Data Sheet
Bench LCR/ESR Meter with Component Tester
Model 889B
Specifications
889B
Test Frequencies
100Hz, 120 Hz, 1 kHz, 10 kHz, 100 kHz, 200 kHz
Frequency Accuracy
±0.1%
Test Levels
1 Vrms, 0.25 Vrms, 0.05 Vrms, 1 Vdc (for DCR)
Level Accuracy
±10%
100 Ω, ±5%
Output Impedance
Measurement Range
Impedance ( Z)
The B&K Precision 889B synthesized in-circuit bench LCR/ESR meter is a
high accuracy test instrument used for measuring inductors, capacitors and
resistors with a basic accuracy of 0.1%. Also, with the built-in functions of
DC/AC Voltage/Current measurements and Diode/Audible Continuity checks,
the 889B can not only help engineers and students to understand the
characteristics of electronics components, but also being an essential tool on
any service bench.
Capacit ance (C)
Features:
Measurement parameters: Z, L, C, DCR, ESR, D, Q, ACV, DCV, ACA,
DCA and Ø
Induct an ce (L)
Freque ncy
Maximum
DCR
20 MΩ
M ini mum
100 Hz
20 MΩ
120 Hz
20 MΩ
1 kHz
20 MΩ
10 kHz
20 MΩ
100 kHz
10 MΩ
200 kHz
10 MΩ
0.1 Ω
Freque ncy
Maximum
M ini mum
Best Re solutio n
100 Hz
15.91 mF
79.57 pF
0.001
120 Hz
13.26 mF
66.31 pF
0.001
1 kHz
1.591 mF
7.957 pF
0.001
0.1 Ω
Best Re solutio n
0.001
0.1 Ω
0.001
0.1 Ω
0.001
0.1 Ω
0.001
0.1 Ω
0.001
0.1 Ω
0.001
0.001
10 kHz
159.1 µF
0.795 pF
0.001
100 kHz
15.91 µF
0.159 pF
0.001
200 kHz
7.957 µF
0.079 pF
0.001
Freque ncy
Maximum
M ini mum
Best Re solutio n
100 Hz
31.83 kH
159.1 µH
0.001
120 Hz
26.52 kH
132.6 µH
0.001
1 kHz
3.183 kH
15.91 µH
0.001
Test conditions: 100 Hz, 120 Hz, 1 kHz, 10 kHz, 100 kHz, 200 kHz,
10 kHz
318.3 H
1.591 µH
0.001
100 kHz
31.83 H
0.159 µH
0.001
0.1% basic accuracy
200 kHz
15.91 H
0.079 µH
0.001
Dual LCD display
General
Very quick response, user-friendly
Operating Temperature
32˚ to 104˚F (0˚ to 40˚C)
Fully auto/manual selection
Storage Temperature
-4˚ to 158˚F (-20˚ to 70˚C)
DC resistance measurement
Relative Humidity
up to 85%
USB interface
AC Input
110 V/220 V AC, 60/50 Hz
Dimensions (LxWxH)
11.8 x 8.7 x 5.9" (300 x 220 x 150 mm)
Weight
10 lbs (4.5 kg)
Included Accessories
Kelvin probe, DMM test leads, and power cord
Three-Year Warranty
Technical data subject to change
© B&K Precision Corp. 2018
v082218
www.bkprecision.com
Tel.: 714.921.9095
很抱歉,暂时无法提供与“889B”相匹配的价格&库存,您可以联系我们找货
