PC Board Fuses -
Sub Miniature with Leads
GFA, GLN and GLX Series
Catalog Symbol: GFA
Sub Miniature with Axial Leads
Non Time-Delay
0.145˝ x 0.300˝ (3.7mm x 7.6mm)
Interrupting Rating: 50 AIC
Agency Approvals:
UL Recognized, (1⁄2-5A) Guide JDYZ2, File 19180
CSA Certified, (1⁄2-5A) File 53787, Class 1425-01
Catalog Symbol: GLN
Sub Miniature with Radial Leads
Non Time-Delay
Electrical Ratings (Catalog Symbol and Amps)
125 Volts AC
125 Volts AC
Amps
Test
Spec.
Color Code
(Opp. Ends)
Amps
Test
Spec.
Color Code
(Opp. Ends)
GLN-1⁄100
A
Red
Orn
GLN-1⁄10
A
Red
Red
GLN- ⁄32
A
Red
Brn
GLN-3⁄10
A
Grn
Grn
GLN-1⁄20
A
Yel
Yel
GLN-4⁄10
A
Blu
Blu
GLN-1⁄16
A
Brn
Brn
Amps
Test
Spec.
Color Code
(Opp. Ends)
Grn
GLN-10
A
Yel
Blk
Amps
Test
Spec.
Color Code
(Opp. Ends)
Amps
Test
Spec.
Color Code
(Opp. Ends)
GFA-1⁄200
A
Red
Blk
GFA-3⁄10
A
Grn
Grn
GFA- ⁄100
A
Red
Orn
GFA- ⁄10
A
Blu
Blu
GFA- ⁄64
A
Red
Grn
GFA- ⁄2
B
Orn
Grn
GFA-1⁄50
A
Red
Wht
GFA-6⁄10
B
Orn
Blu
GFA-1⁄32
A
Red
Brn
GFA-3⁄4
B
Orn
Pur
32 Volts AC
GFA- ⁄20
A
Yel
Yel
GFA-1
B
Yel
Grn
Amps
GFA- ⁄16
A
Brn
Brn
GFA-1 ⁄2
B
Yel
Pur
Test
Spec.
Color Code
(Opp. Ends)
GFA-1⁄10
A
Red
Red
GFA-2
B
Grn
Blu
GLN-7
A
Pur
GFA-1⁄8
A
Orn
Orn
GFA-2 1⁄2
B
Grn
Brn
GLN-8
A
Grn
GFA-15⁄100
B
Red
Yel
GFA-3
B
Blu
Pur
GFA-2⁄10
B
Red
Blu
GFA-4
B
Pur
Brn
GFA-1⁄4
B
Red
Pur
GFA-5
B
Brn
Blk
Test
Spec.
Color Code
(Opp. Ends)
Amps
Test
Spec.
Color Code
(Opp. Ends)
GFA-7
A
Pur
Grn
GFA-12
A
Blk
Blu
GFA-8
A
Grn
Blk
GFA-15
A
Blk
Pur
GFA-10
A
Yel
Brn
1
1
1
1
4
1
1
32 Volts AC
Amps
Test Specifications
Wire Lead Size
Load
“A”
100%
4 hrs. (min.)
24
1
150%
10 sec. (max.)
18
6 to 12A
200%
10 sec.
16
15A
“B”
No.
Fuse
⁄200 to 5A
Carton Quantity and Weight
⁄200–15
*Weight per carton.
1
Test Specifications
Weight*
Carton
Qty.
Lbs.
Kg.
100
0.171
52.6
Wire Lead Size
Load
“A”
“B”
No.
Fuse
110%
4 hrs. (min.)
24
1
150%
*10 sec. (max.)
18
6A to 10A
200%
*10 sec.
BU-SB12568
⁄200 to 5A
*Maximum time.
⁄100–10
*Weight per carton.
1
Weight*
Carton
Qty.
Lbs.
Kg.
100
0.171
52.6
General Information:
• Glass tube fuses for protection of subminiature devices.
• Tinned radial leads spaced for easy assembly on printed
circuit chassis.
• Withstand high-shock and vibration.
• Color-coded for amp rating.
• Radial leads (1 1⁄2˝ ) can be fed through wire forming machine.
• Tinned wire leads solder into circuit.
• Axial leads (1 1⁄2˝ ) can be fed through wire forming machine.
0712
Brn
Opening Time
Amp
Ratings
Opening Time
Amp
Ratings
1
Page 1 of 2
Data Sheet 2035
PC Board Fuses -
15
AMP
RATING
ATING
1-⁄Ω™
2
3
4
5
7
8
10
‹Ω¢
1
flꭧ
⁄Ω¢
‹Ω¡º
›Ω¡º
⁄Ω¡º
⁄Ω•
⁄Ω£™
⁄Ω™º
⁄Ω™
Time-Current Characteristics–Total Clear
100
Catalog Symbol: GLX
Non-Time-Delay
10
Amps
Test
Spec.
Color Code
(Opp. Ends)
Amps
Test
Spec.
Color Code
(Opp. Ends)
GLX-1⁄4
B
Red
Pur
GLX-2
B
Grn
Blu
GLX-1⁄2
B
Orn
Grn
GLX-3
B
Blu
Pur
GLX-3⁄4
B
Orn
Pur
GLX-4
B
Pur
Brn
GLX-1
B
Yel
Grn
GLX-5
B
Brn
Blk
GLX-1 1⁄2
B
Yel
Pur
TIME IN SECONDS
125 Volts AC
1
Wire Lead Size
No.
Fuse
24
1
⁄200 to 5A
.1
52.6
.01
circuit chassis.
• Color-coded for ampere rating.
30
0.171
10
Kg.
100
1
Lbs.
.1
⁄4–5
*Weight per carton.
1
Weight*
Carton
Qty.
.04
Amp
Ratings
CURRENT IN AMPS
The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this BIF document are by definition uncontrolled.This bulletin is intended to
clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any
products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
0712
BU-SB12568
Page 2 of 2
Data Sheet 2035
很抱歉,暂时无法提供与“GFA-7”相匹配的价格&库存,您可以联系我们找货
