NC6R
NC6R
    TPI(TPI 公司)
    KIT NANO-CLIP 6 CLIPS RED
NC6R 数据手册
SURFACE MOUNT TEST CLIPS DESCRIPTION AND COLOR CHOICE SETS FEATURES Access 0.3mm or 1.27mm Pitch Leads Allows you to attached the clip to a lead on the smallest of surface mount IC’s. Normal oscilloscope lead tips are too large and the probe handle is too heavy to access these leads. Gold-Plated hood and contact Ensure minimal signal loss and constant contact with highly conductive gold plating. Fluorine Resin coated barrel extension The barrel of the clip is fully insulated eliminating the chance of clip shorting together. Assorted Colors Clips are available in Black, Red, Yellow, Blue, Green and Gray for easy identification SPECIFICATIONS Maximum Voltage: 25VDC Maximum Amperage: 300mADC Part No. NANO CLIPS 0.3 mm NC2BR NC6BR NC6R NC6B NC6Y NC6CBIue NC6G NC6GY NC12 NC1B NC1GY NC1Y NC1G NC1Blue NCGround NCHot NCDual LC85 LC65 MICRO CLIPS 1.27 mm MC1B MC1G MC1R MC12 Description Package Includes black, red black, red red black yellow blue green gray assorted black gray yellow green blue ground hot dual lead lead out contact lead out contact 2 clips, 2 lead sets, and ground lead 6 clips, 3 lead sets, and ground lead 6 clips, 3 lead sets, and ground lead 6 clips, 3 lead sets, and ground lead 6 clips, 3 lead sets, and ground lead 6 clips, 3 lead sets, and ground lead 6 clips, 3 lead sets, and ground lead 6 clips, 3 lead sets, and ground lead 12 clips, 6 lead sets, and ground lead 1 clip 1 clip 1 clip 1 clip 1 clip 1 lead 1 lead 1 lead use with 24-28 AWG wire (solder type) use crimp tool for Nano clips and micro clips black gray red assorted 1 clip 1 clip 1 clip 6 clips, 3 lead sets, and ground lead MECHANICAL Nano clip • 0.3 mm pitch Micro clip • 1.27 mm pitch Dimensions in mm
很抱歉,暂时无法提供与“NC6R”相匹配的价格&库存,您可以联系我们找货
