Bussmann®
Telpower Indicating Fuse and Holder
70 Series
300 Volts DC – 1/10-10A
Dimensional Data
1.86"
.28"
(47.4mm)
CATALOG SYMBOLS: FUSE – 70 SERIES;
FUSEHOLDER – 15087 (see page 2)
300 VOLTS DC; 125 VOLTS AC
U.L. RECOGNIZED (GUIDE #JDYX2, FILE #E19180)
(7.1mm)
• Visual indicating fuse.
• Fiber tube design, color code for ampere rating.
Test Specification
Percent
Overload
Catalog Numbers
Catalog Number
70P-1/10A
70H-3/4A
70L-6A
70R-15/100A
70I-1A
70M-8A
70E-18/100A
70A-1-1/3A
70N-10A
Opening
Time
70A, 70B, 70C, 70D
70X-2/10A
70B-2A
GKB-10A
70F-1/4A
70C-3A
72A-DUMMY
70K-1/4A
70J-3-1/2A
72B-DUMMY
70G-1/2A
70D-5A
70E, 70F, 70G, 70H
150%
0-90 sec.
70K
160%
0-300 sec.
70P
200%
0-300 sec.
70R
267%
0-300 sec.
1/10
125V
300V
Gray/Wh
100203413
KS23751-L10
70R-15/100A* 15/100
125V
300V
Red/Wh
101384550
KS23751-L11
70E-18/100A* 18/100
125V
300V
Yellow
100203363
KS23751-L5
70X-2/10A
2/10
125V
300V
Black
70F-1/4A*
1/4
125V
300V
Violet
100203371
KS23751-L6
70K-1/4A*
1/4
125V
300V
Violet/Wh
100203405
KS23751-L9
70G-1/2A*
1/2
125V
300V
Red
100203389
KS23751-L7
KS23751-L8
70H-3/4A*
3/4
125V
300V
Brown
100203397
70I-1A
1
125V
300V
Pink
70A-1-1/3A*
1-1/3
125V
300V
White
100203322
KS23751-L1
70B-2A*
2
125V
300V
Orange
100203330
KS23751-L2
70C-3A*
3
125V
300V
Blue
100203348
KS23751-L3
70J-3-1/2A
3-1/2
125V
300V
Black/Wh
70D-5A*
5
125V
300V
Grn/Blk
100203355
KS23751-L4
70L-6A
6
125V
300V
Grn/Wh
70M-8A
8
125V
300V
Brown/Wh
70N-10A
10
125V
300V
Violet/Yel
GKB-10A
10
125V
300V
Violet/Yel
72A
Plastic Case
Dummy
100203421
72B
Blister Pack
Dummy
103757977
70B
70C
70D
GKB-10A
70P-1/10A*
AT&T Comcode Code/
Ref. No.
List No.
70H
70A
Ampere Voltage Rating Color
Rating AC
DC
Code
AMPERE
RATING
100
10
TIME IN SECONDS
Catalog
Number
70E
70F
70 SERIES TELPOWER (300 Volts DC, 125 Volts AC)
70G
Time-Current Characteristic Curves–Average Melt
1
.1
CURRENT IN AMPERES
12-16-98
SB98107 Rev. A
100
10
.1
.01
1
* Product designed to comply with Bellcore Technical Reference TR-TSY-000799
Issue 1, December 1988.
Form No.70 Series
Page 1 of 2
BIF Doc #5007
Bussmann®
Telpower
70 Series
70 Type Indicating Fuse and Holder
300 Volts DC
Dimensional Data
.97"
1.88"
.78"
(24.6mm)
(47.6mm)
(19.8mm)
.47"
.9"
(11.9mm)
(22.9mm)
Eyelet (Optional)
CATALOG SYMBOL: 15087 FUSEHOLDER
300 VOLT DC, 12 AMP
U.L. RECOGNIZED (GUIDE #IZLT2, FILE #E14853)
Mounting
Holes
.50"
(12.7mm)
45°
.83" Dia.
Materials:
Body:
Terminals:
Screws:
.16"
(21.0mm)
Thermosplastic, U.L. 94VO flammability rating
Copper alloy, tin plating
3-24 x 3/8” steel, zinc plated
1"
(25.4mm)
(3.9mm)
.91"
(23.0mm)
NOTE: Optional color coded eyelet for 15087 holder is available.
• Panel mount fuseholder for 70 Type fuses supplied with
two screws.
• Remote alarm capability.
Optional Color Code Eyelets (order separately)
Catalog
Symbol
Amp
Rating
Ref.
Color
Code
Catalog
Symbol
Amp
Rating
Ref.
Color
Code
1A1706-01
18/100
Yellow
1A1706-10
3
Blue
1A1706-02
2/10
Black
1A1706-11
5
Green/Black
1A1706-03
1/4
Violet
1A1706-12
6
Green/White
1A1706-04
1/4
Violet/White
1A1706-13
8
Brown/White
1A1706-05
1/2
Red
1A1706-14
10
Violet/Yellow
1A1706-06
3/4
Brown
1A1706-15
1/10
Gray/White
1A1706-07
1
Pink
1A1706-16
3-1/2
Black/White
1A1706-08
1-1/3
White
1A1706-17
15/100
Red/White
1A1706-09
2
Orange
The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this BIF document are by definition uncontrolled. This bulletin is intended to
clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any
products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
12-16-98
SB98107 Rev. A
Form No. 70 Series
Page 2 of 2
BIF Doc #5007
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Eaton:
70H-3/4A 70I-1A 70L-6A 70X-2/10A 70N-10A 70F-1/4A 70J-3-1/2A 1A1706-01 1A1706-02 1A1706-03 1A170604 1A1706-05 1A1706-06 1A1706-08 1A1706-09 1A1706-10 1A1706-11 1A1706-12 1A1706-13 1A1706-14
1A1706-16 1A1706-17 BK/70L-6A BK/70N-10A 70P-1/10A
很抱歉,暂时无法提供与“BK/70L-6A”相匹配的价格&库存,您可以联系我们找货
