2707B
2707B
    B&K
    Manual True RMS Handheld Digital (DMM) Multimeter 3.5 Digit LCD Display Voltage, Current, Resistance...
2707B 数据手册
Data Sheet Manual Ranging True RMS Tool Kit® DMM Model 2707B T RUE RMS hFE Transist or Test Measures commonemitter gain. The 2707B is a full-featured manual ranging true RMS DMM that combines performance, value and functionality. The 2000 count LCD can display resistance values up to 2 GΩ, capacitance to 20 uF, or a transistors common-emitter gain value up to 1000. Value-packed features make this meter a must in every "Tool Kit®". Features ■ Magnetic hanger ■ One-handed operation ■ True RMS ■ Measures up to 10 A (AC & DC) ■ DC voltage to 1000 V ■ AC voltage to 750 V ■ Resistance to 2000 MΩ ■ Capacitance to 20 uF ■ Continuity test ■ Diode test ■ Logic test ■ hFE Transistor test Specifications model 2707B D C Volts Ranges 200 mV, 2 V, 20 V, 200 V, 1000V Resolution 0.1 mV, 1 mV, 10 mV, 100 mV, 1 V Accuracy ±(0.8 % rdg + 1 dgts) Input Impedance 10 MΩ Overload Protection 1000 VDC or 750 VACrms* A C Volts (True RM S) (50 Hz-500 Hz) Ranges 200 mV, 2 V, 20 V, 200 V, 750V Resolution 0.1 mV, 1 mV, 10 mV, 100 mV, 1 V Accuracy 200 mV & 20 V ranges: ±(1.5 % rdg + 8 dgts) 200 V & 750 V ranges: ±(2.0 % rdg + 8 dgts) Crest Factor 30 % and
2707B 价格&库存
很抱歉,暂时无法提供与“2707B”相匹配的价格&库存,您可以联系我们找货
