Data Sheet
DDS Sweep Function Generators
Models 4014B and 4040B
Features & Benefits
generate a 2-point waveform to simulate the
amplitude and use a high accuracy PLL
(phase-locked loop) circuit for timing. Compared
to signals generated by typical low-cost DDS
function and arbitrary waveform generators, this
implementation significantly minimizes jitter and
improves edge stability of square waves. The
improved signal integrity allows these generators
to be used for simulating reliable clock signals,
generating triggers, or validating serial data
buses.
Models 4014B and 4040B are 12 MHz and
20 MHz DDS (direct digital synthesis) function
generators that generate stable and precise sine,
square, and triangle waveforms. Both models
provide variable output voltages from 0 to
10 Vpp into 50 Ω (up to 20 Vpp into open
circuit), linear and logarithmic sweep, AM/FM
modulation, built-in counter, and a continuously
variable DC offset that allows the output to be
injected directly into circuits at the correct bias
level. Separate output amplitude and DC offset
amplifiers let you set a large DC offset (e.g.
± 4.99 V ) with a small amplitude output signal
(e.g. 10 mV), a feature typically found in more
expensive generators.
These models are suitable for education and
other applications that require digital function
generators with sweep and modulation
capabilities.
The 4014B and 4040B are both designed
with a dual technology architecture, combining
traditional DDS technology with a low-jitter
square wave generator. The instruments
Sine and square waveforms up to
12 MHz (4014B) or 20 MHz (4040B)
Triangle/ramp waveforms up to
1 MHz (4014B) or 2 MHz (4040B)
Bright color display with waveform preview
Linear and logarithmic sweep
AM/FM modulation
Independent output and DC offset amplifiers
allow for small amplitude output signals with
large DC offsets
Low-jitter square wave generation
Adjustable duty cycle
Output ON/OFF button
Internal/external triggering
Gate and burst mode (4040B only)
Built-in counter
USB interface
SCPI-compliant command set
Short circuit and overvoltage protection on all
inputs and outputs
Model
4014B
4040B
Sine and square frequency range
0.01 Hz - 12 MHz
0.01 Hz - 20 MHz
Triangle/ramp frequency range
0.01 Hz - 1 MHz
0.01 Hz - 2 MHz
Technical data subject to change
© B&K Precision Corp. 2018
www.bkprecision.com
DDS Function Generators
Front panel
Color LCD display
Dedicated
waveform keys
Numeric keypad
Intuitive user interface
Rotary
control knob
Output
On/Off button
Easily change all waveform parameters using the
intuitive menu-driven front panel keypad, rotary
control knob, and large color LCD display that
shows a preview of the output waveform.
Convenient waveform and range selection buttons
let users make quick and precise adjustments to
the output signal.
Versatile tools
Main output
Menu function keys
Lin/Log sweep key
Modulation
key
Utility
key
Sync output
Both models provide AM and FM modulation
along with linear/logarithmic sweep and built-in
counter capabilities. Internal and external sources
can be used for triggering and modulating the
signal.
Rear panel
Trigger/counter input connector
Easy PC connectivity
Modulation input connector
2
USB interface
The function generators can be programmed
remotely via the USB (virtual COM) interface
using SCPI commands. B&K Precision also offers
application software (available for download at
www.bkprecision.com) that provides virtual front
panel emulation, allowing users to remotely
control their instrument without the need for
programming.
www.bkprecision.com
Specifications
4014B
4040B
Sine
0.01 Hz to 12 MHz
0.01 Hz to 20 MHz
Square
0.01 Hz to 12 MHz
0.01 Hz to 20 MHz
Triangle
0.01 Hz to 1 MHz
0.01 Hz to 2 MHz
Frequency Characteristics
Modulation Characteristics
Amplitude Modulation
Internal
Resolution
6 digits* or 10 mHz
External
Accuracy
0.01% ± 0.006 Hz
Frequency Modulation
Output Characteristics
Amplitude Range
10 mVpp to 10 Vpp (into 50 Ω);
20 mVpp to 20 Vpp (open circuit)
Amplitude Resolution
3 digits (1,000 counts)
Amplitude Accuracy
± 2% ± 20 mV of programmed output from 1.01 V – 10 V
Flatness
± 0.5 dB to 1 MHz
± 1 dB to 12 MHz
± 0.5 dB to 1 MHz
± 1 dB to 20 MHz
DC Offset Range
-4.99 V to 4.99 V (into 50 Ω)
DC Offset Resolution
10 mV, 3 digits
DC Offset Accuracy
± 2% ± 10 mV (into 50 Ω)
Output Impedance
50 Ω ± 2%
Output Protection
Protected against short circuit or accidental voltage applied
to the main output connector
Waveform Characteristics
Harmonic Distortion
0 – 1 MHz, < -60 dBc
(for sine wave at
1 MHz – 5 MHz,
很抱歉,暂时无法提供与“4040B”相匹配的价格&库存,您可以联系我们找货
