Terminology
TPI offers a
complete
line of...
Oscilloscope / Dif fer ential Pr obe Terminology
Oscilloscope / Differential Probes
Use TPI Probes
with:
CO, Combustibles &
Combustion (CEA)
>> Attenuation: Ratio of the output signal to the input signal. Attenuation should remain constant
decreasing by 3dB only as the frequency increases to the maximum bandwidth.
Refrigerant Leak
Detectors
>> Bandwidth: The maximum -3dB frequency that can be expected.
Bench Top,
Portable, Analog,
and Oscilloscopes
>> Cable Length: Length of the cable from the end of the probe to the end of the connector. It is
important to use a probe with just enough cable length for your needs. Long cables increase the
capacitance and propagation delay of the probe.
MARKETS
Digital Manometers
Temperature Contact &
IR Instruments
IAQ: Air Flow /
Humidity
Handheld
Oscilloscopes
Digital Multimeters &
Clamp-on Meters
Accessories & Kits
Test Products
International, Inc.
Headquarters:
9615 SW Allen Blvd.
Beaverton, OR 97005
USA
503-520-9197
Fax: 503-520-1225
email:
info@tpi-thevalueleader.com
Test Products
International, Ltd.
342 Bronte St. South
Unit 9
Milton, Ontario L9T
5B7
Canada
905-693-8558
Fax: 905-693-0888
email:
The IP series monolithic probes have switchable
attenuation and are available in 60 and 250MHz. These
probes are ideal for technicians that need a basic oscilloscope
Electronic
>> IEC 1010: Probes with the IEC 1010 category rating have been designed for safety.
Commercial
>> Input Impedance: The total resistance and capacitance as measured at the tip of the probe. This
specification is used to define the loading effect of a probe. At frequencies under 1MHz the input
resistance of the probe will have the most influence. At higher frequencies the input capacitance will
Industrial
>> Max Input Voltage: The maximum voltage the probe can be used at.
Logic signal and
waveform tests
>> Max Differential Voltage: The maximum differential voltage that can be measured by a
Distributed By:
differential probe
Measure voice /
data signals
TPI also offers three models of high voltage differential probes all with high common mode
rejection, wide bandwidth, and fast rise times. Differential probes enable the viewing of signals
not referenced to earth ground and provide better performance than a matched pair of single
ended oscilloscope probes when measuring these types of signals.
>> Readout: Probes with this capability are compatible with readout function oscilloscopes that
automatically detect and display the attenuation factor of the probe.
Analyze power
quality
Several important factors must be taken into account when selecting the proper probe.
>> Rise Time: The time required for the leading edge of a pulse to rise from 10% to 90% of its final
value.
Communication
APPLICATIONS
Test motor control
circuits
>> CMRR: Common Mode Rejection Ratio. A measure of a differential probes ability to reject any
signals common to both test points in a differential measurement
The
Value
Leader™
Refer to pages 2-3
for specifications.
To learn about the entire
line of TPI products visit:
www.tpi-thevalueleader.com
L TAW OP 0705
Copyright © 2005 Test Products International, Inc.
probe.
The slimline design P and SP series probes are available in fixed or switchable attenuation.
These series of probes are perfect for the technician needing additional features such as
replaceable cable and interchangeable probe tip. The compensation adjustment for these probes
is located in the BNC to eliminate noise pickup.
• The probe should have sufficient bandwidth and rise time for the test instrument and
application. Choose a probe with at least an equal bandwidth as the scope it will be used with.
For best performance a probe with twice the bandwidth as the scope should be selected.
• For oscilloscope probes, the input capacitance of your oscilloscope should
be within the compensation range specification of the probe. In
addition, if your oscilloscope has readout function, select a
probe with this capability.
Distributed by:
Test Products
International UK Ltd.
contactus@tpieurope.com
Selecting the correct oscilloscope probe ensures accuracy and can
improve the performance of your test instrument. TPI offers a
wide range of high quality oscilloscope probes designed to
meet the most demanding applications.
>> Compensation Range: The range a probe can be compensated to match the input capacitance of
the test equipment it is being used with.
info@tpicanada.com
Longley House, East Park
Crawley, West Sussex
RH10 6AP England
Tel: +44 (0)1293 561212
Fax: +44 (0)1293813465
Oscilloscope / Differential Probe Selection
• For differential probes, make sure the maximum
differential voltage is adequate for your application
and the common mode rejection specification meets
the requirements of the tests being performed.
Refer to the oscilloscope and differential probe specification tables
to select the correct probe for your application.
Oscilloscope Probe Specifications
Differential Probe Specifications
SPECIFICATIONS
SPECIFICATIONS
Model Bandwidth Attenuation Cable Input Impedance Max Input V
Length
R
L
DC + peak AC
IP060
60MHz
IP250
250MHz
SP 60B
60MHz
SP 100B
100MHz
SP150B
150MHz
SP 200B
200MHz
SP 250B
250MHz
SP 300B
300MHz
1P20B
P100B
P100BR
P200B
P250
P250R
P250B
P250BR
x1
x10
x1
x10
x1
x10
x1
x10
x1
x10
x1
x10
x1
x10
x1
x10
15MHz
100MHz
100MHz
200MHz
250MHz
250MHz
250MHz
250MHz
x1
x10
x10
x10
x100
x100
x10
x10
1.5M
1.5M
1.2M
1.2M
1.2M
1.2M
1.2M
1.2M
Rise
Time
Compensation
Range
Readout
20 ~ 45 pF
NA
CAT II
10 ~ 60pF
NA
CAT II
5.8ns
10 ~ 30pF
NA
CAT II
3.5ns
10 ~ 35pF
NA
CAT II
2.3ns
10 ~ 35pF
NA
CAT II
1.8ns
10 ~ 35pF
NA
CAT II
1.4ns
10 ~ 35pF
NA
CAT II
1.1ns
10 ~ 35pF
NA
CAT II
1Meg
10Meg
1Meg
10Meg
IP SERIES, SWITCHABLE
200pF
150V
6ns
22pF
300V
200pF
150V
1.5ns
22pF
300V
1Meg
10Meg
1Meg
10Meg
1Meg
10Meg
1Meg
10Meg
1Meg
10Meg
1Meg
10Meg
SP SERIES, SWITCHABLE
47pF
150V
18pF
300V
47pF
150V
16pF
300V
47pF
150V
15pF
300V
47pF
150V
15pF
300V
47pF
150V
14pF
300V
47pF
150V
13pF
300V
1.2M
1Meg
1.2M 10Meg
1.2M 10Meg
1.2M 10Meg
1.2M 100Meg
1.2M 100Meg
1.2M 10Meg
1.2M 10Meg
NON-SWITCHABLE
47pF
150V
16pF
300V
16pF
300V
15pF
300V
6.5pF
1,500V
6.5pF
1,500V
14pF
300V
14pF
300V
23ns
3.5ns
3.5ns
1.8ns
1.4ns
1.4ns
1.4ns
1.4ns
10 ~ 35pF
10 ~ 35pF
10 ~ 35pF
10 ~ 35pF
10 ~ 35pF
10 ~ 35pF
10 ~ 35pF
NA
NA
Yes
NA
NA
Yes
NA
Yes
IEC1010
CAT II
CAT II
CAT II
CAT II
CAT II
CAT II
CAT II
The
Value
Leader™
Why do TPI oscilloscope probes have a compensation range
and compensation adjustment?
Since the input of every oscilloscope is different our probes have
a compensation adjustment so the capacitance of the probe can
be adjusted to match the capacitance of the scope input. The
compensation range is the range of adjustment available.
Matching probe and scope capacitance is important to prevent
waveform distortion.
Input Voltage
Maximum Differential
Output Voltage
Offset (typical)
Common Mode
ADF25
ADF25A
ADF25C
DC -25 MHz (-3dB)
± 2%
14nS
DC -25 MHz (-3dB)
± 2%
14nS
DC -70 MHz (-3dB)
± 2%
14nS
-80dB
-60dB
-50dB
4M/10pf each
side to ground
8M/5pF
between inputs
±140V DC Inc.Pk AC@
20:1 or 100V RMS
± 1,400VDC Inc. Pk AC
200:1 or 1,000V RMS
± 7V minimum 2KΩ load
-86dB
-66dB
-56dB
4M/10pf each
side to ground
8M/5pF
between inputs
±170V DC Inc.Pk AC@
10:1 or 50V RMS
100:1 or 500V RMS
很抱歉,暂时无法提供与“SP200B”相匹配的价格&库存,您可以联系我们找货
