USER GUIDE TB-9023
EM Eye - ESD Event Meter
Installation, Operation and Maintenance
Made in the
United States of America
Figure 2. Using the EM Eye Meter
Easy Data Logging to Memory Card
The EM Eye Meter supports data logging by using a
microSD card and exports to an Excel spreadsheet.
Having data at hand enables quick analysis. Solutions
can be decided quickly and can be measured on the
spot.
Figure 1. SCS CTM048-21 EM Eye - ESD Event Meter
Description
The SCS EM Eye - ESD Event Meter detects, counts
and measures ESD events that can damage ESD
items and cause tool lock-ups, erratic behavior, and
parametric errors. It calculates event magnitude for
Charged Device Model (CDM), Human Body Model
(HBM), and Machine Model (MM). All measurements
are recorded onto a microSD card for PC download.
It features a touchscreen display and rechargeable
lithium ion battery. Each EM Eye - ESD Event Meter
is calibrated with accepted procedures and standards
traceable to the National Institute of Standards and
Technology (NIST) and includes a NIST certificate.
User Features
Touch Screen to Power ON
The EM Eye Meter is designed with a modern user
interface. All buttons and controls are within the display
itself. With its display and touch screen, it is easier for
users to quickly navigate through the features that were
built into the meter.
Figure 3. Inserting the SD card into the EM Eye Meter
Speaker and Headphone Alarm Outputs
The EM Eye Meter, with a speaker and headphones,
allows flexible means for audible indications, beeping
or “warbling” like a radio. If one is in a noisy place, a
headphone jack for optional headphones can be used
for clearer audio.
SCS - 926 JR Industrial Drive, Sanford, NC 27332
East: (919) 718-0000 | West: (909) 627-9634 • Website: StaticControl.com
TB-9023 Page 1 of 11 September 2021
© 2021 DESCO INDUSTRIES INC
Employee Owned
The EM Eye and its accessories are available as the
following item numbers:
Item
Description
CTM048-21
CTC021
Replacement ESD Sensor
CTC113-6FT Remote ESD Sensor
CTC115-6FT Remote ESD Sensor, High Temp
CTS001
Replacement Antenna
770756
Power Adapter, 100-240VAC Input,
5VDC 1.0A Output, All Plugs
Packaging
1
1
1
1
1
1
1
EM Eye Meter
CTC021 ESD Event Sensor with Local Antenna
CTC113-6FT Remote Antenna with 6 ft. RF Cable
MicroSD Memory Card
Power Adapter, 5VDC, with interchangeable plugs
(North America, UK/Asia, Europe)
Carrying Case
Certificate of Calibration
Precautions
Do not drop the meter. This may damage the device
and will void the warranty.
Do not discharge directly into the antenna metals as
it may damage the input sensors and will void the
warranty.
Be cautious in the placement of antenna and the
module heads; align the parts while assembling.
Do not use sharp objects to touch the screen.
Do not use a wrench or pliers to screw or unscrew
the antenna. Use your bare hands.
Do not remove the microSD card while the power is
on. Turn off the meter before removing the microSD
card.
Do not remove the sensor heads while the power
is on. Turn off the meter before removing and
replacing the heads.
Attaching the Sensor Heads
Keep in mind the following when using the modular
sensor heads.
BEFORE CONNECTING TO AN INPUT SOURCE,
TOUCH THE OUTSIDE SURFACE OF THE EM EYE
METER INPUT CONNECTOR. THIS WILL HELP
PREVENT ESD SHOCK TO THE METER.
1. The power must be turned off when changing the
sensor heads.
2. Make sure to gently plug or unplug EM Eye Meter
and the sensor heads.
3. Plug or unplug the sensor heads by firmly gripping
them. Then fit the sensor over the EM Eye unit. Do
not grab the antenna for plugging and unplugging
the sensor heads.
4. If the antenna is separated from the sensor head,
reattach it when the sensor head is securely in
place.
Attaching the Antenna
In order to avoid damaging the EM Eye Meter,
installation and replacement of the antenna must be
done with great care. An excessive amount of force
or improper installation may permanently damage the
meter.
Attach the antenna to the input connector by simply
screwing it in by hand.
DO NOT OVERTIGHTEN THE CONNECTION. Screw
in the antenna firmly but gently. Do not use any tools
other than your hand to attach and detach the antenna.
TB-9023 Page 2 of 11
Employee Owned
Power Supply and Charger
Use only the power supply that comes with the EM Eye
Meter. Do not use any other power supply as it may
damage the meter.
Features and Components
Battery Care - Charging for the first time
To improve the battery life we recommend that you
make three fully charge-discharge cycles. For example:
fully charge the meter for two hours or overnight,
then use the meter until it is fully discharged (do not
recharge it at half-charge-life). Repeat this step two
times. It would normally take two hours to fully charge
the battery, but since the meter power is on while
charging; it would extend the charge time to four hours.
Succeeding charging would be at any duration. Use only
the supplied charger.
Local directional antenna
Power On
Using your finger, press and hold any spot on the
screen for approximately three seconds – do not use
any tools to perform this action. If a new sensor was
installed, a sequence of initialization will take place
for the first time for approximately ten seconds. After
that, the switch-on action will take approximately three
seconds. The main display screen appears after the
initialization and a beep will sound. The EM Eye Meter
will then perform a battery check. If the battery is too
low to provide reliable operation, it will not turn on. The
screen will go white momentarily and then the meter will
power up. After the initial power up, the meter will go
directly to the main screen.
Communication connectors
SMA connectors
Sensor module
Alignment pin
Alignment hole
Touchscreen display
Connecting the Sensor Head
MicroSD memory slot
Headphone jack
Reset pinhole
Power jack
Figure 5. EM Eye features and components
Figure 4. Connecting the sensors to the EM Eye Meter
TB-9023 Page 3 of 11
Employee Owned
Modular Assembly and Disassembly
1. Position the sensor head so that the dowel pins
align with the holes.
2. With the initial head midway through, reposition it so
that it is parallel to the body. Press the sensor head
firmly against the body until both surfaces are flat
with each other.
3. Insert and screw in the antenna making sure that it’s
not too tight or too loose. Do not use any tools other
than your hand. NOTE: Antenna is not applicable for
the RF Signal Sensor.
Figure 6. Attaching the sensor module to the EM Eye
Meter
If the assembly isn’t done correctly, you may receive
one of the following error and warning messages. To
correct, follow the instructions as indicated within the
message.
Error Message
Reason for Error
ERROR: Sensor is
disconnected. Click here
to turn device off.
The meter is turned
on without the sensor
module.
ERROR: Card was
removed. Data may be
lost and card could be
damaged. Click here to
close the window.
The storage card
(microSD) is removed
while the meter is
powered on.
WARNING: No memory
card. You can add it at
any time. Click here to
close the window.
The meter is turned on
with no storage card in
place.
PREPARING CARD FOR
RECORDING!!! DO NOT
REMOVE!!! PLEASE
WAIT.
A new card is inserted or
when a card is empty.
WARNING: This card
contains the data.
Remove the card or click
here to erase the data.
Inserting a card that has
contents other than the
EM Eye Meter files.
ERROR: Invalid memory
card. Format or replace
it. Click here to close the
window.
The card is not formatted
to FAT32. Formatting is
done using the PC.
ERROR!!! STACK
OVERFLOWED. Click
here to turn device off.
This is a fatal error. If
it appears even after
resetting, please contact
SCS Customer Service.
Reset Button
If the EM Eye Meter locks up or the display freezes,
press the reset button to restart the meter. The reset
button is in a small hole found near the headphone jack.
Use a paper clip to push the button inside the small
hole.
Figure 7. Location of the reset button at the bottom of
the EM Eye Meter
TB-9023 Page 4 of 11
Employee Owned
ESD Event Detection Sensor
The SCS EM Eye Meter will help you detect most ESD
events. This will help you make sound decisions in
tackling what may have been a daunting task. The EM
Eye Meter detects the magnitude of events and using
the filters built into the unit. It can provide approximate
values for some ESD Events for models (CDM, MM,
HBM) using proprietary algorithms. Switching between
any of the modes will give you immediate data analysis.
Solving ESD problems requires data; a before-and-after
analysis of data may now be measured and used to
tailor ESD control programs.
CDM Mode
MM Mode
In IC testing, ICs that are
sliding through tubes may
be charged up. Once the
lead touches the metal
tracks, a CDM event can
occur.
A moving, ungrounded
cart may accumulate
charges in its path. As
it approaches a metallic
worktable and bumps
into it, a discharge may
occur and may adversely
affect nearby products or
instruments
In feeder bowls where the
ICs are arranged for sorting or orientation, voltages
may be induced by the
vibrating bowl.
In using a bad soldering
iron, induced voltages
may cause discharges to
the components mounted
into the PCB. Use grounded tools and confirm that
no ESD events will be
detected by using the MM
mode.
HBM Mode
In IC testing, operators
that are handling an IC
(i.e. fixing bent leads) may
be discharging through
the IC.
Raw Input Mode
For engineers who want
to simply analyze raw
ESD signals for further
analysis, the Raw Input
mode provides actual
voltages received by an
antenna.
During picking up of an IC
by a person not properly
wearing a wrist strap, use
the EM Eye Meter to
alarm the operator of such
events.
TB-9023 Page 5 of 11
Employee Owned
ESD Events Sensor - Display and
Controls
For the detection of most ESD events using CDM, MM
or HBM models.
HOLD and MAX
The HOLD button toggles the HOLD data and MAX data
sequentially.
HOLD freezes the current data on the display. The
instrument will not be active at this point.
MAX displays the maximum voltages detected by the
EM Eye Meter above the set threshold.
Pressing the HOLD button for the third time will disable
the HOLD and MAX function and returns to normal run
mode.
HOLD and MAX does not affect recording into memory
storage. Data is still being recorded even if HOLD and
MAX is active.
Figure 10. Using the Hold button
TIME
To set the time, press the battery icon.
The NAVIGATOR screen appears.
Press the left or right arrows to move the shaded area
that need to be changed.
Figure 8. ESD Event Sensor displays and controls
Common Display and Controls
POWER and CLEAR
The POWER C button turns off the SCS EM Eye Meter
or clears the values that are on display.
To turn off the meter, press and hold the POWER C
button for approximately four seconds or longer until the
meter goes off.
Press the up or down button to scroll and set the
numbers.
Press the center button to return to the main screen.
Time: AM/PM format or 24-hour format
Date: Format as MM/DD/YY
Mode: 12-hour, 24-hour format
To reset all of the values on the display, press the
POWER C button for approximately one second.
Figure 11. Setting the time
Figure 9. Using the Power / Clear button
TB-9023 Page 6 of 11
Employee Owned
Battery
The BATTERY symbol displays the approximate level of
battery life remaining for use.
Full charge life.
Half charge
Open.
5. Navigate to the mircoSD card location. Open the
file inside the microSD card. The extension is
“ESD3M0003.esd”.
6. Select a row of data.
7. Save it into a folder.
8. Launch Microsoft® Excel.
9. Open the file that you just saved from the folder.
10. Sort and analyze the data using the tools in Excel.
Calibration
The EM Eye Meter comes from the factory calibrated.
It is recommended that you calibrate the EM Eye Meter
once a year at the factory.
TB-9023 Page 9 of 11
Employee Owned
Specifications
General
Audio Indicators
Speaker: Beep or analog audio with selectable volume
External Data Storage
microSD Card
Recording Interval
Peaks: 1 – 360 seconds
Average signals: 0.1 – 360 seconds
Display
Touch LCD
Size
65 W x 32 D x 105 L mm
Headphone Jack
3.5 mm (1/8 in.)
Power Supply/Charger
Input: 100-240V ~ 50-60 Hz 0.2A
Output: 5.0V 1000mA
Center: Positive, ID 1.3 mm; OD 3.5 mm
ESD Event Sensor
ESD Event Detection
Characterization Modes
Raw input for magnitude and estimated CDM, HBM, MM using proprietary algorithm
Raw Input Resolution
1mV (1mV-15mV) ; 15 mV (15mV-1500mV)
(Detection Resolution: 1mV)
Threshold (Display)
Resolution
1-10 Volts, 10-990 Volts
Raw input: 1mV (1-15mV) and 15mV (15-1500mV)
Distance Detection Range 1.3 cm (0.5 in.) – 38.1 cm (15.0 in.)
ESD Counter Range
0 – 32,767 counts (screen count)
Hardware Setup
Adjustable Brightness, Auto-off-time
CTC115 Remote Antenna
Temperature Range
-100°F to 400°F (-73°C to 204°C)
TB-9023 Page 10 of 11
Employee Owned
Safety Information
Please read, understand, and follow all safety
information contained in this User’s Guide prior to use
of the SCS EM Eye Meter. Retain these instructions for
future reference.
Warning
To reduce the risks associated with hazardous voltage,
which if not avoided, could result in death or serious
injury:
• Never allow children or other non-qualified persons
to come in contact with battery charger;
• Never use battery charger outdoors or in other wet
locations;
• Always use extreme caution to avoid coming into
contact with any exposed electrical conductors of
the equipment being measured with the EM Eye
Meter.
or possible fire or explosion related to internal Li-ion
battery, which if not avoided, could result in death or
serious injury:
• Use only the battery charger provided with the
product;
• If the battery charger is missing or damaged, only
replace with one supplied by SCS.
To reduce the risks associated with electrostatic
discharge (ESD) voltage, which if not avoided, could
result in damage to the meter:
• To install or change antennas, turn off the meter,
install or change antennas, turn meter back on;
• Avoid touching antenna when meter is turned on.
This device complies with Part 15 of the FCC Rules.
Operation is subject to the following two conditions: (1)
this device may not cause harmful interference, and
(2) this device must accept any interference received,
including interference that may cause undesired
operation.
ICES Statement
This Class A digital apparatus complies with Canadian
ICES-003.
Cet appareil numérique de la classe A est conforme à la
NMB-003 du Canada.
WEEE Statement
The following information is only for EU-members
States: The mark shown to the right is in compliance
with Waste Electrical and Electronic Equipment
Directive 2002/96/EC (WEEE). The mark indicates the
requirement NOT to dispose the equipment as unsorted
municipal waste, but use the return and collection
systems according to local law.
CE Statement
Meets CE (European Confomity) requirements.
Limited Warranty, Warranty Exclusions, Limit of
Liability and RMA Request Instructions
See the SCS Warranty -
StaticControl.com/Limited-Warranty.aspx
Caution
To reduce the risks associated with environmental
contamination from the EM Eye Meter with the lithium
battery and power supply:
• At the end of service life, dispose of the EM Eye
Meter accordance with federal, state and local
requirements.
Regulatory Information
FCC
This equipment has been tested and found to comply
with the limits for a Class A digital device, pursuant to
Part 15 of the FCC Rules. These limits are designed
to provide a reasonable protection against harmful
interference when the equipment is operated in a
commercial environment. This equipment generates,
uses, and can radiate radio frequency energy and, if not
installed and used in accordance with the instruction
manual, may cause harmful interference to radio
communications. Operation of this equipment in a
residential area is likely to cause harmful interference
in which case the user will be required to correct the
interference at their own expense.
TB-9023 Page 11 of 11
Employee Owned
