RYK
RYK
HORIZONTAL
CHIP
TYPE
ALUMINUM
ELECTROLYTIC
CAPACITORS
HORIZONTAL
CHIP
TYPE
ALUMINUM
ELECTROLYTIC
CAPACITORS
Horizontal Type, 125°C Use, For Vibration Capacitors
125°
C high temperature surface mount.
Highly resistant to vibration.
Available in horizontal configurations only.
Supplied with carrier taping.
Guarantees 1000 hours at 125°
C.
125˚C
Vibration
SMD
Resistance 1000hours
Anticleaning
solvent
Horizontal type
Large capacitance
RYK
RVK
Marking color : White print on a black case
Specifications
Item
Performance
ー40 to +125
±20
Less than 0.02CV (after 2 minutes) C : Rated capacitance (µF) ; V : Rated voltage (V)
Category temperature range (℃)
Tolerance at rated capacitance (%)
Leakage current (µA)
Rated voltage (V)
tanδ (max.)
Tangent of loss angle
(tanδ)
6.3
0.30
10
0.28
16
0.26
25
0.24
(20℃,120Hz)
(20℃)
35
0.20
50
0.19
63
0.18
(20℃,120Hz)
Rated voltage (V)
Characteristics at high
Impedance ratio (max.)
CHIP
ALUMINUM
and low temperature
Zー25℃/Z+20℃
Zー40℃/Z+20℃
6.3
3
5
10
3
5
16
3
5
25
3
5
35
3
5
50
3
5
63
3
5
(120Hz)
Endurance (125℃)
(Applied ripple current)
Shelf life (125℃)
Test time
Leakage current
Percentage of capacitance change
Tangent of the loss angle
1000 hours
The initial specified value or less
Within ±30% of initial value
300% or less of the initial specified value
Test time
Leakage current
500 hours
Within ±20% of initial value
200% or less of the initial specified value
Pretreatment performed
JIS C5101-1 1998, -18 1999 (IEC 60384-1 1992, -18 1993)
Applicable standards
Outline Drawing
Unit : mm
H1 H0
H
0.1+0.2
−0
L
L1
F
W
0.1±0.05
6.5
0.1±0.05
6.5
F
L0
Case size
W
L0
9.5×24
9.5±0.5
24±1
L1
L
H
F
H1
H0
21±0.5 22±0.5 9.3±0.5 9.3±0.5 9.1±0.3 3.5±0.5
10
Rated voltage
symbol
Series code
V
561
Case size
W
L0
9.5×19
9.5±0.5
19±1
Land pattern size are described on page 12.
M
G5T T ̶
Rated capacitance
Capacitance
symbol
tolerance symbol
L1
L
H
H1
H0
F
16±0.5 17±0.5 9.3±0.5 9.3±0.5 9.1±0.3 3.5±0.5
The taping specifications are described on page 13.
Coefficient of Frequency for Rated Ripple Current
Part numbering system (example: 10V560µF)
W
L0
Soldering conditions are described on page 11.
RYK
H1 H0
10
2.0±0.5
L
L1
2.0±0.5
0.1±0.05
Case Size : 9.5×19.0
■ 6 terminals type : Casing symbol G4
1.5±0.3
0.1+0.2
−0
0.1±0.05
H
1.5±0.3
Case Size : 9.5×24.0
■ 8 terminals type : Casing symbol G5T
Casing
symbol
Frequency (Hz)
Rated voltage (V)
10 to 63
FL
Tray polarity
symbol
120
1k
10k
100k
0.77
0.88
0.96
1
Standard Ratings
6.3
Rated voltage
(V)
Item
Rated
capacitance
(µF)
Case
ripple
Impedance Rated
current
Case
10
ripple
Impedance Rated
current
Case
25
16
ripple
Impedance Rated
current
Case
50
35
ripple
Impedance Rated
current
Case
ripple
Impedance Rated
current
Case
63
ripple
Impedance Rated
current
Case
ripple
Impedance Rated
current
W×L (mm) (Ω max.) (mArms) W×L (mm) (Ω max.) (mArms) W×L (mm) (Ω max.) (mArms) W×L (mm) (Ω max.) (mArms) W×L (mm) (Ω max.) (mArms) W×L (mm) (Ω max.) (mArms) W×L (mm) (Ω max.) (mArms)
56
9.5×19.0
0.52
204
82
9.5×19.0
0.49
210
9.5×24.0
0.37
272
100
9.5×19.0
0.40
232
9.5×24.0
0.35
279
220
9.5×19.0
0.40
232
9.5×24.0
0.30
302
270
9.5×19.0
0.40
232
9.5×24.0
0.30
302
470
9.5×19.0
0.40
232
9.5×24.0
0.30
302
560
9.5×19.0
0.40
232
9.5×24.0
0.30
302
820
9.5×24.0
0.30
302
(Note) Rated ripple current : 125℃, 100kHz ; Impedance : 20℃, 100kHz
CAT.No.2015/2016E
88
NOTE : Design, Specifications are subject to change without notice.
It is recommended that you shall obtain technical specifications
from ELNA to ensure that the component is suitable for your use.
很抱歉,暂时无法提供与“RYK-16V471MG5TT-FL”相匹配的价格&库存,您可以联系我们找货
