2835
    B&K
    BENCHTOP DMM MULTIMETER LCD
2835 数据手册
2831C 2835 Specifications 2835 B+K Precision offers 2 models that are great for use by any technician or students in a laboratory or field environment. Model 2835 has a compartment to carry test leads and other accessories with convenient strap for easy transportation. The large LCD provides a good reading. Model 2831C has accurate True RMS for interpretation of any waveform signal. The LED display provides clear reading in darker environments. It is a great tool for any bench, next to a power supply and oscilloscope. Model 2835 ■ Large LCD provides a good reading ■ Compartment to carry test leads and other accessories ■ Convenient strap for easy transportation ■ Portable ■ Battery operated Model 2831C ■ True RMS for accurate interpretation of any waveform signal ■ LED display for clear reading in darkest environment ■ Great overload protection ■ Tests 1200VDC and 1000VAC DC Volts Ranges Resolution Basic Accuracy Input Impedance AC Volts Ranges Resolution Basic Accuracy Input Impedance True RMS DC Current Ranges Resolution Basic Accuracy Overload Protection AC Current Ranges Resolution Basic Accuracy Overload Protection Resistance Ranges Resolution Basic accuracy Capacitance Ranges Resolution Basic Accuracy Frequency Range Accuracy Sensitivity Diode Test Continuity Check General Display Power Operating Temperature Size Weight 2831C models 400mV 4V, 40V, 400V, 1000V 0.1mV, 1mV, 10mV, 100mV, 1V 0.5% + 2 digits 10MΩ 200mV, 2V, 20V, 200V, 1200V 0.1mV, 1mV, 10mV, 100mV, 1V 0.1% + 1 digit 10MΩ 400mV, 4V, 40V, 400V, 750V sames as DCV 1.0% + 5 digits 10 MΩ
很抱歉,暂时无法提供与“2835”相匹配的价格&库存,您可以联系我们找货
