706
High CO Analyzer
Features
Specifications
QUICK AND SIMPLE SET UP All TPI analyzers feature quick and simple set up. Fast purge and the ability to perform
fuel selectionduring start up enable tests to be performed quickly without requiring extra set-up time after initial startup. TPI analyzers also use the last selected fuel as the default setting. This feature prevents the need toperform fuel
selection every time the analyzer is turned on.
• Pump driven for fast response
• Will not shut off if 15 ppm CO is present for increased safety
• Optional A740 IR printer available for hard copies of test results
• Store function to save up to 50 readings
• Push on fittings for fast and easy use
• Large easy to read backlit display
Instrument
Operating Temperature Range
Battery / Batery Life
Display
Data Storage
Time & Date
Dimensions
Weight
14°F to +122°F (-10°C to +50°C)
AA (3) / > 6 Hours
3 Line Backlit LCD w/ annunciators
50 sets of readings
24 Hour Real Time Clock
7.8” x 3.5” x 2.4”
1.1lbs
Gas
Range
Carbon Monoxide
0-9,999 ppm
Over 9,999ppm displays in percent
1-9.999%
706 Contents
706 CO Analyzer
A787 Soft Carrying Case
Resolution
1 ppm
Accuracy
+/- 5 ppm or 5%
0.001%
+/-5% of reading
A763 Mini pump
protection filter
A785 Exhaust Probe
Copyright © 2008 Test Products International, Inc.
Features
很抱歉,暂时无法提供与“706”相匹配的价格&库存,您可以联系我们找货
