Effective May 2016
Supersedes December 1998
Technical Data 1039
BUSSMANN
SERIES
Edison base CSA plug fuses – dual-element,
time-delay, 125 volts, 15-30 amps
Recommended fuse holders
Catalog
numbers
SOU
SRU
SSU
SOW
SRW
SSW
SOX
Catalog symbol:
BP/TC - (amps)
TC - (amps)PK4
SRX
Description:
Type
box
2 1/4”
handy
2 3/4”
handy
4”
octagon
Catalog
numbers
SOY
SRY
SSY
SSY-RL
STY
SCY
SOY-B
Type
box
4”
square
Single
gang
SSN
Package quantity and weight
Bussmann® series CSA Type D, dual-element,
time-delay Edison base fuse.
Quantity
Weight
Amp
ratings
Per
box
Per
card
Per
box
Per 5
cards
Specifications:
15 to 30 A
4
3
0.24
1.04
Ratings
Volts — 125 Vac or less
Features:
Amps — 15 to 30 A
“D” rating for Canadian applications
Heavy duty, dual-element, time-delay plug
fuses
These fuses thread into fuse receptacles or
box cover units
Edison base size
Industrial strength, featuring an exclusive
dual-element construction
This spring loaded design provides superior
short circuit and overload protection
More time-delay than the medium duty Type
P fuses in order to better protect industrial
motors and optical residential
circuits
Agency Information
CSA® Certified, Class 1423-01, File 53787
Catalog numbers (amps)
TC - 15
TC - 20
TC - 25
TC - 30
Technical Data 1039
dual-element, time-delay, 125 volts, 15–30 amps
Effective May 2016
Amp
rating
30
300
15
Time-current curve – average melt
100
Time in seconds
10
1
10,000
1000
100
0.1
Current in amps
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this
document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical
information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction
of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice,
any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible
applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
Eaton.com/bussmannseries
© 2016 Eaton
All Rights Reserved
Printed in USA
Publication No. 1039 – SB98107
May 2016
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Eaton and Bussmann are valuable
trademarks of Eaton in the US and other
countries. You are not permitted to use the
Eaton trademarks without prior written
consent of Eaton.
CSA is a registered trademark of the
Canadian Standards Group.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“TCA2”相匹配的价格&库存,您可以联系我们找货
