Data Sheet
Handheld Battery Capacity Analyzers
Models 600B and 601B
The 600B and 601B Battery Capacity Analyzers
address the need to test and maintain sealed lead
acid (SLA) batteries used in backup power UPS,
emergency lighting, fire alarms, security systems,
and many other electrical systems. By quickly
characterizing a battery’s response to a load
resistance, these meters display the remaining
battery capacity as an indicator of the battery’s
health. Powered by the battery under test, both
models support testing of 12 V storage type lead
acid batteries. The 601B is also capable of
testing 6 V batteries and displaying the internal
resistance of the battery.
Features
Measure remaining battery storage capacity in
just seconds
Easy-to-use interface
Powered by the battery under test eliminating
the need for external power to instrument
High quality, durable Kelvin clamps
Rubber buttons
Rugged housing with extruded aluminum case
Internal resistance measurement (601B only)
Model
600B
601B
Supported SLA battery voltages
12 V
6 V & 12 V
Internal resistance
Loaded voltage
Technical data subject to change
© B&K Precision Corp. 2015
www.bkprecision.com
Front panel
Display
Rubber keypad
Reverse polarity LED
Kelvin clamps
Strain reliefs
Specifications
Model
600B
601B
12 V
6 V & 12 V
5 - 100 in 1 Ah steps
Ah range
7, 12, 24, 42, 65, & 100
No load (open circuit) voltage accuracy
±2 counts
±(0.2% + 1 count)
Dimensions (W x H x D)
2.91 x 10.44 x 2.18" (74 x 265.1 x 54 mm)
2.91 x 10.44 x 2.28" (74 x 265.1 x 58 mm)
Weight
2.65 lbs (1.2 kg.)
Included accessories
User manual
One-Year Warranty
2
v092215
www.bkprecision.com
很抱歉,暂时无法提供与“600B”相匹配的价格&库存,您可以联系我们找货
