4014B
4014B
    B&K
    FUNCTION GENERATOR 12 MHZ DDS
4014B 数据手册
Data Sheet DDS Sweep Function Generators Models 4014B and 4040B Features & Benefits ■ generate a 2-point waveform to simulate the amplitude and use a high accuracy PLL (phase-locked loop) circuit for timing. Compared to signals generated by typical low-cost DDS function and arbitrary waveform generators, this implementation significantly minimizes jitter and improves edge stability of square waves. The improved signal integrity allows these generators to be used for simulating reliable clock signals, generating triggers, or validating serial data buses. Models 4014B and 4040B are 12 MHz and 20 MHz DDS (direct digital synthesis) function generators that generate stable and precise sine, square, and triangle waveforms. Both models provide variable output voltages from 0 to 10 Vpp into 50 Ω (up to 20 Vpp into open circuit), linear and logarithmic sweep, AM/FM modulation, built-in counter, and a continuously variable DC offset that allows the output to be injected directly into circuits at the correct bias level. Separate output amplitude and DC offset amplifiers let you set a large DC offset (e.g. ± 4.99 V ) with a small amplitude output signal (e.g. 10 mV), a feature typically found in more expensive generators. These models are suitable for education and other applications that require digital function generators with sweep and modulation capabilities. The 4014B and 4040B are both designed with a dual technology architecture, combining traditional DDS technology with a low-jitter square wave generator. The instruments Sine and square waveforms up to 12 MHz (4014B) or 20 MHz (4040B) ■ Triangle/ramp waveforms up to 1 MHz (4014B) or 2 MHz (4040B) ■ Bright color display with waveform preview ■ Linear and logarithmic sweep ■ AM/FM modulation ■ Independent output and DC offset amplifiers allow for small amplitude output signals with large DC offsets ■ Low-jitter square wave generation ■ Adjustable duty cycle ■ Output ON/OFF button ■ Internal/external triggering ■ Gate and burst mode (4040B only) ■ Built-in counter ■ USB interface ■ SCPI-compliant command set ■ Short circuit and overvoltage protection on all inputs and outputs Model 4014B 4040B Sine and square frequency range 0.01 Hz - 12 MHz 0.01 Hz - 20 MHz Triangle/ramp frequency range 0.01 Hz - 1 MHz 0.01 Hz - 2 MHz Technical data subject to change © B&K Precision Corp. 2018 www.bkprecision.com DDS Function Generators Models 4014B and 4040B Front panel Color LCD display Dedicated waveform keys Numeric keypad Intuitive user interface Rotary control knob Output On/Off button Easily change all waveform parameters using the intuitive menu-driven front panel keypad, rotary control knob, and large color LCD display that shows a preview of the output waveform. Convenient waveform and range selection buttons let users make quick and precise adjustments to the output signal. Versatile tools Main output Menu function keys Lin/Log sweep key Modulation key Utility key Sync output Both models provide AM and FM modulation along with linear/logarithmic sweep and built-in counter capabilities. Internal and external sources can be used for triggering and modulating the signal. Rear panel Trigger/counter input connector Easy PC connectivity Modulation input connector 2 USB interface The function generators can be programmed remotely via the USB (virtual COM) interface using SCPI commands. B&K Precision also offers application software (available for download at www.bkprecision.com) that provides virtual front panel emulation, allowing users to remotely control their instrument without the need for programming. www.bkprecision.com DDS Function Generators Models 4014B and 4040B Specifications 4014B 4040B Sine 0.01 Hz to 12 MHz 0.01 Hz to 20 MHz Square 0.01 Hz to 12 MHz 0.01 Hz to 20 MHz Triangle 0.01 Hz to 1 MHz 0.01 Hz to 2 MHz Frequency Characteristics Modulation Characteristics Amplitude Modulation Internal Resolution 6 digits* or 10 mHz External Accuracy 0.01% ± 0.006 Hz Frequency Modulation Output Characteristics Amplitude Range 10 mVpp to 10 Vpp (into 50 Ω); 20 mVpp to 20 Vpp (open circuit) Amplitude Resolution 3 digits (1,000 counts) Amplitude Accuracy ± 2% ± 20 mV of programmed output from 1.01 V – 10 V Flatness ± 0.5 dB to 1 MHz ± 1 dB to 12 MHz ± 0.5 dB to 1 MHz ± 1 dB to 20 MHz DC Offset Range -4.99 V to 4.99 V (into 50 Ω) DC Offset Resolution 10 mV, 3 digits DC Offset Accuracy ± 2% ± 10 mV (into 50 Ω) Output Impedance 50 Ω ± 2% Output Protection Protected against short circuit or accidental voltage applied to the main output connector Waveform Characteristics Harmonic Distortion 0 – 1 MHz, < -60 dBc (for sine wave at 1 MHz – 5 MHz,
4014B 价格&库存
很抱歉,暂时无法提供与“4014B”相匹配的价格&库存,您可以联系我们找货
