2831D
2831D
    B&K
    DMMBENCH41/2DIGITTRUERMS
2831D 数据手册
Model 2831D 4 1/2 Digit True RMS Bench Digital Multimeter Data Sheet Model 2831D 4 1/2 Digit True RMS Bench Digital Multimeter The model 2831D provides versatility and reliability for a broad spectrum of laboratory and service applications. Being a true Multimeter it can make diode, frequency and continuity measurements in addition to basic current, voltage and resistance measurements. ■ True RMS for accurate interpretation of any waveform signal ■ 4 1/2 Digit LED display for clear reading in darkest environment ■ Great overload protection on all ranges ■ Voltage measurements up to 1200VDC and 750VAC ■ Current measurements up to 20A AC/DC ■ Basic accuracy for DCV is 0.05% Specifications 2831D DC Voltage Max Range Best Accuracy Best Resolution AC Voltage Max Range Best Accuracy Best Resolution DC Current Max Range Best Accuracy Best Resolution AC Current Max Range Best Accuracy Best Resolution Resistance Max Range Best Accuracy Best Resolution Frequency Max Range Best Accuracy Best Resolution model 1200V +0.05%+5D 100uV 750V +0.75%+10d 100uV 20A +0.75+5d 100nA 20A +0.75+5d 100nA 20M Ω +0.2%+5d 0.1ohm 200KHz +1.0%+5d 1Hz B&K Precision Corporation 22820 Savi Ranch Parkway, Yorba Linda, CA 92887 Tel: 714-921-9095, Fax: 714-921-6422 www.bkprecision.com Specifications subject to change without notice
2831D 价格&库存
很抱歉,暂时无法提供与“2831D”相匹配的价格&库存,您可以联系我们找货
