TPM-20
TPM-20
    EATON(伊顿)
    TPM20AMPFUSE
TPM-20 数据手册
Telpower® DC Power Protection Systems Bussmann® TPM & TPMDS Telpower® Miniature Fused Disconnect Switch General Information: TPM & TPMDS Telpower® TPMDS Miniature Fused Disconnect Switch TPM - Telpower® Miniature Fuse - Current Limiting Ampere Ratings: 3-30A Voltage Rating: 80VDC Interrupting Rating: 20,000A Agency Information: UL Recognized (investigated to UL 1801) as a disconnect switch for the interruption of load current by means of withdrawing the fuse pullout. Recognized to U.S. and Canadian requirements under the component recognition program of Underwriters Laboratories Inc. Files E219046 and E56412. Catalog Number TPM-3 TPM-4 TPM-5 TPM-6 TPM-7 TPM-8 TPM-10 TPM-12 TPM-15 TPM-20 TPM-25 TPM-30 TPMDS-E TPMDS-M Description Miniature Fuse Miniature Fuse Miniature Fuse Miniature Fuse Miniature Fuse Miniature Fuse Miniature Fuse Miniature Fuse Miniature Fuse Miniature Fuse Miniature Fuse Miniature Fuse Miniature Disconnect, English Miniature Disconnect, Metric Ampere Rating 3A 4A 5A 6A 7A 8A 10A 12A 15A 20A 25A 30A 3-30A 3-30A • Smallest and most versatile fused disconnect switch available. • Small size allows for assembly into 1 U (1.75 inch / 44.5 mm) panel. • AmpColor ID™ System for easy fuse replacement. • Switch design provides for easy panel mounting by single captive 4-40 (M3) nut and panel notch integral to switch footprint. • Local and remote open fuse indication. Local alarm indication provided by LED on TPM fuse. • Current-limiting capability • Complete system coordination capability • Load connection: 1/4 inch quick-connect or bolted connection with 10-32 (M5) captive nut. • Line connection: 1/4 inch quick-connect or screw connection with clearance hole for #10 (M5) bolt. • Maximum alarm circuit current: 20 mA • Materials: Fuse housing - black thermoplastic, UL 94 V-0, 170ºC RTI Switch housing - black thermoplastic, UL 94 V-0, 140ºC RTI CE logo denotes compliance with European Union Low Voltage Directive (50-1000VAC, 75-1500VDC). Refer to Data Sheet: 8002 or contact Bussmann Application Engineering at 636-527-1270 for more information. TPM Alarm Schematic NOTES: 1. The resistance, R, must be provided by the end-user to limit the alarm output current to a maximum of 20 mA. The value, R, should be calculated using the system voltage value. If remote alarm functionality is not required, the END-USER CIRCUITRY must still be supplied to provide a resistive path to the return for the local alarm to properly function. 2. The fuse is polarized to maintain proper orientation with the switch housing. The line and load terminals are identified on the switch housing. • The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Look for Telpower® BLUE™ fuses exclusively from Cooper Bussmann. 11-13-02 SB02302 Form No. TPM & TPMDS Page 1 of 4 Data Sheet: 5022 Telpower® DC Power Protection Systems Telpower® Miniature Fused Disconnect Switch Bussmann® TPM & TPMDS TPM & TPMDS - Dimensional Data Look for Telpower® BLUE™ fuses exclusively from Cooper Bussmann. 11-13-02 SB02302 Form No. TPM & TPMDS Page 2 of 4 Data Sheet: 5022 Telpower® DC Power Protection Systems Bussmann® Telpower® Miniature Fused Disconnect Switch TPM & TPMDS AmpColor ID™ System AmpColor ID™ Chart included with each box of ten TPM fuses. TPM Fuses: 3-30A TPC Fuses: 3-125A Reference Data Sheet: 5023 for TPC fuse specifications. Twelve AmpColor ID™ tags included with each box of ten TPM fuses. Telpower’s AmpColor IDTM System Is Easy to Use. Each Amp rating is represented by a specific color. Simply label new or existing panels with the appropriate AmpColor tags and post the AmpColor chart nearby. Personnel can quickly and accurately reference the chart for the appropriate replacement fuse. AmpColor IDTM tags Look for Telpower® BLUE™ fuses exclusively from Cooper Bussmann. 11-13-02 SB02302 Form No. TPM & TPMDS Page 3 of 4 Data Sheet: 5022 Telpower® DC Power Protection Systems Telpower® Miniature Fused Disconnect Switch Bussmann® TPM & TPMDS Time-Current Characteristic Curve–Average Melt Look for Telpower® BLUE™ fuses exclusively from Cooper Bussmann. 11-13-02 SB02302 Form No. TPM & TPMDS Page 4 of 4 Data Sheet: 5022
TPM-20 价格&库存
很抱歉,暂时无法提供与“TPM-20”相匹配的价格&库存,您可以联系我们找货
