S8063B
S8063B
    LAIRD(莱尔德)
    OMNIPOLMNT23IN806-866MHZ5DBI
S8063B 数据手册
BASE STATION OMNI ANTENNAS S8xxxB 800/900 MHz OMNIDIRECTIONAL ANTENNAS Omnidirectional antennas are the right choice for situations where you need to be in contact with sources that are in two directions or if you do not know what direction the signals will be coming from. Standard data transmission omnis are fully decoupled antennas built on a copper laminate and housed in 0.100 inch wall fiberglass housings. They may be mounted right side up or tipped upside down depending upon the desired pattern. They also feature a very versatile clamp mounting system that will fit most every situation you will encounter. FEATURES MARKETS • Broadband performance • Fiberglass enclosures • DC grounded • Plated copper laminated radiator • Weatherproof designs with UltraLink pigtail • Omnidirectional • WiMAX • Two-way dispatch ANTENNA PATTERNS S8060B S8063B S8064B SPECIFICATIONS MODEL FREQ. MHz VSWR BANDWIDTH -3 dB BMWIDTH TYPE E-PLANE (FEMALE) (NOMINAL) 1.5:1 MHz HEIGHT in(cm) WEIGHT W/SUR AREA W/SURVIVAL lb(kg) ft2 (m2) mph(kph) 42-1/8 (107) 1.56 (0.70) 0.22 (0.02) PIGTAIL in(cm) S8964B 896-960 1.5:1 64 25° N 125 (200) 23 S8963B 896-960 1.5:1 64 45° N 30-3/4 (78) 1.19 (0.53) 0.176 (0.016) 125 (200) 23 S8960B 896-960 1.5:1 64 75° N 17-1/2 (44.5) 0.56 (0.25) 0.083 (0.009) 125 (200) 17 S8804B 880-960 1.5:1 62 25° N 42-1/8 (107) 1.56 (0.70) 125 (200) 23 S8803B 880-960 1.5:1 62 45° N 30-3/4 (78) 1.19 (0.53) 0.176 (0.016) 125 (200) 23 S8800B 880-960 1.5:1 62 75° N 17-1/2 (44.5) 0.56 (0.25) 0.083 (0.009) 125 (200) 17 S8244B 824-896 1.5:1 62 25° N 42-1/8 (107) 1.56 (0.70) 125 (200) 23 S8243B 824-896 1.5:1 62 45° N 30-3/4 (78) 1.19 (0.53) 0.176 (0.016) 125 (200) 23 S8240B 824-896 1.5:1 62 75° N 17-1/2 (44.5) 0.56 (0.25) 0.083 (0.009) 125 (200) 17 S8064B 806-868 1.5:1 62 25° N 42-1/8 (107) 1.56 (0.70) 125 (200) 23 S8063B 806-868 1.5:1 62 45° N 30-3/4 (78) 1.19 (0.53) 0.176 (0.016) 125 (200) 23 S8060B 806-868 1.5:1 62 75° N 17-1/2 (44.5) 0.56 (0.25) 0.083 (0.009) 125 (200) 17 0.22 (0.02) 0.22 (0.02) 0.22 (0.02) Common speci ications: Power handling - 5 watts; Element material - plated copper laminate; Enclosure material - fiberglass; Mounting style - tube end; Maximum mast diameter - 2 in (5.1 cm) Americas: +1.847 839.6925  IAS‐AmericasEastSales@lairdtech.com  Europe: +44.1628.858941  IAS‐EUSales@lairdtech.com  Asia:  +86.21.5855.0827.127  IAS‐AsiaSales@lairdtech.com  www.lairdtech.com  ANT-DS-S8xxxB 1215 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
S8063B 价格&库存
很抱歉,暂时无法提供与“S8063B”相匹配的价格&库存,您可以联系我们找货
