TVSS-5-01
TVSS-5-01
    EATON(伊顿)
    FUSE TRANSIENT VOLTAGE
TVSS-5-01 数据手册
Bussmann® Transient Voltage Surge Suppression Limiters TVSS General Information: • Designed to protect TVSS systems per UL 1449 Second Edition Requirements. • Able to withstand 8x20 µSec surge pulses without opening. • Limiters are identified by a surge rating and not continuous current rating. Dimensional Data TVSS-( ) TVSS-( )-01 Catalog Symbol: TVSS Physical Size: Refer to “Dimensional Data” Construction: Melamine Tube Nickel Plated Brass End Caps Voltage Rating: 600Vac Interrupting Rating: 200,000A RMS Sym. Agency Approvals: UL Recognized 600Vac, File E56412 Catalog Symbol and Surge Ratings CATALOG 8x20µS NUMBER SURGE RATING MELTING I2t (A2s) CLEARING I2t (A2s) Ipeak @ 100kA 60 Hz (A) TVSS-5 5,000A 559 1,650 4,283 TVSS-10 10,000A 1,788 5,766 6,618 TVSS-15 15,000A 3,760 9,730 7,843 TVSS-20 20,000A 6,020 14.000 8.594 Above catalog numbers are available with Printed Circuit Board Tabs. When ordering, use suffix “-01”. CE logo denotes compliance with European Union Low Voltage Directive (50-1000Vac, 75-1500Vdc). Refer to Data Sheet: 8002 or contact Bussmann Application Engineering at 636-527-1270 for more information. 9-01-04 SB04303 Recommended fuseblocks/fuseholders for 13/32” x 1-1/2” fuses See Data Sheets listed below • Open fuseblocks - 1104, 2104 • Finger-safe fuseholders - 1109, 1102, 1103, 1151 • Panel-mount fuseholders - 2114, 2113, 2108, • In-line fuseholders - 2127, 2126 Form No. TVSS Page 1 of 3 Data Sheet: 2141 Bussmann® Transient Voltage Surge Suppression Limiters TVSS TVSS-5 TVSS-10 TVSS-20 Time-Current Characteristic Curves–Average Melt AMPERE RATING 300 200 100 TIME IN SECONDS 10 1 .1 2,000 1,000 100 30 20 .01 CURRENT IN AMPERES 9-01-04 SB04303 Form No. TVSS Page 2 of 3 Data Sheet: 2141 Transient Voltage Surge Suppression Limiters TVSS Time-Current Characteristic Curves–Peak Let-Through Current In Amperes x100 Instantaneous Peak Let Thru Current In Amps x100 200 20 15 10 100 5 10 3 2 10 100 1000 3000 RMS Symmetrical Current In Amperes x100 The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 9-01-04 SB04303 Form No. TVSS Page 3 of 3 Data Sheet: 2141
TVSS-5-01 价格&库存
很抱歉,暂时无法提供与“TVSS-5-01”相匹配的价格&库存,您可以联系我们找货
