CUTTER KIT, HOLE-CARBIDE
7/8, 1-1/8, 1-3/8, 1-3/4, 2Cutter Heads
Arbor, Hex Key and Case
Cat No:
660
UPC No:
783310057666
Description
Cuts stainless steel quickly and easily
Quick Change arbor allows you to change cutter heads with a simple push and a turn. Use the
same arbor for different size cutting heads
Removable cutter heads available in sizes from 5/8 IN through 3 IN
Flange stop prevents over-drilling
Ejector spring on all sizes above 3/4 IN makes removal of slug easier
Replaceable, cobalt-steel pilot drill with split-point tip to prevent walking
Precision carbide teeth for optimum performance and durability
Minimum chuck size of 3/8 IN
Specifications
Includes :
ƕ 7/8 IN, 1-1/8 IN, 1-3/8 IN,1-3/4, 2.000 IN Cutter Heads
ƕ Arbor, Hex Key, Case, Set Screw, Ejector Spring
Replacement Part : 3581 3 MM Hex Key, 54274 Set Screw, 55225, 1/2 IN Ejector Spring
很抱歉,暂时无法提供与“660”相匹配的价格&库存,您可以联系我们找货
