381a DS 0715
381a Combo Non-Contact / Contact Thermometer
Features
Measure hard-to-reach, sensitive, or large moving target areas.
• Non-contact
-4 to 572°F
• Repeatable, 0.1° resolution readings ensure tests are
consistently correct.
• Contact -146 to
2,192°F depending
upon optional
temperature probe
• Temperature compensated for accurate readings.
• Temperature
compensated
• Don’t have to hit a hold button holds last
reading automatically.
• Single button,
last reading hold
function, °F/°C
switchable
• Easy-to-use one button operation you can’t lock up chip
by pressing multiple buttons at one time and therefore
don’t have to disconnect the battery to reboot the chip.
Applications
• °C and °F selectable
HVACR
• Compressor heads
• Vents
• Hot and cold areas
in insulation
• Leaks around
cooler or freezer
doors
• Leaks around
windows
• Steam traps
• Registers
Electrical
• Cables
• Circuit breakers
• Connections
• Machinery
• Motors
• Transformers
Food
• Grill & surface
temperatures
• Holding cabinets
• Serving
temperatures
• Storage
temperatures
• 9 to 1 D:S
381a Technical Data
Distance to Spot Ratio
Temperature
Range
IR Accuracy @ 23°C
and 0.95 emissivity
Contact Accuracy
Emissivity
Laser Sighting
°F or °C
Contact or Non-contact
Display Hold
Response Time
Spectral Response
Operating Temperature
Battery Type
9:1
Non-contact: -4° to 572°F (-20° to 300°C)
Contact:* -148° to 2192°F (-100° to 1200°C)
± 5°F (3°C) below 32°F (0°C)
± 2% of rdg or ± 3.5°F (2°C)
whichever is greater at >32°F (0°C)
+(0.5% of reading + 3.5°F (2°C)
0.95
Output
很抱歉,暂时无法提供与“381A”相匹配的价格&库存,您可以联系我们找货
