SURFACE MOUNT TEST CLIPS
DESCRIPTION AND COLOR CHOICE SETS
FEATURES
Access 0.3mm or 1.27mm Pitch Leads
Allows you to attached the clip to a lead on
the smallest of surface mount IC’s. Normal
oscilloscope lead tips are too large and the
probe handle is too heavy to access these
leads.
Gold-Plated hood and contact
Ensure minimal signal loss and constant
contact with highly conductive gold plating.
Fluorine Resin coated barrel extension
The barrel of the clip is fully insulated
eliminating the chance of clip shorting
together.
Assorted Colors
Clips are available in Black, Red, Yellow,
Blue, Green and Gray for easy identification
SPECIFICATIONS
Maximum Voltage: 25VDC
Maximum Amperage: 300mADC
Part No.
NANO CLIPS 0.3 mm
NC2BR
NC6BR
NC6R
NC6B
NC6Y
NC6CBIue
NC6G
NC6GY
NC12
NC1B
NC1GY
NC1Y
NC1G
NC1Blue
NCGround
NCHot
NCDual
LC85
LC65
MICRO CLIPS 1.27 mm
MC1B
MC1G
MC1R
MC12
Description
Package Includes
black, red
black, red
red
black
yellow
blue
green
gray
assorted
black
gray
yellow
green
blue
ground
hot
dual lead
lead out contact
lead out contact
2 clips, 2 lead sets, and ground lead
6 clips, 3 lead sets, and ground lead
12 clips, 6 lead sets, and ground lead
1 clip
1 clip
1 clip
1 clip
1 clip
1 lead
1 lead
1 lead
use with 24-28 AWG wire (solder type)
use crimp tool for Nano clips and micro clips
black
gray
red
assorted
1 clip
1 clip
1 clip
MECHANICAL
Nano clip •
0.3 mm pitch
Micro clip •
1.27 mm pitch
Dimensions in mm
很抱歉,暂时无法提供与“NC12”相匹配的价格&库存,您可以联系我们找货
