rated Ripple Current
Unit : mm
φ8,φ10
Frequency (Hz)
0.3MAX
50 ・ 60
120
1k
10k ・ 100k
6.3 to 16
25 to 35
50 to 63
100
0.80
0.80
0.80
0.70
1
1
1
1
1.15
1.25
1.35
1.35
1.25
1.40
1.50
1.50
Frequency (Hz)
Rated
capacitance(µF)
120
1k
10k
100k
47
100 to 220
330 to 1000
0.50
0.70
0.80
0.76
0.85
0.93
0.87
0.90
0.98
1
1
1
Rated voltage (V)
(P)
B±0.2
φD±0.5
(C)
M
A±0.2
(C)
φ12.5
W
L
( ) : Reference size
L
φD
B
A
8.4
8 6.5±0.3
8.4
10±0.5
8.4
8
8.4
10±0.5 10.4 10.4
10
12.5 13.5±0.5 13.0 13.0
C
3.4
3.0
3.3
4.9
M
0.4±0.2
0.4±0.2
0.4±0.2
0.7±0.3
P
2.3
3.1
4.7
1.0 to 1.4 4.6
W
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
Casing symbol
G68
G10
H10
ⅠE
Part numbering system
φ8,φ10
(16V470µF)
RVJ
Soldering conditions are described on page 13.
Land pattern size are described on page 11.
The taping specifications are described on page 14.
Rated
capacitance
(µF)
6.3
φD×L(mm)
Casing
symbol
10
Rated
ripple
current
Case
(mArms) φD×L(mm)
Casing
symbol
16
Rated
ripple
current
Case
(mArms) φD×L(mm)
Casing
symbol
25
Rated
ripple
current
Case
(mArms) φD×L(mm)
Casing
symbol
10
35
Rated
ripple
current
Case
(mArms) φD×L(mm)
Casing
symbol
22
33
8×6.5
G68
110
8×6.5
G68
110
8×10
G10
178
10×10
H10
324
100
8×6.5
G68
110
8×6.5
G68
110
8×10
G10
178
8×6.5
G68
110
8×10
G10
178
Case
(mArms) φD×L(mm)
M
H10 U ̶
102
M
Taping
symbol
Casing
symbol
Casing
symbol
T̶
Case
(mArms) φD×L(mm)
8×6.5
G68
110
8×10
G10
8×10
G10
8×10
G10
178
10×10
H10
324
Casing
symbol
R5
Taping
symbol
Casing
symbol
63
Rated
ripple
current
ⅠE
Rated capacitance
Capacitance
symbol
tolerance symbol
50
Rated
ripple
current
10
47
471
Rated capacitance
Capacitance
symbol
tolerance symbol
V
Rated voltage
symbol
Series code
Standard Ratings
Item Case
V
φ12.5
(10V1000µF)
RVJ
Rated voltage
(V)
16
Rated voltage
symbol
Series code
100
Rated
ripple
current
Case
(mArms) φD×L(mm)
Casing
symbol
Rated
ripple
current
(mArms)
8×10
G10
67
8×10
G10
99
10×10
H10
133
178
10×10
H10
160
10×10
H10
133
178
10×10
H10
160
12.5×13.5
ⅠE
475*
12.5×13.5
ⅠE
577*
220
8×10
G10
178
8×10
G10
178
10×10
H10
324
10×10
H10
324
10×10
H10
324
12.5×13.5
ⅠE
655*
330
8×10
G10
178
10×10
H10
324
10×10
H10
324
10×10
H10
324
12.5×13.5
ⅠE
747*
470
10×10
H10
324
10×10
H10
324
10×10
H10
324
12.5×13.5
ⅠE
747* 12.5×13.5
ⅠE
747*
10×10
H10
324
10×10
H10
324
12.5×13.5
ⅠE
747* 12.5×13.5
ⅠE
747*
1000
12.5×13.5
ⅠE
747*
NOTE : Design,
Specifications are subject to change without notice.
It is recommended that you shall obtain technical specifications
from ELNA to ensure that the component is suitable for your use.
61
(Note) Rated ripple current : 105℃, 120Hz
(Note*) Rated ripple current : 105℃, 100kHz
CAT.No.2015/2016E
CHIP
ALUMINUM
Rated voltage (V)
Z−25℃/Z+20℃
Z−40℃/Z+20℃
Characteristics at high
and low temperature
很抱歉,暂时无法提供与“RVJ-100V220MH10U-R”相匹配的价格&库存,您可以联系我们找货
