2005B
2005B
    B&K
    RF GENERATOR TO 450MHZ
2005B 数据手册
Data Sheet 150 MHz RF Generator Model 2005B Specifications 2005B Main Output Frequency Range The 2005B supplies sine wave outputs from 100 kHz to 150 MHz (harmonics usable to 450 MHz) at up to 100 mV (RMS). The output can be amplitude modulated with an internal 1 kHz signal or with an external audio signal up to 1 V (RMS). An external crystal can be plugged in for precise frequency control. The output is provided via a BNC female connector. ■ 100 kHz to 150 MHz on six bands ■ Output to 450 MHz on harmonics ■ AM modulation, internal or external Step and variable attenuation 100 kHz to 150 MHz (up to 450 MHz on third harmonics) A) 100 kHz-300 kHz B) 300 kHz-1 MHz C) 1 MHz-3.2 MHz D) 3 MHz-10 MHz E) 10 MHz-35 MHz F) 32 MHz-150MHz (96-450 MHz on harmonics) Dial Accuracy ±3% RF Output Level Continuously variable. Step attenuator provides approximately 20 dB of attenuation Maximum Output Approximately 100 mV rms to 35 MHz. Continuously variable in hi or lo step, at least 20 dB range of adjustment Frequency Monitor Output Frequency 100 kHz to 150 MHz Level 50 mV rms min. fixed, unmodulated signal Amplitude Modulation Internal Frequency 1 kHz; level continuously variable. Modulation signal available at front panel jack; fixed 1 V rms (min) into approx. 10 kΩ External Frequency 50 Hz to 20 kHz Sensitivity Approximately 100 mV rms General AC Input 120/220/240V ±10%, 50/60 Hz Dimensions (HxWxD) 5.91 x 9.84 x 5.12" (150 x 250 x 130 mm) Weight 5.5 lbs. (2.5 kg) Included Accessories BNC to insulated clip output cable, detachable power cord, and instruction manual One-Year Warranty Technical data subject to change © B&K Precision Corp. 2014 v080514 www.bkprecision.com
2005B 价格&库存
很抱歉,暂时无法提供与“2005B”相匹配的价格&库存,您可以联系我们找货
