709
Data Sheet
02.11
709 Combustion Analyzer
Test the TPI Advantage
Features
QUICK AND SIMPLE
SET UP All TPI
analyzers feature
quick and simple
set up. Fast purge
and the ability to
performfuel
selectionduring start
up enable tests to be
performed quickly
without requiring
extra set-up time
after initial startup.
TPI analyzers also
use the last selected
fuel as the default
setting. This feature
prevents the need
toperform fuel
selection every time
the analyzer is
turned on.
• Built-in differential
manometer with
0.001” H2O
resolution
• Calculates
combustion
efficiency
• Pump driven for
fast response
• Will not shut off if
15 ppm CO is
present for
increased safety
• Optional A740 IR
printer available for
hard copies of test
results
thermometer
• Store function to
save up to 50
readings
• Push on fittings for
fast and easy use
• Large easy to read
backlit display
• Ten selectable fuels
www.tpithevalueleader.com
Specifications
Instrument
Operating Temperature Range
14°F to +122°F (-10°C to +50°C)
Battery / Batery Life
AA (3) / > 6 Hours
Fuels
Natural Gas, LPG, Light Oil, Heavy
Oil, Bituminous Coal, Anthracite
Coal, Coke, Butane, Wood, Bagasse
Units of Pressure
mbar, kPa & inH2O
Display
3 Line Backlit LCD w/ annunciators
Data Storage
50 sets of readings
Time & Date
24 Hour Real Time Clock
Dimensions
7.8” x 3.5” x 2.4”
Weight
1.1lbs
Gases
Oxygen
Carbon Monoxide
Carbon Dioxide
CO/CO2 Ratio
Combustion Eff.
Range
0-25%
0-10,000 ppm
0-25%
0-0.999
0-100%
Resolution
0.1%
1 ppm
0.1%
0.001
0.1%
Accuracy
+/- 0.3%
+/- 5 ppm or 5%
Calculated
Calculated
Calculated
Pressure Measurement
Selectable Ranges
Range
Resolution
Accuracy
mbar, kPa and inH2O
-120 inH2O to 120 inH2O
0.001 inH2O
+/- 0.5% fsd
Temperature Measurement
Input Type
Range
Resolution
Accuracy
K-Type thermocouple
-58°F to 1832°F (-50°C to 1000°C)
1°F (1°C)
+/- (0.3% of rdg + 2°F) or +/- (0.3% of rdg + 1°C)
A787 Soft Carrying Case
A770 Flue Probe
GK11M K-type
thermocouple
A763 Mini pump
protection filter
A774 Silicone Tubing
Copyright © 2011 Test Products International, Inc.
很抱歉,暂时无法提供与“709”相匹配的价格&库存,您可以联系我们找货
