Data Sheet
True RMS Bench Multimeter
5492B
The B&K Precision model 5492B is a versatile
5½-digit, 120,000-count bench multimeter
suitable for applications in education, service
repair, and manufacturing. The instrument
enhances your productivity with built-in math
functions and USB connectivity. Rel, Max/Min,
dBm, dB, %, and Hold functions provide
educators with a convenient tool to teach basic
math concepts. Additionally, the 5492B offers
powerful features not commonly found in other
5½- digit DMMs such as advanced triggering,
buffer storage operation, and a GPIB interface
option.
Features & benefits
The 5492B measures volts and amps with great
accuracy and stability, with basic VDC accuracy
of 0.01%. The meter is also capable of measuring frequency, period, resistance, continuity, and
performing diode tests. Readings can be taken at
a maximum rate of 57 readings/sec and stored
to an internal 512-byte buffer for post
acquisition statistical analysis.
5½-digit, 120,000-count display resolution
0.01% basic VDC accuracy
Advanced triggering options such as external,
bus and event trigger
Two and four-wire resistance measurement up
to 120 MΩ
AC voltage and AC current measurement over
wide frequency range (ACV 100 kHz/ACI 10
The 5492B was designed for cost-conscious
users requiring an accurate meter with a broad
range of features offered at a value price.
Increase Productivity with PC Connectivity
The 5492B is programmable via USB, RS232,
and GPIB (5492BGPIB only) interface using
industry standard SCPI commands. Users can
remotely control and configure the instrument
from a PC and retrieve measurement results for
further analysis. The multimeter can also be
remotely controlled using application software
(via USB & RS232), which supports front panel
emulation and data logging of measurement
results.
Technical data subject to change
© B&K Precision Corp. 2017
kHz)
AC (RMS) and DC current measurements up
to 12 A
Limit mode for Pass/Fail testing
Save/recall up to 10 instrument settings
Built-in math functions: Rel, Max/Min, dBm,
dB, %, Hold, Limit Test
www.bkprecision.com
CATI (1000 V)/CATII (300 V) protection
USB (Virtual Com) and RS232 interface
SCPI compatible
Model 5492B
▲ Versatile tools
▲ Easy operation
Limit Operation
The limit operation lets you set and control the
values that determine a HI / IN / LO status of
subsequent measurements. The meter can be
configured to emit an audible alarm when
readings are outside of the configured limit.
Front panel
Input banana terminals
Bright VFD display
Advanced Triggering
A variety of advanced trigger options are
available: Manual Trigger via a front panel button
press, Bus Trigger sending a *TRG command
via PC interface, External Trigger using the EXT
TRIG input terminal on the rear panel.
Additionally, a trigger delay can be programmed
after an event detection, and a VM Comp output
is available to indicate the instrument’s
completion of a present measurement.
Fast Buffering with Built-in
Statistics
The 5492B provides an internal buffer capable
of storing up to 512 readings. Buffer storage
operation can be enabled via front panel or
remote command. The buffer fills up with the
requested number of readings at a rate of up to
57 readings/sec and then stops. The instrument
automatically calculates statistical information
based on the stored readings such as minimum,
maximum, or average reading, and standard
deviation, which can then be retrieved along with
the readings via the front panel or remote
command.
Power button
Interface keypad
Rear panel
Serial number label
External
Trigger BNC
input terminal
RS-232
(Serial) interface
USB interface
Power line
fuse holder
2
VM Comp
(Voltmeter
complete) BNC
output terminal
mA Fuse socket
GPIB (IEEE-488) interface
(model 5492BGPIB)
Chassis ground
screw terminal
www.bkprecision.com
Model 5492B
Specifications
Specifications are based on the following conditions:
■ One year calibration cycle
Operating temperature between 18 °C to 28 °C
Accuracy expressed as: ± (% of reading + % of range) after 30 minutes warm-up and valid for 10 PLC (Slow)
Temperature coefficient: add ± [0.1% × (applicable accuracy)/°C] for 0 °C to 18 °C and 28 °C to 40 °C
Relative humidity: Up to 80% RH for 0 °C to 28 °C (75% RH for 10 MΩ and above ranges
for resistance measurement), up to 70% RH for 28 °C to 40 °C
DC Voltage
Resolution, Full Scale Reading and Accuracy ± (% of reading + % of range), 23 °C ± 5 °C
Fu ll Scale
Accuracy
Typical Input
R ange
Resolu tion
Reading
(1 year)
Impe dance
120.000 mV
1.20000 V
12.0000 V
120.000 V
1000.00 V
1 µV
10 µV
100 µV
1 mV
10 mV
119.999
1.19999
11.9999
119.999
1010.00(2)
0.02+0.008(1)
0.01+0.004(1)
0.01+0.004
0.01+0.004
0.01+0.004
>10 GΩ
>10 GΩ
>10 GΩ
10 MΩ ±1%
10 MΩ ±1%
(1) under REL status
(2) 1% overrange (1010 V) is readable at 1000 V range
Input protection: 1000 V
AC Voltage (True RMS, AC coupled)
Accuracy (1 ye ar) (1)
R ange
Re solution
Full Scale
Re ading
10-20 Hz
20-50 Hz
50-20 kHz
20-50 kHz
50-100 kHz
120.000 mV
1.20000 V
12.0000 V
120.000 V
750.00 V
1 µV
10 µV
100 µV
1 mV
10 mV
119,999
1.19999
11.9999
119.999
757.50(3)
1.50+0.100
1.50+0.100
1.50+0.100
1.50+0.100
1.50+0.100
0.50+0.100
0.50+0.100
0.50+0.100
0.50+0.100
0.50+0.100
0.10+0.100
0.10+0.100
0.10+0.100
0.10+0.100
0.10+0.100
0.30+0.150
0.30+0.150
0.30+0.150
0.30+0.150
0.30+0.150(2)
1.0+0.150
1.0+0.100
1.0+0.100
1.0+0.100
1.0+0.100(1)
(1) Specifications are for sine wave inputs >5% of range
(2) ≤3×107 Volt-Hz for 750 V range
(3) 1% overrange (757.5V) is readable at 750 V range
Measurement method: AC coupled true RMS, measuring the AC component only
Maximum Crest factor: 3.0 at full scale
Input impedance: 1 MΩ ± 2% in parallel with capacitance 10~12 ADC is readable for 20 seconds maximum
很抱歉,暂时无法提供与“TL500”相匹配的价格&库存,您可以联系我们找货
