9130B
9130B
    B&K
    DC POWER SUPPLY 30V/3A 5V/3A
9130B 数据手册
Data Sheet Programmable Triple Output DC Power Supplies 9130B Series Features ■ Three independent and electrically isolated outputs ■ The 9130B Series triple output linear programmable DC power supplies feature isolated outputs that can be adjusted independently or combined in series or parallel to output higher voltage or current. Additionally, these supplies can operate in tracking mode with user-configurable ratios between channels. The front panel keys and rotary knob with convenient cursors let users quickly set voltage and current values. Up to 36 different instrument settings can be saved and recalled. The power-on state of the outputs can also be configured. Displays voltage and current settings for all three channels simultaneously supporting SCPI commands can be used to remotely control the power supplies via a PC. Alternatively, users can control the power supply, execute test sequences or log measurements using the provided PC software application. This software also integrates with Data Dashboard for LabVIEW apps enabling iOS, Android, or Windows 8 compatible tablets or smartphones to remotely monitor select measurement indicators. These power supplies are suitable for a wide range of applications including production testing, telecommunications, R&D, electronic service, and labs. ■ Low noise, linear regulation ■ High programming and readback resolution of 1 mV / 1 mA ■ Series and parallel modes combine channels to increase the output voltage or current ■ Tracking mode allows users to set up channels to maintain a programmed ratio ■ Fully programmable channels with Output On/Off control ■ Store and recall up to 36 instrument settings ■ Remote sense ■ Timer-controlled output function adjustable For remote control, the standard USB (USBTMCcompliant), RS232, and GPIB interfaces from 0.1 – 99999.9 s ■ Standard USB (USBTMC-compliant), RS232, and GPIB interfaces supporting SCPI commands for remote control Model 9130B 9131B 9132B Voltage 0 - 30 V (Ch1 & Ch2) 0 - 5 V (Ch3) 0 - 30 V (Ch1 & Ch2) 0 - 5 V (Ch3) 0 - 60 V (Ch1 & Ch2) 0 - 5 V (Ch3) Current 0-3 A (Ch1, Ch2 & CH3) 0-6 A (Ch1 & Ch2) 0 - 3 A (Ch3) 0-3 A (Ch1, Ch2 & Ch3) ■ NI certified LabVIEW driver and softpanel for remote control, test sequence generation, and datalogging available ■ Overvoltage (OVP) and overtemperature (OTP) protection including keylock function ■ Compact 19” half-rack form factor allows for side-by-side rack mounting of two units Technical data subject to change © B&K Precision Corp. 2021 www.bkprecision.com Programmable Triple Output DC Power Supplies 9130B Series Front panel Bright vacuum fluorescent display indicates voltage and current for each output simultaneously Numeric keypad for direct entry of voltage and current values Function keys Rotary knob Cursor keys CH1, CH2, CH3 Outputs Rear panel Thermostatically controlled cooling fan RS-232 interface USB interface Rear panel output and remote sense 2 GPIB interface AC line input www.bkprecision.com Programmable Triple Output DC Power Supplies 9130B Series Flexible operation Combined parallel mode Combined series mode 120.00V Series 3.000A CH1+2 5.000V 3.000A 5.000V 9.000A Ch1 and Ch2 in Series mode Channels 1 and 2 can be wired in series to increase the voltage. Selecting Series Combined Mode provides convenient metering of the channels connected in series. Para ALL Tracking mode Para ALL Track CH1+CH2 All Channels in Parallel mode Channels 1 and 2, 2 and 3, or All channels can be wired in parallel to increase the current. Selecting Parallel Combined Mode provides convenient metering of the channels connected in parallel. Remote control and programming CH2+CH3 ALL Tracking mode options 60.000V 20.000V 3.000A 1.000A 5.000V 3.000A Ch1 and Ch2 in Tracking mode Tracking mode can be used to simplify adjustments across multiple channels by maintaining a user-defined ratio between outputs. Tracking mode can be set on channels 1 and 2, 2 and 3, or All channels. Test system integration These power supplies offer standard USB, RS-232, and GPIB interfaces to facilitate test system development and integration. The 9130B Series supports SCPI-compliant protocols and come with LabVIEW™ drivers. Bipolar output configuration Application software The independent and isolated outputs can be used to create positive and negative outputs between channels 1 and 2. +VDC + Channel 2 OVDC Channel 1 -VDC PC software is provided for front panel emulation, generating and executing test sequences or logging measurement data without the need to write source code. ■ Remote monitoring on iOS, Android, or Windows 8 compatible tablets or smartphones via NI Data This feature is useful for powering bipolar circuits and devices. Dashboard for LabVIEW apps. ■ Log voltage, current, and power values of each channel as well as timestamp, CV/CC mode, and output status. ■ Quickly develop a custom dashboard with indicators, charts, or gauges to monitor your power supply. ■ Create an unlimited number of external list files to be executed from PC memory. Save and recall list files to/from the PC. 3 www.bkprecision.com Programmable Triple Output DC Power Supplies 9130B Series Specifications Models 9130B 9131B 9132B 0–30 V (Ch1 & Ch2), 0-5 V (Ch3) 0-3 A (Ch1, Ch2), 0-3 A (Ch3) 195 W 0-30 V (Ch1 & Ch2), 0-5 V (Ch3) 0-6 A (Ch1, Ch2), 0-3 A (Ch3) 375 W 0-60 V (Ch1 & Ch2), 0-5 V (Ch3) 0-3 A (Ch1, Ch2), 0-3 A (Ch3) 375 W Output Rating Voltage Current Power Load Regulation ≤ 0.01%+3 mV ≤ 0.1%+3 mA Voltage Current Line Regulation ≤ 0.01%+3 mV ≤ 0.1%+3 mA Voltage Current Ripple & Noise ≤ 1mVrms ≤ 3mArms Voltage Current ≤ 1mVrms ≤ 5 mArms (Ch1 & Ch2), ≤ 4 mArms (Ch3) Temperature Coefficient (0 °C to 40 °C) ± (% output + offset) (typical) Voltage Current ≤ 1mVrms ≤ 4 mArms ≤ 0.03% + 10 mV ≤ 0.1% + 5 mA Programming Resolution Voltage Current 1 mV 1 mA Readback Resolution Voltage Current 1 mV 1 mA Programming Accuracy ± (% output + offset) Voltage Current ≤ 0.1% + 5 mA ≤ 0.03% + 10 mV ≤ 0.1% + 8 mA (Ch1& Ch2), ≤ 0.1% + 5 mA (Ch3) ≤ 0.1% + 5 mA ≤ 0.1% + 5 mA ≤ 0.03% + 10 mV ≤ 0.1% + 8 mA (Ch1 & Ch2), ≤ 0.1% + 5 mA (Ch3) ≤ 0.1% + 5 mA Readback Accuracy ± (% output + offset) Voltage Current Series Accuracy (combined mode) ≤ 0.05% + 10 mA Current Parallel Accuracy (combined mode) ≤ 0.02% + 5 mV ≤ 0.1% + 20 mA Voltage Current General Memory Timer Remote Interface AC Input Operating Temperature Storage Temperature Dimensions (W x H x D) Weight ≤120 µs ≤90 µs ≤200 µs ≤80 µs ≤100 ms ≤100 ms ≤100 ms ≤100 ms ≤1.5 ms ≤5 ms ≤1.5 ms ≤4.5 ms ≤1 s ≤5 s ≤1 s ≤150 ms 4 memory groups with 9 locations in each group 0.1 - 99999.9 seconds USB (USBTMC-compliant), GPIB, RS-232 110/220 VAC (+/- 10 %), 47 Hz - 63 Hz 32 °F to 104 °F (0 °C to 40 °C), relative humidity up to 80% -4 °F to 158 °F (-20 °C to 70 °C) 8.45" x 3.47" x 13.96" (214.5 x 88.2 x 354.6 mm) 8.45” x 3.47” x 17.52” (214.5 x 88.2 x 445 mm) 16.98 lbs. (7.7 kg) 33.07 lbs. (15 kg) Standard Accessories Power cord, instruction manual, and certificate of calibration Transient Response Time1 Rising Time at Full Load / No Load Falling Time at Full Load Falling Time at No Load Ch1,Ch2 Ch3 Ch1,Ch2 Ch3 Ch1,Ch2 Ch3 Ch1,Ch2 Ch3 ≤180 µs ≤160 µs ≤100 ms ≤20 ms ≤2.4 ms ≤1 ms ≤4 s ≤300 ms Three-Year Warranty Optional Accessories IT-E151 rack mount kit “1” Following a change in output current from 10% to 100% load with output recovery to within 15 mV. Note: All specifications apply to the unit after a temperature stabilization time of 15 minutes over an ambient temperature range of 23 °C ± 5 °C. 4 v110221 www.bkprecision.com About B&K Precision For more than 70 years, B&K Precision has provided reliable and value-priced test and measurement instruments worldwide. Our headquarters in Yorba Linda, California houses our administrative and executive functions as well as sales and marketing, design, service, and repair. Our European customers are most familiar with B&K through our French subsidiary, Sefram. Engineers in Asia know us through our B+K Precision Taiwan operation. The independent service center in Singapore services customers in Singapore, Malaysia, Vietnam, and Indonesia. B&K Headquarters Yorba Linda, California, USA Sefram St. Etienne, France B&K Taiwan Taipei, Taiwan Dynamics Circuit Singapore B&K Precision group member Independent service center Quality Management System B&K Precision Corporation is an ISO9001 registered company employing traceable quality management practices for all processes including product development, service, and calibration. ISO9001:2015 Certification body NSF-ISR Certificate number 6Z241-IS8 Service center location Video Library View product overviews, demonstrations, and application videos in English, Spanish and Portuguese. http://www.youtube.com/user/BKPrecisionVideos Product Applications Browse all of our supported product and mobile applications. http://bkprecision.com/product-applications
9130B 价格&库存
很抱歉,暂时无法提供与“9130B”相匹配的价格&库存,您可以联系我们找货
