Bussmann®
AMI SERIES
DIMENSIONS
(Dims. shown are for reference only. Consult factory for latest prints)
41.0
(1.61)
30.0
(1.18)
16.0
(0.63)
9.5
12.0
(0.37) (0.47)
Ø5.5
(Ø0.22)
0.8
(0.03)
6.0
(0.24)
*Consult factory for higher voltage fuses.
TIME-CURRENT SPECIFICATIONS
Opening Time
% of
Rating
Minimum
Maximum
BOLT-IN FUSE PROTECTION
34
100
110
150
200
300
500
100 hrs
4 hrs
90 s
5s
0.3 s
0.1 s
80
100
AMPERE RATING
10000
1000
TIME IN SECONDS
SPECIFICATIONS:
Applications: Power distribution protection for
automotive systems. Consult factory for available fuseholders.
Current Rating: 30-150A.
Voltage Rating: 32VDC.*
Interrupt Rating: 2000A @ 32VDC.
Housing Material: UL-Rated 94V-0 thermoplastic.
Terminal Material: Tin-plated brass.
Mounting: Max torque of 35in-lb (4Nm).
Marking: Color-coded housings for each amperage.
50
BOLT IN AUTOMOTIVE FUSES
100
10
1
.01
3600 s
100 s
10 s
1s
0.01
10
100
1000
CURRENT IN AMPERES
PART NUMBERING SYSTEM
Series
Rating
B K / A M I
030 – 30 amps (orange)
040 – 40 amps (lt. green)
050 – 50 amps (red)
060 – 60 amps (yellow)
070 – 70 amps (brown)
080 – 80 amps (white)
100 – 100 amps (blue)
125 – 125 amps (pink)
150 – 150 amps (gray)
Cooper Bussmann Transportation Products • Phone: 1-888-867-8194 • Website: http://www.coopertp.com
10000
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Eaton:
AMI-80 AMI-50 AMI-40 BK/AMI-100 BK/AMI-030 BK/AMI-060 BK/AMI-080 BK/AMI-070 BK/AMI-125 AMI-125
AMI-30 BK/AMI-050 BK/AMI-040 BK/AMI-200 BK/AMI-150 BK/AMI-175
很抱歉,暂时无法提供与“BK/AMI-030”相匹配的价格&库存,您可以联系我们找货
