CMQ69273
698-2700MHZ
Ceiling Mount 3 dBi Panel
SPECIFICATIONS
Model
Frequency
Gain (dBi)
ASSEMBLY ANDPSQ24495
INSTALLATION
Internal Wireless
Device
Antenna
INSTRUCTIONS
4-Port Directional Slant 45° MIMO Antenna
EMN2449C-152SMAM
MHZ 5 dBi 4-PORT DIRECTIONAL MIMO ANTENNA
Laird’s PSQ24495 antenna is a 4-port directional antenna for use in 802.11n
MIMO applications. The antenna
Mini-Nanoblade
3.5 (typical), 4.1 (max) @ 800 Band
is an excellent choice for high density WiFi applications where adjacent antenna interference is o f concern.
CMQ69273
698 MHz-960MHz
1710MHz -2700 MHz
2.4-2.49
4.9-6.0
2.9 (typical), 4.5
(max) @&700
Band
3.2 (typical), 3.8
(max) @
900
Band
Equipped
with
two
sets of slant +/-45 degree ports, the antenna takes advantage of both polarization and spatial
separation
mitigate
multipath issues.
4.4 (typical), 4.9
(max) @to1800
Band
Enclosed
compact/low
profile ASA, UV stable, radome and equipped with an articulating arm that can be
4.1 (typical), 4.8
(max) in
@ a1900
Band
affixed to a mast or anchored directly to a vertical surface, the antenna can be oriented to take full advantage
of the antenna’s directionality. Uniform and symmetrical radiation patterns provide a high-level signal density
Patent Pending
3.3 (typical), 4.1
@ coverage
2300 Band
into(max)
defined
zones. This antenna will greatly enhance
the performance of 802.11n systems where
MINI-NANOBLADE
INTERNAL
EMBEDDED
ANTENNA
Please
read all
instruction
carefully
before
2.8 (typical), 3.7
(max)obstructions
@ 2600 Band
physical
are anticipated. The dual band
frequency
coverage
means
that a single
typeattempting
of antenna can
The evolution
of technology
has2.4brought
the need
touse
communicate
to install
and
this product.
with any MIMO
radio in the
2.49
MHz
and
4.9-6.0
MHz
bands.everywhere and at all
be deployed
3.8 (typical), 4.3 (max) @ 2100 Band
Port to Port Isolation
times without being confined to one space. Laird internal wireless device antennas feature
16attenuate
dB
Laird warrants to the original purchaser that antenna products will remain free
reflected signals interfere with the primary signal path.
from defects in materials and workmanship forPort-to-Port
a period
of
(5)
years
from
the
Isolation,
Max
dB
> 15 dB
> 20 dB
ELECTRICAL SPECIFICATIONS
Avoid mounting next to a column or vertical support that
purchase date. If any such defect is discovered within the warranty period,
13could
dB - 6create
Front
-to-Back
Laird will at its sole option, repair or replace the
Product
free ofRatio
charge upon
>a 20
dB
Frequency
2.4 - 2.5 >GHz,
4.9
GHz
“shadow
zone” of reduced coverage to
its return to the factory. This warranty applies only if the Product is used in a
one
portion
of
the
room.
50 Ω2.5-4.8 dBi (4.9-5.875 GHz)
Nominal
Impedance
Gain
2.0-2.5 dBi (2.4-2.5 GHz),
normal fashion, and is void if the Product is abused,
disassembled,
tampered
Operating Temperature
Range
-30°C ~ +70°C
SPECIFICATIONS
FEATURES
with, used unreasonably, or fails as a result of normal wear. Furthermore, this
warranty applies only to defects, which occurPolarization
where Polarization
the proper Product is
selected as recommended by Laird and is used in the Nominal
fashion recommended
Maximum
InputImpedance
Power (per port)
by Laird for the defective Product. THIS WARRANTY IS IN LIEU OF ALL
OTHER WARRANTIES, EXPRESSED OR IMPLIED, AND
IS LIMITED TO A
VSWR
(LxWxH)
PERIOD OF (5) YEARS FROM THE DATEDimensions
OF ORIGINAL
PURCHASE.
Size
LAIRD IS NOT LIABLE FOR INCIDENTAL OR CONSEQUENTIAL
DAMAGES
Weight
(w/o
mount)
OF ANY KIND. ANY WARRANTY EXTENDED HEREIN SHALL BE LIMITED
TO THE PRICE PAID TO LAIRD FOR THE DEFECTIVE
MountingPRODUCT. WHERE
STATE OR LOCAL LAW GOVERNS THE PERIOD OF WARRANTY, SUCH
PERIOD SHALL CONTROL.
Cable Type
Wind Survival
Americas: +1.847 839.6925
IAS-AmericasSales@lairdtech.com
Europe: +44.1628.858941
IAS-EUSales@lairdtech.com
Asia: IAS-AsiaSales@lairdtech.com
Americas:
839.6907
Middle East+1.847
and Africa:
+44.1628.858941 IASIAS-AmericasEastSales@lairdtech.com
MEAUSales@lairdtech.com
www.lairdtech.com
Europe:
+44.1628.858941
Slant
± 45°
Vertical, Omnidirectional
STANDARD
50 10
ohms
W (ambient
temp ofpost
25°C/77°F)
A threaded
on the back of the antenna and a
supplied
mounting
nut are the primary mounting
< 2.:1
max
across
all
bands
202 x 200 x 40mm (7.96"x 7.87"x 1.6")
method when access is available to both sides of the
1.42" x 0.475" 698 g (1.54 lbs)
mounting surface, such as a suspended ceiling tile.
Mark the
desiredmount
mounting location on the tile and cut a
Articulating
mast/wall
ø40mm (1.57”) hole for threaded post. Feed the cables
Low temperature
Plenum
through the
holerated
and secure the antenna with the
mounting
nut.mph)
(See figure 1).
200
km/h (125
Wind Gust Survival
266 km/h (165 mph)
Ingress Protection
IP67
Operating Temparture
-30°C to +70°C (-22°F to +158°F)
Storage Temparture
-40°C to +85°C (-40°F to +185°F)
Radome / Baseplate Material
Material Compliance
MOUNTING
ASA LURAN S778T
Figure 1
RoHS Compliant
Asia: +86.21.5855.0827.127
www.lairdtech.com
165-00183_AA
PSQ24495
CONFIGURATION
PART NUMBER
CABLE LENGTH
CONNECTOR
PSQ24495-91NF
4x- 91 cm (3.00 ft)
Type N- Female
PSQ24495-91NM
PSQ24495-91RSM
4x- 91 cm (3.00 ft)
4x-91cm (3.00 ft)
Type N- Male
Type SMA - Male Reverse Polarity
RADIATION PATTERNS
2400 MHz
5400 MHz
ANT-DS-PSQ24495 0617
2450 MHz
2500 MHz
4900 MHz
6000 MHz
Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its
agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of
any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2017 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo,
and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual
property rights.
很抱歉,暂时无法提供与“PSQ24495-91RSM”相匹配的价格&库存,您可以联系我们找货
