VERTICAL CHIP TYPE ALUMINUM ELECTROLYTIC CAPACITORS
&KLS7\SH&8VH/DUJH&DSDFLWDQFH&DSDFLWRUV
Compatible with surface mounting.
For Vibration resistance.
Supplied with carrier taping.
Guarantees 2000 hours at 105°
C.
Ý&
9LEUDWLRQ
60'
5HVLVWDQFH KRXUV
RTJ
$QWL
FOHDQLQJ
VROYHQW
RTJ
RVJ
Marking color : White print on a brown sleeve
6SHFLILFDWLRQV
Performance
ー55 to +105
±20
Less than 0.01CV or 3 whichever is larger (after 2 minutes) C : Rated capacitance (µF) ; V : Rated voltage (V)
Item
Category temperature range (℃)
Tolerance at rated capacitance (%)
Leakage current (µA)
Rated voltage (V)
tanδ (max.)
Tangent of loss angle
(tanδ)
6.3
0.30
10
0.26
16
0.22
25
0.16
35
0.13
50
0.12
(20℃,120Hz)
(20℃)
63
0.11
100
0.10
(20℃,120Hz)
Rated voltage (V)
Characteristics at high
16
2
4
25
2
3
35
2
3
50
2
3
63
2
3
100
2
3
(120Hz)
Test time
Leakage current
Percentage of capacitance change
Tangent of the loss angle
Endurance (105℃)
(Applied ripple current)
2000 hours
The initial specified value or less
Within ±20% of initial value
200% or less of the initial specified value
Shelf life (105℃)
Test time : 1000 hours; other items are the same as those for the endurance. Voltage application treatment : According to JIS C5101-1
Applicable standards
JIS C5101-1 1998, -18 1999 (IEC 60384-1 1992, -18 1993)
2XWOLQH'UDZLQJ
Coefficient of Frequency for Rated Ripple Current
Unit : mm
Frequency (Hz)
0.4±0.2
0.3MAX
Rated voltage (V)
(C)
A
B
L
10±0.5 8.4 8.4
8
10 10.5±0.5 10.4 10.4
10k・100k
0.80
0.80
0.80
0.70
1
1
1
1
1.15
1.25
1.35
1.35
1.25
1.40
1.50
1.50
Part numbering system (example: 25V220µF)
RTJ
W1
(P2)
φD
1k
(P1)
W2
B±0.2
φD±0.5
(W3)
L
120
6.3 to 16
25 to 35
50 to 63
100
(C)
A±0.2
50・60
W1
C
W2
3.0 0.7 to 1.1 1.5±0.2
3.3 0.7 to 1.1 1.5±0.2
P1
3.1
4.7
25
V
Rated voltage
symbol
Series code
( ) : Reference size
W3
2.0
3.0
221
M
Rated capacitance
symbol
Capacitance
tolerance symbol
H11 U ̶
Casing
symbol
Taping
symbol
P2 Casing symbol
G10
4.4
H11
4.4
Soldering conditions are described on page 13.
Land pattern size are described on page 11.
The taping specifications are described on page 14.
Standard Ratings
Rated voltage
Rated
capacitance
(µF)
φD(mm)
Casing
symbol
16
10
6.3
(V)
Item Case
ESR
Rated
ripple
current
Case
(Ω)(mArms)φD(mm)
Casing
symbol
ESR
Rated
ripple
current
Case
(Ω)(mArms)φD(mm)
Casing
symbol
35
25
ESR
Rated
ripple
current
Case
(Ω)(mArms)φD(mm)
Casing
symbol
ESR
Rated
ripple
current
Case
(Ω)(mArms)φD(mm)
Casing
symbol
50
ESR
Rated
ripple
current
Case
(Ω)(mArms)φD(mm)
Casing
symbol
100
63
ESR
Rated
ripple
current
Case
(Ω)(mArms)φD(mm)
Rated
ripple
current
Case
(Ω)(mArms)φD(mm)
ESR
Rated
ripple
current
(Ω)(mArms)
22
̶ 8×10 G10 8.3 99
33
̶ 8×10 G10 6.0 178
10×10.5
H11 5.5 160
47
̶ 8×10 G10 4.6 178 8×10 G10 4.2 178
10×10.5
H11 3.9 160
100
̶ 8×10 G10 3.6 178 8×10 G10 2.7 178
10×10.5
H110.98 324
Casing
symbol
H11 2.2 324
ESR
10
10×10.5
Casing
symbol
̶ 8×10 G10 16.6 67
10×10.5
H11 7.5 133
H11 2.0 324
220
8×10 G10 2.3 178 8×10 G10 2.0 178
10×10.5
H11 1.7 324
10×10.5
H11 1.2 324
10×10.5
330
8×10 G10 1.5 178
10×10.5
H11 1.3 324
10×10.5
H11 1.1 324
10×10.5
H110.80 324
470
10×10.5
H11 1.0 324
10×10.5
H110.92 324
10×10.5
H110.78 324
(Note) Rated ripple current : 105℃, 120Hz ; ESR : 20℃, 120Hz
NOTE
Design, Specifications are subject to change without notice.
Ask factory for technical specifications before purchase and/or use.
77
CAT.No.2013/2014E
Chip Type
Aluminum Electrolytic Capacitors
and low temperature
10
3
5
6.3
4
8
Z−25℃/Z+20℃
Z−40℃/Z+20℃
Impedance ratio (max.)
很抱歉,暂时无法提供与“RTJ-16V331MH11U-R2”相匹配的价格&库存,您可以联系我们找货
