510 Solar Irradiance Meter
510
Solar Meter
0212
Test the TPI Advantage
Value • Performance • Service • Safety
Applications
Features and Benefits
• Use to find the
optimal angle of
inclination for
installing solar
panels
• Measure solar radiation (irradiance).
• Measure light
intensity
through
windows
• Min / Max and Data hold functions
• Displays results in W/m2 or BTU
• 0 to 1999 W/m2 (0 to 634 BTU) range
• Determine the
effectiveness of
solar film /
window tint.
Specifications
Range:
Accuracy:
TPI
Headquarters:
9615 SW Allen Blvd.
Beaverton, OR 97005
USA
503-520-9197
Fax: 503-520-1225
Copyright © 2012
Test Products International, Inc.
Display:
Sampling Time:
Resolution:
Operating Temp. & RH:
Storage Temp. & RH:
Dimensions & Weight:
1999W/m2 / 634BTU/(ft2*h)
typically within +/-10W/m2
[+/-3BTU/(ft2*h)] or +/-5%, whichever is
greater in sunlight; additional temperature
induced error +/-0.38W/m2/°C
[+/-0.12BTU/(ft2*h)/°C] from 25°C
3-1/2 digits LCD with maximum reading 1999
approx. 0.25 second
0.1W/m2 / 0.1BTU/(ft2*h)
41°F~104°F (5°C~40°C), below 80%RH.
14°F~140°F (-10°C~60°C), below 70% RH.
5.1 x 2.4 x 1.5” 5.3oz
(132 x 60 x38 mm, approx. 150g)
TPI 510 Applications
Measuring Solar Irradiance
Test solar irradiance through a windshield by
placing the 510 close to the inside of the glass.
Measuring Headlight Intensity
Turn on the headlights and place the
510 close to the headlight lense to test
light intensity
很抱歉,暂时无法提供与“510”相匹配的价格&库存,您可以联系我们找货
