HOLESAW,VARIABLE PITCH (4 1/2) STD PK 20
Bi-Metal Hole Saws
Cat No:
825B-4-1/2
UPC No:
783310380511
Description
Cut through steel, tin, aluminum, fiberglass, wood and plastic
Deep 1-5/8 IN (41.3 mm) cutting depth allows for cuttingthrough 2 IN x 4 IN wood studs
Extra-tough bi-metal bladewe use the highest grade of tool steel to outlast competitor's blades.
That beats premature saw replacement and saves you money
Steam oxide finish no paint to gum up and slow cutting. The saw runs cooler for longerlife and
better performance
Extra-thick backplate minimizes vibration for smoother, easier, less tiring cutting
Made in USA
Specifications
Application : For 4.000 Conduit IN
Cutting Size : 1-5/8 IN
D Chain : 4
Hole Diameter : 4-1/2 IN
Material : Bi-Metal
Material Master Number : 50380516
Package : 20/Standard Pack
Type : Variable Pitch
Use With Quick Change Arbor No. : 2801
Use With Standard Arbor No. : 37156
很抱歉,暂时无法提供与“825B-4-1/2”相匹配的价格&库存,您可以联系我们找货
