4030
    B&K
    10MHZ PULSE GENERATOR
4030 数据手册
Data sheet 10 MHz Pulse Generator with 4-Digit LED Display Model 4030 The B&K Precision Model 4030 is a versatile signal source which combines four functions into one unit – waveform generation, pulse generation (through variable symmetry), frequency sweep operation, and triggered operation. The 4030 offers low rise and fall time pulsed signals up to 10MHz to meet many test and measurement applications. Specifications Model 4030 Frequency Range Internal 0.1 Hz to 10 MHz in 8 decade ranges & variable Crystal Tal Spot frequencies 1 Hz, 10 Hz, 100 Hz, 1 KHz, 10 KHz, 100 KHz, 1 MHz, 10 MHz Rate 100 ns – 0.1s Internal 0.1 Hz to 10 MHz External 10 Hz to 10 MHz Triggering Features and Benefits ■ *Manual trigger available for 10 MHz (100 ns) rate only. Not available with any other rate settings. Ext. Trig-Input +1 V to +10 V p-p sine & square waveform Width 50 ns - 50 ms (6 decade ranges & variable) Delay 0-2 uS variable w.r.t. trigger Output Polarity Normal/Inverting Output Main Out typical 1 V - 10 V (open circuit) Pulse Out typical 0.5 V - 5 V at 50 Ω Impedance 50 Ω Rise & Fall Time 10 ns approximately Output Terminal BNC Connector General AC Input 115/230 V AC +10%, 50/60 Hz Consumption 10 VA Dimensions (WxHxD) 10.3’ x 4.4’ x 12.4’ (26.2 x 11.2 x 31.5 cm) Weight 5.5 Lbs (2.5 kg) Included Accessories Power cord, instruction manual, and BNC to alligator clip cable One-Year Warranty Technical data subject to change © B&K Precision Corp. 2020 v042020 Adjustable frequency range from 0.1 Hz to 10 MHz 1 pulse per sec (*for 10 MHz rate only) Manual Applications With this versatility, it has a vast number of applications in both analog and digital electronics in the engineering, manufacturing, servicing, educational, and hobbyist fields. w w w.bk prec ision.c om Tel.: 714.921.9095 ■ Four digit LED frequency display ■ Invertible polarity ■ Single pulsed output via manual trigger
很抱歉,暂时无法提供与“4030”相匹配的价格&库存,您可以联系我们找货
