Data Sheet
20MHz DDS Sweep Function Generator
with Arb Function
Model 4045
The model 4045 DDS Function Generator is a
must-have for anyone needing a low cost, full
featured direct digital synthesis (DDS) function
generator with arbitrary waveform capabilities. The
4045 has a menu-driven front panel interface that
includes a large, easy-to-read graphical LCD display.
Waveform parameter changes and data entry can be
made using the rotary knob or via the built-in USB
interface. The unit generates superb quality
waveforms with high signal precision and stability.
It provides sine & square wave outputs over the
frequency range from 0.1 Hz to 20 MHz in one
extended range (triangle/ramped wave outputs to
2MHz). Arbitrary waveforms can be edited from
scratch or by modifying standard waveforms. A full
range of triggering capabilities is available, including
internal-external trigger source, gated and burst
modes of operation.
Graphical LCD display
USB connection
20MHz Frequency Range (sine & square only)
Sine, Square & Triangle waveforms
Arbitrary waveforms to 1,000 points
Clean, precise DDS waveform generation
Modulation in both AM & FM
Frequency Range
0.1Hz to 20MHz (sine & square wave only)
Lin or Log Sweep Function
Waveforms
Sine, Square, Triangle, Arbitrary, Ramp, Pulse
Adjustable Duty Cycle
Amplitude
10V p-p into 50Ω
Adjustable DC Offset
Attenuation
-20dB +1dB
Bright informative LCD
Offset
± 4.5V into 50 Ω (amplitude dependent)
USB Interface
Free downloadable software
Distortion (for sine wave at
5 Vp-p into 50 Ω)
DC-20KHz = -55 dBc
Square Rise/Fall Time
很抱歉,暂时无法提供与“4045”相匹配的价格&库存,您可以联系我们找货
