TC-25PK4
TC-25PK4
    EATON(伊顿)
    FUSE BOX OF 4 TC-25
TC-25PK4 数据手册
Effective May 2016 Supersedes December 1998 Technical Data 1039 BUSSMANN SERIES Edison base CSA plug fuses – dual-element, time-delay, 125 volts, 15-30 amps Recommended fuse holders Catalog numbers SOU SRU SSU SOW SRW SSW SOX Catalog symbol: • BP/TC - (amps) • TC - (amps)PK4 SRX Description: Type box 2 1/4” handy 2 3/4” handy 4” octagon Catalog numbers SOY SRY SSY SSY-RL STY SCY SOY-B Type box 4” square Single gang SSN Package quantity and weight Bussmann® series CSA Type D, dual-element, time-delay Edison base fuse. Quantity Weight Amp ratings Per box Per card Per box Per 5 cards Specifications: 15 to 30 A 4 3 0.24 1.04 Ratings • Volts — 125 Vac or less Features: • Amps — 15 to 30 A • “D” rating for Canadian applications • Heavy duty, dual-element, time-delay plug fuses • These fuses thread into fuse receptacles or box cover units • Edison base size • Industrial strength, featuring an exclusive dual-element construction • This spring loaded design provides superior short circuit and overload protection • More time-delay than the medium duty Type P fuses in order to better protect industrial motors and optical residential circuits Agency Information • CSA® Certified, Class 1423-01, File 53787 Catalog numbers (amps) TC - 15 TC - 20 TC - 25 TC - 30 Technical Data 1039 Edison base CSA plug fuses dual-element, time-delay, 125 volts, 15–30 amps Effective May 2016 Amp rating 30 300 15 20 Time-current curve – average melt 100 Time in seconds 10 1 10,000 1000 20 0.01 100 0.1 Current in amps The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2016 Eaton All Rights Reserved Printed in USA Publication No. 1039 – SB98107 May 2016 For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Eaton and Bussmann are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. Follow us on social media to get the latest product and support information.
TC-25PK4 价格&库存
很抱歉,暂时无法提供与“TC-25PK4”相匹配的价格&库存,您可以联系我们找货
