Temperature
Probes
Probe Tips
Penetration / Immersion
Type “F”
20 Pointed penetration
21 Tapered penetration
22 Chisel penetration
24 Rounded Immersion
26 Corkscrew penetration
28 Alligator Immersion
Surface/Contact
Type “C”
30 Flat disk (Thermistor)
32 Ribbon
34 Between pack
36 Heavy duty spring
Air/Gas
Type “G”
40 Air (Thermistor)
42 Beaded thermocouple
44 Hooded
46 Caged
48 Caged with rack clip
Sub-Mini Connector
Lumberg Connector
Bipolar
Connectors
Temperature Probe
Catalog V101
Three Year Limited Warranty on TPI Products
Copyright © 2008 Test Products International, Inc.
www.tpi-thevalueleader.com • 503.520.9197
Probe Tips
Probe Type
Type “F”
F: Penetration/immersion
C: Contact/Surface
G: Air/Gas
Sensor Type
K: Type K-thermocouple
T: Type T-thermocouple
J: Type J-thermocouples
X: Thermistor (PST)
Connector Type
M- Sub-miniature
L- Lumberg connector
B- Bipole
F
K
21
M
Surface/Contact
Type “C”
Sequential Number
32 Ribbon
34 Between pack
What is the difference between thermocouple and thermistor probes?
Thermocouple probes utilize the reaction between two dissimilar metals to produce a voltage that changes as
temperature changes. A thermistor is a resistive with a change in temperature. In general, thermocouples
offer a wider temperature range and quicker response time than thermistors. Thermistors are typically more
accurate than thermocouples.
What are the differences between thermocouple types?
Each thermocouple uses different metals and there fore have different characteristics. Here are general
guidelines:
K-Type- Wide temperature range used in many digital thermometers. Identified by a yellow connector.
T-Type- Narrower temperature range than J-type but more accurate than K and J types, used in digital
thermometers. Identified by a blue connector.
J-Type- Narrower temperature reange the K-Type used in analog and digital thermometers. Identified by
a black connector.
Air/Gas
Type “G”
40 Air (Thermistor)
44 Hooded
46 Caged
Can different thermocouple types be interchanged?
No. Since each thermocouple type uses different metals in it’s construction they have different output
characteristics. Using a J-type thermocouple in a K-type thermometer will cause measurements to be very
inaccurate.
What are the differences between the connector types TPI offers?
Sub-Mini- This is an industry standard connector type allowing TPI probes to be used in any thermocouple
thermometer using this type of connector. Sub-mini connectors are quick and easy to use, simply push in and
out. A wide variety of economical probes are available with sub-mini connectors, enhancing versatility and
affordability of the temperature tester.
Lumberg- This connector uses a screw collar to attach to the thermometer and is the most secure connection
available. Lumberg connectors are designed for the rigors of food processing environments. Advantages
include:
• Strong connection - stainless steel collar holds and protects connection. Probe will not
pull out of instrument with out unscrewing the collar.
• Waterproof stainless steel will not rust and is ideal for wet, humid conditions
• Lumberg connectors are manufactured following ISO9000 quality control guidelines.
Bi-Polar- This connector is used in the TPI thermistor probe line.
2
Sub-Mini
Connector
Lumberg
Connector
Bipolar
Connectors
REFER TO THE TPI WEBSITE FOR ADDITIONAL OR OEM PROBE OPTIONS
Contact/Surface Probe Applications (C)
Penetration / Immersion Probe Applications (F)
• Measure grill temperature to assure correct cooking temperatures.
• Check internal food temperatures to assure quality control.
• Measure deep fat fryers with a high temp immersion probe.
• Measure liquids and semi-solid temperatures in food processing applications.
• Use a reduced tip probe for quicker response times where time is crucial to
the process.
• Check frozen food to assure proper storage temperatures.
• Measure temperatures between package to ensure proper
quality control.
• Check any surface for correct process control temperatures.
Air/Gas Probe Applications. (G)
• Measure superheats on condensers.
• Measure air temperatures in duct work.
• Measure air temperature coming from diffusers while Trouble-shooting heating
and air conditioning systems.
• Measure flame temperatures to trouble-shoot industrial heating applications.
• Calibrate thermostats using an ambient air probe.
• Measure griddle temperature.
• Measure mackinery or mold temperature with a surface probe.
• Measure pipe temperatures in any industrial application.
Penetration/Immersion (F)
Probe
Tips
Use for penetation into solids and immersion
into semi-solids & liquids.
Contact/ Immersion (C)
Air/Gas (G)
Measure air or gas temperatures
Designed to measure surface temperatures
Pointed: Can be used in air with slower response Ribbon: Fast response.
Chisel: Can be used in air and on surfaces with
Spring: Heavy duty sensing element for higher
slower response
Tapered: Heavy duty, large diameter shaft for
bend resistant
Beaded: Flexible, can be used in some liquid
immersion applications
Hooded: Rigid, hood provides protection for the
sensing element.
Caged: Rigid, cage provides maximum protection for the sensing element.
What type of probe should I use?
The type of probe you use depends upon your application. Here are some general guidelines for different types of probes.
Penetration/Immersion (F) General purpose probe used for penetration and immersion; can be used for air, but is much slower than an air probe.
Need to select the tip type that best cuits the application.
Contact/Surface (C) Contact probes are used to measure surface temperatures. Penetration probes, with the exception of the chisel tip, can’t measure
surface temperatures. Need to select the tip type that best suits the application
Air/Gas (G) Air probes measure the air or gas temperatures. They respond significantly faster than penetration or contact probes in air. Need to select
the tip type that best fits the application.
K-Type Thermocouple with Sub-Mini Connector Probes
Model #
Description
Application
Range°F°C
Contact temperaCK11M
-58° to 500°F
Contact surface
tures on flat and
-50° to 250°C
probe, water proof uneven surfaces
CK12M
Contact temperaContact surface
tures on flat and
probe, right angle,
uneven
surfaces
waterproof
Contact temperaCK13M
tures on flat and
Heavy-duty contact
uneven high temsurface probe
perature surfaces
CK14M
Contact temperaRight angle heavy- tures on flat and
duty contact surface uneven high temprobe
perature surfaces
CK15M
Contact temperaHeavy-duty contact tures on flat and
surface probe for uneven high temperature surfaces
HK11M handle
Probe
tip
32
-58° to 500°F
-50° to 250°C
32
-58° to 1202°F
-50° to 650°C
36
-58° to 1202°F
-50° to 650°C
36
-40° to 950°F
-40° to 510°C
36
Dimensions
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
4" (102mm)
0.13" (3.2mm)
39.4" (1M)
N/A
4" (102mm) w/90° bend
0.3" (7.5mm)
39.4" (1M)
N/A
4" (102mm)
0.6" (14mm)
39.4" (1M)
N/A
6" (152mm) w/90° bend
0.6" (14mm)
39.4" (1M)
N/A
8" (203mm)
0.6" (14mm)
N/A
N/A
Insulation
Material
Polyurethane
Polyurethane
Polyurethane
Polyurethane
N/A
3
Model #
Description
Range°F°C
Probe
tip
-40° to 950°F
-40° to 510°C
36
-40° to 500°F
-50° to 250°C
32
CK18M
Contact surface
probe
Contact temper-58° to 500°F
atures on flat
-50° to 250°C
surfaces
32
CK20M
Pipe clamp probe
Clamp probe for
-58° to 212°F
pipe tempera-50° to 100°C
tures
N/A
CK21M
Pipe clamp probe
Clamp probe for
-58° to 212°F
tures
N/A
Application
Contact temperaCK16M
tures on flat and
Heavy-duty contact
perature surfaces
CK17M
tures on flat and
probe, 45 degree
uneven surfaces
angle
CK22M
Contact temper-
atures on flat -58° to 500°F
Fast response contact
surface probe, 45 degree and uneven sur- -50° to 250°C
faces
angle swivel head sensor
CK23M
32
Contact temper-
surface probe, 90 degree and uneven sur- -50° to 260°C
faces
General purpose
FK11M
penetration into -58° to 500°F
Chisel tip penetrasemi-solids and -50° to 250°C
tion probe
liquids
32
Heavy duty penetra-
FK12M
tion into semi-solids
Pointed tip tapered
and liquids tapered
penetration probe shaft resist bending
FK13M
General purpose
Pointed tip penetra- penetration into
tion probe for
semi-solids and
HK11M handle
liquids
General
purpose
FK14M
penetration into
tion probe
liquids
Food temperature
FK15M
Tapered tip low mass measurements
quick response pene- and other light
tration probe
duty applications
-58° to 500°F
-50° to 250°C
21
-40° to 1562°F
-40° to 850°C
-40° to 1562°F
-40° to 850°C
-58° to 500°F
-50° to 250°C
General purpose light
-58° to 500°F
duty penetration
applications requiring -50° to 250°C
fast response
21
FK22M
-58° to 500°F
duty penetration
Pointed tip penetra- applications requiring
-50° to 250°C
tion probe
fast response
21
General purpose
FK23M
-40° to 950°F
air / liquid probe
Rack clamp probe
-40° to 510°C
with clip
28
FK24M
General purpose
Heavy duty T-handle penetration into -40° to 500°F
long stem penetra- semi-solids and -40° to 250°C
tion probe
liquids
21
FK21M
Tapered chisel tip
penetration probe
4
Dimensions
Stem Length: 8" (203mm)
Diameter:
0.6" (14mm)
Lead Length: 39.4" (1M)
IP Rating:
N/A
Stem Length: 4" (102mm) w/45° bend
Diameter:
0.3" (7.5mm)
IP Rating:
N/A
Stem Length: N/A
Nomin:
2.36" (60mm)
IP Rating:
N/A
Max jaw opening:
0.79"
Nominal jaw opening: 0.25"
Lead Length:
39.4" (1M)
IP Rating:
N/A
Max jaw opening:
1.2"
Nominal jaw opening: 0.75"
Lead Length:
39.4" (1M)
IP Rating:
N/A
Stem Length: 4.5" (114mm) w/45° bend
Diameter:
0.5" (12.7mm)
IP Rating:
N/A
Stem Length: 4.9" (125mm) w/90° bend
Diameter:
0.5" (12.7mm)
IP Rating:
Diameter:
0.13" (3.2mm)
IP Rating:
67
Stem Length: 11.8" (300mm)
Diameter:
0.25 / 0.10" (6.4 / 2.5mm)
IP Rating:
67
Diameter:
0.15" (3.75mm)
Lead Length: N/A
IP Rating:
67
Diameter:
0.15" (3.75mm)
IP Rating:
67
Stem Length: 3.75" (80mm)
Diameter:
0.06 (1.6mm)
IP Rating:
N/A
Stem Length: 4.” (101.6mm)
Diameter:
0.13”/.06” (3.2/1.6mm)
Lead Length: 39.4” (1M)
IP Rating:
67
Stem Length: 4" (101.6mm)
Diameter:
0.09/0.06" (3.2/2.5mm)
IP Rating:
N/A
Stem Length: N/A
Diameter:
N/A
Lead Length: 177" (4.5M)
IP Rating:
67
Stem Length: 24" (610mm)
Diameter:
0.37"/0.15" (9.5mm/3.76mm)
IP Rating:
67
Insulation
Material
Polyurethane
Polyurethane
Polyurethane
Polyurethane
Polyurethane
Polyurethane
Polyurethane
Polyurethane
Polyurethane
N/A
Polyurethane
Teflon
Polyurethane
Teflon
Teflon
Polyurethane
Model #
Description
Application
Range°F°C
Probe
tip
FK25M
Flat sensor
pack probe
Between pack
temperatures
-40° to 400°F
-40° to 204°C
34
FK26M
Petes plug probe
Petes plug
temperatures
-40° to 400°F
-40° to 204°C
24
FK27M
Waterproof long
stem heavy duty
penetration probe
General purpose
liquids
21
FK28M
Heavy duty
penetration probe
Heavy duty penetration into semi-solids -58° to 500°F
and liquids tapered -50° to 250°C
22
General purpose
FK29M
penetration into
Long stem pointed
semi-solids and
tip penetration probe
liquids
Heavy duty penetraFK30M
Long stem heavy tion into semi-solids
duty T-handle pene- and liquids tapered
tration probe
-58° to 500°F
-50° to 250°C
22
-58° to 500°F
-50° to 250°C
22
FK31M
General purpose
-58° to 500°F
T-handle corkscrew penetration into
-50° to 250°C
insertion probe
semi-solids
26
Must be used with EXT31M extension (included)
FK32M
Long stem heavy
duty T-handle penetration probe
24
GK11M
General purpose
beaded tip probe
Exposed junction for
fast response in non- -40° to 950°F
food liquid, air and -40° to 510°C
surface applications
42
GK12M
General purpose
beaded tip probe
with rack clip
Exposed junction for fast
response in air
applications.
-40° to 950°F
-40° to 510°C
42
GK13M
General purpose
beaded tip probe
Exposed junction
for fast response in -40° to 400°F
food and non-food
liquid, air and sur- -40° to 204°C
face applications
42
response in air
applications.
-58° to 910°F
-40° to 510°C
44
GK16M
Caged exposed
-40° to 500°F
General purpose caged
junction for fast
air probe for use with
-40° to 260°C
response in air
HK11M handle
46
GK14M
Rigid stem hooded
exposed tip probe
GK17M
General purpose
caged air probe
Caged exposed
-40° to 500°F
junction for fast
-40° to 260°C
response in air
46
GK18M
air probe with rack clip
and armored cable
GK19M
General purpose
beaded tip probe
with armored cable
Caged exposed
-40° to 586°F
junction for fast
-40° to 308°C
response in air
48
Exposed junction
for fast response in -40° to 950°F
non-food liquid, air
and surface appli- -40° to 510°C
cations
42
Dimensions
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
N/A
N/A
39.4" (1.2M)
67
3" (76mm)
0.12" (3mm)
39.4" (1M)
67
11.8" (300mm)
0.25"/0.10" (6.4mm/2.5mm)
39.4" (1M)
67
6.3" (160mm)
0.13" (3.2mm)
39.4" (1M)
N/A
6.3" (160mm)
0.13" (3.2mm)
39.4" (1M)
N/A
24" (609.60mm)
0.38" (9.5mm)
39.4” (1M)
67
4.5" (114mm)
0.20" (5mm)
39.4" (1M)
67
18" (457mm)
39.4" (1M)
67
N/A
28 gauge
48" (1.2M)
N/A
N/A
20 gauge
48" (1.2M)
N/A
N/A
24 gauge
48" (1.2M)
N/A
3.74" (95mm)
0.13" (3.75mm)
39.4" (1M)
N/A
8" (203mm)
0.26" (6.5mm)
39.4" (1M)
N/A
8" (203mm)
0.26" (6.5mm)
39.4" (1M)
N/A
N/A
N/A
39.4" (1M)
N/A
N/A
28 gauge
48" (1.2M)
N/A
Insulation
Material
Polyurethane
Polyurethane
Polyurethane
Polyurethane
Polyurethane
Polyurethane
Polyurethane
Polyurethane
Fiberglass
Fiberglass
Teflon
Polyurethane
N/A
Polyurethane
Braided
stainless steel
Braided
stainless steel
5
Model #
Description
Application
Range°F°C
GK20M
Flue temperature
probe
Exposed junction
with cone stop, fast
response in flue
temperature
applications
-40° to 932°F
-40° to 260°C
42
EXT 31M
Male to Male
Extension
Use with
FK31M
N/A
N/A
N/A
N/A
HK11M
Use with
Handle for use with FK13M, CK15M,
K-type interchangeand GK16M
able probe tips
Probe
tip
Dimensions
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
4.33" (110mm)
0.24" (6mm)
16' (4.9M)
N/A
NA
NA
39.4” (1M)
N/A
N/A
N/A
39.4" (1M)
N/A
Insulation
Material
Teflon
Polyurethane
Polyurethane
J-Type Thermocouple with Sub-Mini Connector Probes
Model #
Application
Description
GJ11M
Exposed juncStandard fiberglass
insulation, 4 foot, bead- tion for fast
response
ed end (disposable)
Oven clip to
GJ12M
shield sensor
GJ11M with
from direct
oven clip
radiated heat
Range°F°C
Probe
tip
Dimensions
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
-40° to 950°F
-40° to 500°C
-40° to 950°F
-40° to 500°C
N/A
24 Gauge
1.2
N/A
N/A
24 Gauge
1.2
N/A
Insulation
Material
Fiberglass
Fiberglass
K-Type Thermocouple with Lumberg Connector Probes
Model #
Description
FK21L
Contact surface
probe with ribbon
sensor. Water proof
Probe
tip
Application
Range°F°C
Food
Penetration
-58° to 500°F
-50° to 250°C
21
FK22L
Oven food probe
Testing food
temperatures
during cooking
-58° to 500°F
-50° to 250°C
FK23L
Immersion /
Penetration probe
no handle or lead
Food
Penetration
-58° to 500°F
-50° to 250°C
21
FK25L
Flat sensor pack
probe
Between pack
-40° to 400°F
-40° to 204°C
34
FK26L
Immersion /
Penetration probe
Food
Penetration
-58° to 500°F
-50° to 250°C
Dimensions
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
4” (101.6mm)
0.13/.06” (3.2/1.6mm)
39.4” (1M)
67
4”(101.6mm)
0.09/.06” (3.2/1.6mm)
47.2” (1.2M)
3.9”(100mm)
0.15” (3.75mm)
NA
67
NA
NA
47.2” (1.2M)
67
4”(101.6mm)
.09/.06” (2.4/1.6mm)
39.4” (1M)
67
Insulation
Material
Polyurethane
Teflon
NA
Teflon
Polyurethane
T-Type Thermocouple with Lumberg Connector Probes
Model #
Description
Application
Range°F°C
Probe
tip
CT11L
Surface probe with
ribbon sensor
Surface
Temperatures
Grills
-58° to 500°F
-50° to 250°C
32
Stem Length:
Diameter:
Lead Length:
IP Rating:
4”(102mm)
0.13” (3.2mm)
39.4” (1M)
N/A
General purpose
FT11L
penetation into -148° to 500°F
Chisel tip penetra- semi-solids
and -100° to 250°C
tion probe
liquids
22
Stem Length:
Diameter:
Lead Length:
IP Rating:
4”(101.6mm)
0.13/.15” (3.2mm/2.2mm) Polyurethane
39.4” (1M)
67
6
Dimensions
Insulation
Material
PVC
Model #
Description
Application
Range°F°C
Probe
tip
FT12L
Needle probe
Weiner probe
for food
processing
-148° to 500°F
-100° to 250°C
22
FT15L
Needle probe
Weiner probe
for food processing
-148° to 500°F
-100° to 250°C
22
FT21L
Tapered end for
food penetration
Waterproof
Food
penetration
-148° to 500°F
-100° to 250°C
21
FT22L
Oven food probe
Testing food
temperature
during cooking
-40° to 500°F
-50° to 250°C
22
FT23L
Oven food probe
Testing food
temperature
during cooking
-40° to 950°F
-40° to 510°C
28
-40° to 500°F
-40° to 250°C
21
-148° to 500°F
-100° to 250°C
42
FT24L
General purpose
tion probe
liquids
GT13L
General
Beaded probe
with FDA approved Purpose. Air
insulation
GT19L
Oven clamp probe
Special
-40° to 500°F
hangingClip for
-40° to 510°C
ovens. Air.
48
Dimensions
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Insulation
Material
4”(101.6mm)
0.13”(3.2mm)
PVC
39.4” (1.0M)
67
3.15”(80mm)
0.06”(1.6mm)
Teflon
39.4” (1.2M)
N/A
3.75”(95.3mm)
3.2/1.6mm
PVC
39.4” (1.0M)
67
3.93”(100mm)
0.13” (3.2mm)
Teflon
98.4” (2.5M)
N/A
NA
NA
Teflon
177.2” (4.5M)
N/A
24" (610mm)
0.37"/0.15" (9.5mm/3.76mm) Polyurethane
39.4" (1M)
67
NA
NA
Teflon
47.2” (1.2M)
67
NA
NA
SS
39.4” (1M)
67
Thermistor Probe with Lumberg Connectors
Model #
Description
FX11L
Liquid immersion
probe
Application
Range°F°C
General
-40° to 300°F
Purpose, Liquid -40° to 150°C
Probe
tip
24
Dimensions
Stem Length:
Diameter:
Lead Length:
IP Rating:
4”(102mm)
0.13” (3.2mm)
39.4” (1M)
67
Insulation
Material
PVC
Thermistor Probe with Bipolar Connectors
Model #
Description
Application
Range°F°C
Probe
tip
CX13B
Surface flat disk
probe
Surface
-40° to 300°F
-40° to 150°C
30
FX12B
Liquid immersion
probe
General Purpose
-40° to 300°F
-40° to 150°C
24
FX13B
Liquid immersion
probe
General Purpose
-40° to 300°F
-40° to 150°C
24
GX15B
Shielded air probe
Air
-40° to 300°F
-40° to 150°C
44
EX11B
extension lead
Thermistor
probes
N/A
NA
Dimensions
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
Stem Length:
Diameter:
Lead Length:
IP Rating:
3.15”(80mm)
0.3” (7.5mm)
15.7” (0.4M)
N/A
3.15”(80mm)
0.13” (3.2mm)
15.7” (0.4M)
N/A
8”(203mm)
0.13” (3.2mm)
15.7” (0.4M)
67
3.15”(80mm)
0.13” (3.2mm)
15.7” (0.4M)
N/A
N/A
N/A
36” (0.9M)
N/A
Insulation
Material
PVC
PVC
PVC
PVC
PVC
7
The Val ue Leader
• Di gi tal Mul ti meters
Probe selection
• Di gi tal Cl amp-Ons
TPI has three basic types of temperature probes: Penetration/Immersion (F),
Contact/Surface (C), and Air/Gas (G).
• Temperature Products
• Combusti on Anal yzers
• Carbon Monoxi de
Penetration/Immersion (F) probes are used for liquids, semi-solids, and solids.
Contact/Surface (C) probes are designed for surface temperatures.
Air/Gas (G) probes are designed to measure air or gas temperatures.
Anal yzers
Select your type of application and probe tip first. Then match the connector type of the
probe to your instrument.
• Combusti bl e Gas
Detectors
• Di gi tal Manometers
• Indoor Ai r Qual i t y
OEM/specialty temperature probes
• Insul ati on Resi stance
Whatever your OEM temperature probe needs are, let TPI help you. Just let us have the
following information, along with your company and contact information.
Testers (IRT)
• Handhel d Osci l l i scopes
• Refri gerati on Leak
Detectors
• Coax / BNC Cabl es and
Adapters
• Osci l l i scope Probes /
SMTP Cl i ps
1.
2.
3.
4.
5.
6.
7.
Application, environment, and operating temperature
New or existing product
Annual usage and release quantities
Connector type or bare wire details
Length of lead wire and straight or coiled wire
Probe tip type and dimensions
Any other special requirements, materials, etc.
• Speci al t y Testers
Cost of ownership temperature probe
Ask us about a customized cost of ownership temperature probe program.
The
Val ue
Leader
Headquarters:
9615 SW Allen Blvd.
Beaverton, OR 97005 USA
503-520-9197
Fax: 503-520-1225
info@tpi-thevalueleader.com
Temperature Probe brochures 07.10.08
Test Products International, Ltd.
342 Bronte St. South Unit #9
Milton, Ontario L9T 5B7 Canada
905-693-8558
Fax: 905-693-0888
info@tpicanada.com
Test Products International UK Ltd.
Longley House, East Park
Crawley, West Sussex RH10 6AP
England
Tel: +44 (0)1293 561212
Fax: +44 (0)1293 813465
e-mail: info@tpi-uk.com
For additional products, specifications, and info contact TPI at tpi-thevalueleader.com or 800.368.5719
