925-2-1/2
    GREENLEECOMMUNICATIONS(格林利)
    Radial
    CUTTER PKG HSS 2.500"
925-2-1/2 数据手册
CUTTER PKG,HSS 2.500" Ultra Cutters Cat No: 925-2-1/2 UPC No: 783310101628 Description • • • • • • • • Lasts 10 times longer thanstandard hole saws Precision-ground teeth cut smooth, burr-free holes with ease 1/4 IN (6.35 mm) capacity Durability and speed provide low cost per hole Split-point pilot drill prevents "walking" - makes accurate hole placement easy Spring-loaded slug ejector saves time No tool required to change cutter sizes Less chance of broken teeth because the saw body is machined out of solid, high-speed steel Specifications • • • • Hole Diameter : 2-1/2 IN Material : High Speed Steel Pipe Tap Size : 2.000 IN Type : Ultra
925-2-1/2 价格&库存
很抱歉,暂时无法提供与“925-2-1/2”相匹配的价格&库存,您可以联系我们找货
