Technical Data 1043
BUSSMANN
Effective May 2016
Supersedes October 2002
SERIES
Limitron® fast-acting, RK1 – 250 volt fuses
Catalog symbol - KTN-R-(amps)
Description:
Advanced protection Class RK1 current-limiting,
fast-acting fuses.
Specifications:
Dimensions - in:
2"
0.56"
1/10 A to 30 A
3"
0.81"
Ratings
Volts:
250 Vac
35 A to 60 A
5.88"
250 Vdc (70-350 A)
Amps - 1-600 A
1.06"
70 A to 100 A
Interrupting rating:
200 kA Vac RMS Sym.
• 100 kA Vdc
7.13"
Agency Information
UL® Listed, Std. 248-12, Guide JDDZ,
File E54273
CSA® Certified, Class 1422-02, File 53787
CE
1.56"
110 A to 200 A
8.63"
2.06"
225 A to 400 A
10.38"
Features:
Provides 10X better current limitation to help
prevent equipment damage caused by
short-circuit events
200 kA interrupting rating complies with
NEC® Section 110.9 for today’s large capacity
systems
2.59"
450 A to 600 A
Catalog numbers
KTN-R-1
KTN-R-30
KTN-R-125
Fast-acting fuse helps prevent equipment
damage caused by short-circuit events
KTN-R-2
KTN-R-35
KTN-R-150
KTN-R-3
KTN-R-40
KTN-R-175
Incorporates Class R rejection feature. Can
be inserted in non-rejection type fuse holders
to physically and electrically replace Class H,
K1, K5, and other fast-acting fuses
KTN-R-4
KTN-R-45
KTN-R-200
KTN-R-5
KTN-R-50
KTN-R-225
KTN-R-6
KTN-R-60
KTN-R-250
Ideal for critical industrial or commercial
applications that have specific current
limitation requirements
KTN-R-8
KTN-R-70
KTN-R-300
KTN-R-10
KTN-R-75
KTN-R-350
KTN-R-12
KTN-R-80
KTN-R-400
KTN-R-15
KTN-R-90
KTN-R-450
KTN-R-20
KTN-R-100
KTN-R-500
KTN-R-25
KTN-R-110
KTN-R-600
Technical Data 1043
Limitron® fast-acting fuses 250 volt
Effective May 2016
Carton quantity and weight (250 vac)*
5
110–200
1
225–400
1
450–600
1
600A
10
70–100
400A
40–60
200A
10
100A
1–30
60A
Carton
qty.
30A
Amps
Time-current curves — average melt
Amp
rating
300
100
*Contact Eaton’s Bussmann Division for DC ratings.
Recommended fuse blocks
0-30
35-60
70-100
1-pole
2-pole
3-pole
HM25030-1
HM25030-2
HM25030-3
RM25030-1
RM25030-2
RM25030-3
HM25060-1
HM25060-2
HM25060-3
RM25060-1
RM25060-2
RM25060-3
RM25100-1CR
RM25100-2CR
RM25100-3CR
110-200
RM25200-1CR
RM25200-1CR
RM25200-1CR
225-400
RM25400-1CR
RM25400-1CR
RM25400-1CR
450-600
RM25600-1CR
RM25600-1CR
RM25600-1CR
For additional information on 250 volt blocks, see data sheet
No. 10289 (RM250) and (HM250) and product brochure
No. 3192 (RM style).
10
Time in seconds
Fuse amps
1
Fuse reducers for Class R fuses - 250 V
400 A
600 A
NO.263-R
NO.213-R
60 A
NO.216-R
60 A
NO.226-R
100 A
NO.2621-R
100 A
NO.2641-R
200 A
NO.242-R
100 A
NO.2661-R
200 A
NO.2662-R
400 A
NO.2664-R
0.1
0.01
† Single reducer only (pair not required).
For additional information on Class R fuse reducers, see data
sheet No. 1118.
2
Eaton.com/bussmannseries
RMS symmetrical current in amps
10,000
200 A
30 A
30 A
1000
100 A
Catalog symbol
(pairs)
100
60 A
Desired fuse
(case) size
40
Equipment
fuse clips
Technical Data 1043
Effective May 2016
Current-limitation curves
B
Amp
rating
100,000
600
400
200
100
10,000
60
30
200,000
1000
1000
100,000
A
10,000
Instantaneous peak let-through current in amps
400,000
RMS symmetrical currents in amperes
A-B=asymmetrical available peak (2.3 x symm. RMS amps)
The only controlled copy of this Data Sheet is the electronic read-only version located on the Eaton Network Drive. All other copies of this
document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical
information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction
of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice,
any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible
applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2016 Eaton
All Rights Reserved
Printed in USA
Publication No. 1043 – SB02295
May 2016
Eaton, Bussmann and Limitron are
valuable trademarks of Eaton in the US
and other countries. You are not permitted
to use the Eaton trademarks without prior
written consent of Eaton.
CSA is a registered trademark of the
Canadian Standards Group.
NEC is a registered trademark of the
National Fire Protection Association, Inc.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Follow us on social media to get the
latest product and support information.
3
很抱歉,暂时无法提供与“KTN-R-8”相匹配的价格&库存,您可以联系我们找货
