RS232
RS232
    GREENLEECOMMUNICATIONS(格林利)
    Tool
    PUNCH UNIT-CONNECTOR 25 PIN
RS232 数据手册
PUNCH UNIT-CONNECTOR 25 PIN RS-232 Electronic Connector Panel Punches Cat No: RS232 UPC No: 783310344209 Description • • • • • Cut-out and mounting slots are punched in one operation Drill only one 7/16 IN (11.1 mm) pilot hole. (See page 82 for Kwik Stepper step bits.) Fast, accurate panel punching with no sawing or filing required Universal size punches forfront or back mount of TRW Cinch and ITT Cannon-type or equivalent connectors in 9, 15, 25, 37 or 50-pinconfigurations U.S. Patent No. 4,899,447 Specifications • • • • • • • Capacity : ƕ 16 GA (1.500 MM) Mild Steel ƕ 10 GA (3.500 MM) Aluminum No. Of Pins : 25 Operation Type : ƕ Manual With A Wrench ƕ Quick Draw And Quick Draw 90 Hydraulic Drivers, Battery Driver, Ram And Pump HydraulicDrivers Aluminum Replacement Part : 34418 Punch, 35198 Die Unit, 34421 Draw Stud, 04638 Square Counter Nut, 34733 Drive Nut Size : 1.655 IN X 1.853 IN X 0.469 IN (42.000 MM X 47.100 MM X 11.900 MM) Type : Electronic Connector Panel Weight : 2.000 LB (0.910 KG)
RS232 价格&库存
很抱歉,暂时无法提供与“RS232”相匹配的价格&库存,您可以联系我们找货
