30008POP
30008POP
    GREENLEECOMMUNICATIONS(格林利)
    BIT DISPLAY 5 PACK-K/S STEP
30008POP 数据手册
BIT DISPLAY, 5 PACK-K/S STEP 1-1/8 Multi-Hole Step Bit Cat No: 30008POP UPC No: 783310017592 Description • • • • Unique split-tip design penetrates through steel faster Resists walking or skidding, even on round surfaces Balanced, double-flute construction requires less pressure, does the work for you Designed and manufactured in USA Specifications • • • • • • • • Bit Extension : 901 Capacity : Cut Up Through 3/8 IN (9.500 MM) Mild Steel, Copper, Brass,Aluminum, Wood, Plastic and Laminates Hole Size : 1/2 IN (12.700 MM), 7/8 IN (22.200 MM), 1-1/8 IN (28.600 MM) Maximum Material Thickness : 10 GA (3.500 MM) Minimum Chuck Size : 3/8 IN (9.500 MM) Overall Length : 2-15/16 IN (74.600 MM) Sub Brand : Kwik Stepper Type : Multi Hole
30008POP 价格&库存
很抱歉,暂时无法提供与“30008POP”相匹配的价格&库存,您可以联系我们找货
